Question about Candy Dishwashers
We have Candy CDI 1012/2-80 dishwasher. When we switch it on all the lights on Programme 1 to programme 4 continously flash and beep!!!
vickygomar
  • 460 Answers
SOURCE: Hotpoint BF1620 Integrated dishwasher not working
Lets try the following hope this works
1.- unplug the appliance, isolate it from the electric supply.
2.- Remove the kitchen unit plinth and check inside the inspection panels below the door to see if there is water in the base.
If there is, sponge it out and then try the machine again.
Was this helpful?
Posted on May 15, 2009
  • 4 Answers
SOURCE: Candy dishwasher CDl 1012/2-80, program stuck?
Hi Derek if its only been used about as you say ten times it will stil be under gaurantee,just call the supplier and have them solve the problem for you mate it sounds as if the program selector is faulty as it is all eletronic programming and could even be a faulty circuit board.
hope this helps
regards JL
Posted on Oct 04, 2009
SOURCE: dishwasher wont complete program 1 2 or 3
Did you ever resolve this problem with your dishwasher, unfortunately i've exactly the same type of problem!
Thanks Steve
Posted on Jan 23, 2010
SOURCE: cda cw 496 dishwasher runs cycle till rinse light
cda cw496 stops after a few minuts then just beeps help me with my problem please
Posted on Feb 16, 2010
  • 3247 Answers
SOURCE: I have a candy cdi
Is there water in the dishwasher when it stops?
Are you able to check if the water is normal temperature or warm/ hot?
Can you try the dishwasher in a short cycle and see if it completes the cycle?
Posted on Oct 11, 2010
Zanussi dishwasher ZDF601M 1 in 3 red light comes on and programme doesn't work through
26269906-aipk5px1bmfkdpsmrgevaqwn-3-0.jpg "3 in 1" function
This appliance is equipped with the "3 in 1" function, that
allows the use of the "3 in 1" combi detergent tablets.
This function can be selected with all washing programmes.
With the selection of this function the inflow of rinse aid and
salt from each respective supply container is automatically
deactivated and also the indicator lights for salt and rinse aid
are deactivated.
Select the "3 in 1" function before the set of a washing
programme.
Once this option is selected (indicator light illuminated) it will
remain active also for the following washing programmes.
With the use of the "3 in 1" function, the cycle durations may
change. In this case, in the digital display, the indication of the
running time of the programme is automatically updated.
NOTE: Once the programme is running, the "3 in 1" function
can NO longer be changed. If you want to exclude the "3 in 1"
function you have to cancel the programme setting (see
chapter "Starting a washing programme" - "Cancel a washing
programme in progress") and then deactivate the "3 in 1"
function.
In this case you have to set a washing programme (and
options) again.
Activation/deactivation of the "3 in 1" function
(The dishwasher must be switched off)
1. Press the On/Off button. The On/Off indicator light
illuminates (setting mode).If a programme button indicator light is on, this means that a washing programme is set. The programme must be cancelled: press simultaneously function buttons 2 and 3
for about 2 seconds. All the indicator lights will turn off (except for the On/Off indicator light and eventually salt and rinse aid indicator lights) indicating that the set programme has been cancelled and the machine is now in setting mode.
2. Press simultaneously function buttons 2 and 3, until the
indicator lights of function buttons 1, 2, 3 and 4 start
flashing.
3. Press function button 4, the indicator lights of function
buttons 1, 2 and 3 turn off while the indicator light of function
button 4 goes on flashing.
4. Press function button 4 again, the "3 in 1" indicator light
illuminates, indicating that the "3 in 1" function is active.
To deactivate the function press function button 4 again, the
indicator light turns off.
5. To memorise the operation, switch off the dishwasher by
pressing the On/Off button or wait about 60 seconds after
which the dishwasher will automatically return to setting
mode.
Dado
Aug 29, 2016 | Zanussi Dishwashers
Zanussi zdt 6053 usually will not run full cycle (on any cycle) but stops with constant error beeps. But it is draining ok and sometimes goes full cycle (not often) Any ideas?
Could be anything!
If you suspect that there is a fault then it will be displayed by blinking LED "END OF CYCLE". As the display of failure in hexadecimal code it can flash up to max. 15 times than short pause and after that repeat fault code. You must to count the number of times the LED "END OF CYCLE" flash up.
Example from user manual: Anti-flood device is activated.
- continuous flashing of the indicator light of the running programme
- 3 intermittent audible signals
- 3 flashes of the END OF CYCLE indicator light
(which means "i30" fault code, the cycle is interrupted and the
drain pump switches on).
Possible causes:
Water leakage from the tub - sump and various connections
(pump, upper spray arm duct etc.); floating sensor blocked
mechanically; microswitch faulty; fill solenoid blocked
mechanically; circuit board faulty (solenoid triac short-circuited);
wiring faulty.
26226179-aipk5px1bmfkdpsmrgevaqwn-3-1.jpg Could be also:
To cancel a washing programme in progress:
- Open the dishwasher's door.
- Press the programme selection/cancel button for about 3 seconds,
until the indicator light of the running programme turns off and the
END OF CYCLE indicator light flashes, indicating that the running
programme has been cancelled and that the machine has
returned to setting mode. It is now possible to select another
washing programme. If a new washing programme will be
selected, check that there is detergent in the detergent dispenser.
NOTE: only during the drying phase, if the dishwasher's door will be opened and remains open for more then 30 seconds, the running programme will be automatically cancelled and the machine will return to setting mode. This will happen, always only during the drying phase, also when the machine is switched off by pressing the
On/Off button and remains switched off for more then 30 seconds.
Dado
Jun 26, 2016 | Zanussi Dishwashers
When I start the normal 50 button, the top and middle lights blink three times. Then after few seconds the normal 50 and bottom lights start to blink
Start the wash programme
1. Check that when the dishes and cutlery are loaded in the dishwasher
the spray arms are free to rotate.
2. Open the water tap fully.
3. Shut the door.
4. Press the ON/OFF button. ON/OFF button indicator comes on.
5. Press the button for the programme required (see "Programme Table"). The programme indicator lights up. One or two lights will flash in the multi-display. During this time it is possible to reselect the programme. The selected washing programme begins after approx. 6 seconds. The current wash programme stage will always be shown in the multi-display.
3 If the top light and/or the middle light in the multi-display flash after
the programme has started please read the section "What to do, if...".
Dado
Jun 13, 2014 | AEG 24 in. Favorit 40630 Free-Standing...
Candy Futura CDF 325 beeping alarm
Is there a sequence to the beeps?
Jun 04, 2013 | Candy Dishwashers
Why does my Diplomat ADP 8902 dishwasher beep twice when i switch it on and the 4th wash program light flash and do nothing else?
Can I say thank you for the above advice. Hit the programme button 4 times and closed machine. Now running rinse cycle. Let hope it works afterwards. Will post ant let you know.
Nov 20, 2010 | Dishwashers
I have a candy cdi 3515 and after about 1/2 an hour into the programme it stops and a continuous alarm bleeping starts.
Oct 11, 2010 | Candy Dishwashers
How can i reset diplomat dishwasher it is stuck on a program with the 3 red buttons at the left flashing and beeping.
turn it off. switch it back on and immediatley hit the programme button 4 times within 2 seconds. This should clear the programme and reset the controller.
Aug 23, 2010 | Dishwashers
1)My Candy DFI 50 is not washing properly, it leaves residue on the pots. 2)The programme controller on my DFI 50 seems to be sticking. Sometimes the dial doesn't move at all or takes 'hours' to run a...
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101
Aug 09, 2010 | Candy DFI Plan Built-In Dishwasher
Dishwashers Logo
267 people viewed this question
Top Candy Dishwashers Experts
 Evgeniy_Getz
Evgeniy_Getz
Dado
Tom Chichester
Are you a Candy Dishwasher Expert? Answer questions, earn points and help others
