Question about Dell Dimension 8100 PC Desktop
Monitor automatically sleeps on startup.PLEASE HELP!!!!!!! im running a Dell dimension 8100 .thank you
  • 426 Answers
Can you get it out of sleep mode? if so then change your power settings.... you may also be in a mode that the monitor cant support try going into safemode to see if stays on ... if it does it could be two things..... the res is Too high or there is a program that is making it go to sleep......if you have anymore information or would like more help reply here or e-mail me at fixya@whypayforhelp.org
Posted on May 28, 2008
I have a dell dimension 4600 computer. I usually put the computer in sleep mode when I am not using it. Usually I press the ESC button and the computer wakes up. All of a sudden, the monitor won't...
Plug the monitor into another computer to determine if the monitor is damaged or working properly. You can also plug another monitor into your computer to determine the same thing.
May 21, 2011 | Dell Dimension 4600 PC Desktop
Dell 4700 sleep on bootup
ok here's what i can suggest. Two things.
1. Check your power settings by going to the Control Panel and then going to Power Options. Take a look at the power schemes..specifically the option where it says turn of monitor...you can select the "Always On" power scheme....if this doesn't do it...
2. Right click on your desktop and click on Properties. Go to the Screen Savers and verify that the time before the screensaver comes on is not something ridiculous like 1 minute. You can just disable the screensaver if you'd like by selecting "none"..
I'm pretty sure you're dealing with one of those two problems.
Dec 21, 2009 | Dell Dimension 4700 PC Desktop
Monitor keep going into "sleep" mode
Check the power setting in control panel of windows. If you have a monitor from another computer swap them and see if the problem stays with the computer or monitor.
May 12, 2009 | Dell Dimension 3100 PC Desktop
My dell dimension 8100 has an intermittent fault where it says no signal, when this happens the A and B lights on the back are amber.i have bought a new Dell ispiron but want to still use my old...
According to Dell's list of light codes (available here), this means "memory failed to be sized or enabled". In other words, it's a memory issue. Dell suggests reseating the memory modules. I would recommend removing the modules, make sure the contacts are clean (use a pencil eraser to gently clean them if they aren't), and use compressed air (available in cans at office supply places) to blow any dust and dirt from the module connectors on the system board. Then reseat the modules, making sure they latch properly into place.
If the problem continues, you might have a bad module. Sometimes they act up intermittently. Or it could be a symptom of a developing motherboard problem. Try cleaning and reseating the memory first as that's pretty common.
May 06, 2009 | Dell Dimension 8100 PC Desktop
Dell computer will not work with an older HP monitor
no dell have set up there computers so you cant use othe appliances that arnt dell. so im sorry for the inconveince.
please rate my help to you.
thank you.
Apr 22, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
My monitor says "opms going into off mode " as soon as I plug it into my computer. The light on the monitor is green and when I plug it into my computer is goes amber. It is a Dell dimension 8100 . I have...
Hi from your description of the problem it sounds like the display settings on your computer are set wrongly for this monitor, i.e. 1280x800. If this is the case you need to change the settings, Obviously you cant do this with this monitor in ordinary boot but you can using F8 and safe mode, control panel, display settings, change to the ones that match this monitor. Is this a Dell monitor that came with your system? if so and you need info for it heres a link that may help.
http://support.euro.dell.com/support/systemsinfo/documentation.aspx?c=uk&cs=ukdhs1&l=en&s=dhs&~subcat=138&~cat=3
I hope this helps, if not let me know. Thanks
Apr 15, 2009 | Dell Dimension 3100 PC Desktop
Monitor displays slowly after the computer starts.
try to turn off you screen saver just turn off power monitor to see monitor easy wake up after long time.if ok means windows screen saver have problem if still same look like is you monitor something wrong need to check
Jan 03, 2009 | Dell Dimension 2400 PC Desktop
My screen goes blank immediately after initial DELL startup image
You can either try to reset the BIOS, or have the restore cd fix it for you. By the way, what does the message say?
Nov 27, 2008 | Dell Dimension B110 PC Desktop
Upgrading Graphics Card
So your dell only has a AGP slot.
You need a AGP card
On nvidia side you can get
The geforce 6000 - series
Geforce 7000 series
On Ati side you can get
Radeon x1000 series
Radeon HD 2000 series
Radeon Hd 3000 series
Remember they have to be AGP
May 26, 2008 | Dell Dimension 8100 PC Desktop
Dell Dimension 8100 PC Desktop Logo
93 people viewed this question
Alun Cox
