Question about Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13 In
I have a HILTI TE905 breaker and something is seems wrong with the chuck or the chilsal as it keeps falling out of the end and not gripping it. Is it possible to take the chuck apart to see if I can spot the problem and if so, how?
I have just dismantled my own TE 905 to see why it was dropping the chisels and have found the following:-
1. The chisel is worn and has almost become too small for the chuck. (mesure the thickness of the chisel at both ends of the hexagonal shaft and see the difference)
2. The chuck is worn and will probably need to be replaced.
I phoned Hilti today and was quoted £100 for ONE PART OF THE CHUCK!!!
a. The chuck as a whole can easily be removed by undoing the four torx screws that hold the chuck on to the main body.
b. The chuck can be dismantled by removing the retaining ring that holds the metal outer case in place at the front of the chuck. This is very fiddly and requires some engineering skill, the use of pointed instruments could easily result in injury.
The third fix is the one I am going to use to 'patch up' my old breaker. This involves welding some small amounts of dissimilar weld onto the points of the hexagonal section at the rear of the chisel then grinding them to near enough the original size of the un-damaged section of the chisel.
This will very crudely stop the chisel from passing the ball bearings inside the chuck. PLEASE NOTE THAT ANY HEAT APPLIED TO THE CHISEL WILL CAUSE STRESS AND POSSIBLE FAILURE OF THE CHISEL. ANY MODIFICATIONS OF THIS NATURE COULD RESULT IN INJURY TO PERSONS WORKING AROUND YOU AND ARE NOT RECOMMENDED IF YOU ARE WORKING AT HEIGHT OR WITH PEOPLE BELOW YOU. This is a fix that should only be attempted by competent engineers for use on a DIY or small job basis. Hope this helps.
Posted on Nov 08, 2010
  • WELDINGFIX Nov 08, 2010
How do you remove the drill bit on a Hilti TE 804
It is a quick release chuck, grip the body and twist the chuck anti-clockwise.
Apr 17, 2016 | Hilti Drills
Need a new chuck for a tm8 hilti drill
The TM8 was only manufactured from 1984-1986. Parts have not been available in around 15 years. The TM8 had HIlti's version of the Joacob's chuck. It tightened the opposite way from a standard chuck. It had a tendency to fall apart and come off.Hilti revised the chuck two to three times but eventually did away with it after three years.
You might be able to find one on Ebay.
Sep 18, 2011 | Hilti Drills
Chuck fell off!
You did not state which model you had but normally on Hilti drills with a removable chuck you just put the nose of the chuck in the palm of your hand. Take your fingers and pull back the sleeve. Slide it back on the guide tube and then turn it until it catches. If that does not work then something is wrong with your chuck.
Nov 14, 2010 | Hilti Drills
The chuck on my Hilti TE 24 hammer drill keeps falling off. I doesnt appear to be anything broken. Either there is a missing snap ring or I am just not putting it back on correctly. Any suggestions?
the header list 2 different drills, if yur chuck has a colllar with a quick release, I would suggest thoroughly cleaning and then using a lubricant, usually there are steel balls that lock into detents in the spindle and they might be stuck the collar should move freely.
Sep 25, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
Where should I grease the hilti 7c
You should not have to grease The TE-7. It is permantly lubricated. You can occasionally put a small ball of grease on the end of a drill bit before you stick in the chuck. This will keep the chuck greased.
Aug 14, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
Te70 hilti hammer drill
The TE-70 is permantly lubricated. You would only add lubricant if you took the tool apart. You can add a small amount of grease to the end of your bit occasionally before putting in the chuck. This keeps the chuck parts lubed.
Jul 09, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
The chuck on my old Hilti TE 60 is stripped.
Are you talking about the cap nut that threads onto the chuck? It is very rare that it would strip out. Word of warning if you do find one and thread it back on. You need to have a chisel in the chuck and have the chisel end locked in a vise. This protects from breaking the gear housing on the inside where the shift dog rides up and down.
Those parts are no longer available but you can still find some used on Ebay. Also the TE-72 used the same chuck parts.
Apr 27, 2010 | Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13...
Hilti te-72 hammer failure
Do not put it in hammer mode and try to unscrew the chuck! This will break the housing internally. To remove the chuck you will have to put a chisel in the chuck. Lock that chisel in a big vice. You will then have to put a pipe wrench on the chuck to unscrew it. It is regular threads but there will be loctite on it. Once that is off your will have a spring and two roller bearings to remove before you can slide the bell off. You will then have 8 5MM screws to remove. This will remove the chuck. You will then have a snap ring to remove. After that you can remove the whole cylinder assy. More then likely your connecting rod is broken.
Jul 20, 2009 | Hilti TE 7-C 120V Rotary Hammer Drill
Breakers support
When breaking Concrete, the breaker is expected to penetrate the material, allowing it to crack and shake loose from the reinforcing steel. High frequency breakers tend to provide better performance in this application as it is not the energy per blow, but the fast blow rate that destroys the concrete's structural integrity. We recommend on concrete walls, footings, and floors to use a 750 - 1,500-ft. lb. breaker. With larger projects, consisting of large footings greater then 4 cu. yards, use a 2,000 - 5,000-ft. lb. breaker. The high production demand of bridge and building demolition requires a 7,500 - 10,000-ft. lb. breaker.
Aug 27, 2008 | Northwest Smith Cooper 3/4" Hose End...
Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13 In Logo
565 people viewed this question
Top Hilti Drills Experts
John Trevino
Are you a Hilti Drill Expert? Answer questions, earn points and help others
