Question about Gibson Heating & Cooling
Hi my name is corn my gibon furnance is approximately 4yrs old last year it would shut down at Any given time would reset the rollout switch and it would comeback on. Eventually we replaced the rollout switch this year its doing the same thing only its not staying on and its giving off a burning odor HELP!.
    President:
  • 1,515 Answers
Hi, what happens if this roll out switch is tripping, as it is a safety switch, what will cause a flame roll out is a flue cap missing on your roof, or a bird has nested in the flue pipe this is something you should check. I have had this happen before. Wind will blow down and cause the flame to roll out. Also, if that looks good, a cracked heat exchanger will do this also, but this is a new unit so I will rule this out. The next thing you need to due, is remove each burner one at a time, turn it over and clean it out. To remove one there is a slot at the very back that it will rest in. Raise the back up by grasping the burner from the front, slide it forward over the brass orfice and pull it out, very easy. Do the same when putting it back as you want it to set in the slot in the back, and pull it over the orfice. Make sure your inducer motor is running up to speed and not shutting down on you somewhere in the heating cycle. If it were to shut off, the heater would shut off, so there is no danger. When you smell these fumes, the burners are plugging up and you are smelling this. If your gas furnace is propane gas and not natural, this is a big problem if and when the burners start to plug up. If it is propane and you continue to have a problem, call out you local gas company and just tell them you smell gas. They will check the inlet and manifold pressures for you at no charge. Make sure this flue pipe is clear and please don't forget to rate me and keep me posted in the comment section, I would like to know what you find.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
PS, Propane if you have it, will cause the burners to carbon up, so you need to keep an eye open.
Posted on Oct 05, 2010
Testimonial: "Thanks for the help! Your response was quick and extremely helpful. Will checkout your solution and get back to you."
  • Robert Horton
    Robert Horton Oct 06, 2010
    Thank you for the great rating. When this problem happens, roll out, its either plugged burners, or air coming down the flue blowing the flame back enough to trip the switch. I hope you find the cause.
    Shastalaker7
Keeprite furnance showing 7 flashes blower fan on no fire inside furnance
Limit Or Rollout Switch Open--Requires Manual Reset.
Read Sticker On Unit--Codes Are There.
Mar 07, 2015 | Heating & Cooling
Tip
How to make sure you Heat is working
A common problem with a furnance is the furnance will attempt to ignite, several times, you will notice that the house is not heating properly. You will hear the furnance come on and you will assume the heat is on, and the house will continue to be cool. You wiil check the furnance and you will hear it start up and the blower will come on, however a few seconds later after you have walked away the blower will shut down and there is no heat on at this time. You will again go check the furnance and after the furnance start and go through the cycle the furnance will shut down you will notice that the furnance has indeed shut down. This is the common problem of the flame sensor, you will have to remove the flame sensor, get a small piece of fine grade sand paper, and remove all the black colored carbon from the flame sensor until is is shinning bright, replace the flame sensor and attempt to start the furnance. You will notice that apatment or house have reach the set temperture, that the furnance has went through its cycle and the furnance will ignite and stay on continueously until the house obtain the preset temperture..
on Dec 13, 2009 | Heating & Cooling
Fan comes on no heat
turn a/c power off. place a jumper wire between both sides of switch, leaving wire attached on both sides. power on, set thermo to heat, if furnace stay lit after test, replace rollout switch. If furnace shuts down after short time it's not the rollout. please remove jumper after test.
Feb 12, 2015 | Reznor Hanging Furnaces-Power Vented-...
My furnance keeps turning off and I could go to furnance flip switch on and it only last 5 minutes then shuts off again
You may want to check the limit switch or you could have a issue with the gas valve or transformer. I would check the low voltage transformer first, Sometimes I have found that under load the transformer will open ( quit working) and will close after power is removed and it cools down, It indicates a bad internal connection.
Jan 26, 2013 | American Standard Trane Ge Gas Furnace...
Hi,my name is julio i have a problem with my goodman furnance,the furnance run for 10 or 15 minutes and then shut off and come back again for 5 minutes keep do in on and off on and off and then shu off...
it is probably hitting the high limit switch possibly.
Is your filter clean?
Are all the vents in the house full open?
Is your furnace vent (flue Pipes) clean and unobstructed?
Jan 07, 2011 | Goodman GMS90703BXA Heater
Gas furnance would only operate for about 3-5 minutes then turn off. Replaced gas valve on furance for a Rudd comerical A/C 4 ton unit model UKKA-A048JK10E. Now the blower fan turns on but the igniator and...
the rollout switches will be located at the ends of the burner assembly and will have a manual reset. they must be manually reset to ensure that the problem has been corrected. Most units will go into a soft lockout for a time and eventually a hard lockout if the problem persists. Go to tempstar.com and go to their troubleshooting section for a gas furnace. the codes they give are pretty common for alot of furnaces and see if they help
Dec 10, 2009 | Ruud UAKA042 Air Conditioner
I have a Carrier Weathermaker SXi. Furnance will not turn on. I shut power off and waited ten minutes and tried to restart. Codes flashing are 12, 31, 32, 33, 41, 42. Can this be started in emergency mode?
Emergency heat is made for this kind of situation.So yes you can.
now for the codes.
code 12= Blower on after power up
code 31=High heat pressure switch or relay didn't close or reopened
code 32=Low heat pressure switch or relay didn't close or reopened
code 33=limit circuit fault(Flame rollout switch is open)
code 41=board fault
code 42=control lockout
Please rate this solution
Jan 17, 2009 | Heating & Cooling
Gas furnace cycles on then shuts down
COULD BE A ROLL OUT SWITCH ,OR GAS PRESURE TO HIGH TRIPPING ROLLOUT SWITCH COULD BE A FLAME SENSOR ,TELL ME MORE IF POSSIBLE
Nov 21, 2008 | Water Heaters
Heating & Cooling Logo
184 people viewed this question
Top Gibson Heating & Cooling Experts
Paul Carew
Are you a Gibson Heating and Cooling Expert? Answer questions, earn points and help others
