Question about GE 29875GE Digital Answering Machine
How to set for more than four rings. - GE 29875GE Digital Answering Machine
  • GE Master
  • 17,129 Answers
Check for setting or mode setting for ring on the menu . It can be set to the desired number of rings.
Posted on Oct 05, 2010
Why no ring on any of the four phones
Has the ring tone been shut off on the main phone menu? Did you check to see the setting(s)?
Sep 10, 2015 | Uniden DECT 6.0 Cordless Phone ID
Answering machine will not pick up after four rings
What model Uniden 5.8GHz phone/answering machine? Exactly what does it do after four rings? Does it just drop the call or continue to ring? Is the answering machine turned on?
Nov 19, 2013 | Uniden 5.8GHz Expandable Cordless Phone...
The phone only rings four times then it goes into answere
Here's how to set the ring delay:
Setting the Ring Delay
The Ring Delay setting determines the number of times the machine
rings before it answers.
1 Press Menu, 2, 1. .
2 Press Z or X to select RING DELAY.
3 Press Set.
4 Press Z or X to select how many times the line rings before the
machine answers.
5 Press Set when the screen displays your selection.
6 Press Stop to exit.
Mar 05, 2011 | Brother FAX 930 All-In-One Thermal Printer
THE ANSWERING SERVICE CUTS IN BEFORE I AM ABLE TO GET TO THE PHONE
There should be a switch towards the bottom on the right hand side
Setting ring time switch The ring time/toll saver switch allows you to set the number of rings the caller hears before the answering system plays your outgoing message. You can set the switch to answer af ter two rings or af ter four rings. Once the greeting has star ted, you can stop it when you pick up the call at the handset or base. In the TS (Toll Saver) position, the answering system picks up af ter two rings if you have new messages, and af ter four rings if there is none. This way, if you call long distance to check your messages, you can hang up af ter the third ring to avoid billing charges.
Feb 28, 2011 | Uniden Cordless Phone
How do I increase the rings before message answers?
Setting the Number of Rings (Excerpt from the Uniden Dect 1580 Phone manual
The ring time setting allows you to set the number of rings the caller hears before your answering system plays the outgoing message. You can set the ring time to answer after two, four, or six rings. If you enable the Toll Saver (TS) setting, the answering system picks up after two rings if you have new messages, and after four rings if there are
none. This way, if you make a long distance call to check your messages, you can hang up after the third ring to avoid long distance billing charges.
  1. Press Menu/Select.
  2. Select the Ans. Setup menu, and then the Ring Time submenu.
  3. Move the cursor to select a ring time (Toll Saver, 2 Times, 4 Times, or 6 Times).
  4. Press Menu/Select. You will hear a confirmation tone.
thanks
Jul 01, 2010 | GE 28112EE2 Cordless Phone
How do I replace the headlights in my 1985 Lincoln town car.
To replace the headlights, you must first remove the trim ring around the headlight. There should be three or four screws holding it in place. Once the trim ring is removed, there will be four screws, two at the top and two on the bottom. Carefully remove screws and remove the retaining ring. Gently pull bulb out, unplug the wire connector. With new bulb in hand, carefully connect the wiring to back of bulb and carefully set in place. While holding the bulb in place, set retaining ring back in place over bulb and insert screws. Then replace the trim ring, tighten the screws and you are done.
Jun 12, 2010 | 1985 Lincoln Town Car
Would like to increase number of rings before answering machine comes on.
Feb 02, 2010 | Uniden DECT 6.0 Cordless Phone ID
Ow doyou set it to ring four times before the
Press menu 3 times. Then press either repeat/rew or skip/ff to get to 4. Press set/ringer to store your changes.
That is all it takes to get your 4 ring then answer maching picks up.
Nov 20, 2009 | Uniden Cordless Phone exai398i
Number of rings before recording answers
Choose how many times the line will
RINGS IS...” ring before the system answers a call.
• Set for 2 to 7 rings, or choose
Toll Saver 2/4 or Toll Saver 4/6.
• When set to Toll Saver 2/4, the system
answers after four rings when you have
no new messages and after two rings
when you do. Toll Saver 4/6 causes the
system to answer after six rings when
you have no new messages and after
four rings when you do.
• During setup, the Message Window will
display the number of rings (8 for Toll
Saver 2/4, or 9 for Toll Saver 4/6).
Sep 05, 2008 | AT&T 1738 Digital Answering Machine
Number of rings
Looks like 6 is the Max, according to the Manual.
Setting the Ring Time
Ring Time allows you to set the number of rings the caller hears before your
after two, four, or six rings. If you enable the Toll Saver (TS), the answering system
picks up after two rings if you have new messages and after four rings if there are
none.
1) Enter the Answ. Setup menu, and then the Ring Time
submenu (see "Entering the Menu Option" on
page 16).
2) Press volume up/down to select a Ring Time (Toll
3) Press the OK soft key. You will hear a confirmation tone.
Toll saver is a feature where you can call the phone yourself, if there are messages it wil answer in 2 rings, if not it'll answer in 4 rings. The idea is to hang up on the 3rd ring and save the LD changes.
Hope that fixed Ya...
Geno
Mar 27, 2008 | Uniden TRU8885 Digital Answering Machine
GE 29875GE Digital Answering Machine Logo
37 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Dudeman321
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
