Question about GE Monogram ZDP48L4GHSS Dual Fuel (Electric and Gas) Kitchen Range
I get a f9 error code on my new 48 ge monogram range
  • 3 Answers
SOURCE: Need a duel fuel range
We love ours have had it for two years. We have the 48" Dual fuel with the grill on top. Model ZDP48N6RH2SS.
The only issue we had to adjust to is the btu's (stove top flame) are so high and there is designated simmer burner or low btu burner.
The grill is excellent especially in the winter but you have to follow the instructions. First time use we didn't let it heat up long enough. Patience - it's worth it.
That's for our model from 2006.
YOu must be sure to get a strong enough range hood for the range you buy.
Posted on Jan 02, 2009
localwonder
  • 6784 Answers
SOURCE: I got an F9 code on my GE Monogram Stainless Steel
HI. A F-9 code will, generally, be the result of a Problem with your door lock circuit, such as pinched wires between the Electronic Range Control board (ERC), and door lock switch. I would inspect the wiring to , and from the door lock switch for faults. If all wiring is ok, and visibly connected well at the switch, and control board, this will confirm that the door switch has failed. Use the procedure below to confirm the failure.
Before repairs or further testing can begin you must disconnect the electricity at the fuse panel, at the circuit breaker panel, or by pulling the plug. Make sure the power is off before proceeding. Gain access to the latch assembly.Set the latch to the "clean" position, and test for circuit continuity at the terminals of the switch with your VOM's ohmmeter function. If there is no continuity, the switch is faulty. Use caution when testing.
Posted on Dec 21, 2009
SOURCE: tin foil stuck to bottom of new ge monogram oven
I had the same thing just occur. GE is now telling me the only fix is to buy a new range. Great. $10K for a range that I use once.
Posted on Jun 10, 2010
SOURCE: I have a 48" GE
I just bought a new/used GE mongram natural gas range and need an LP conversion kit. Called GE and found them very UNhelpful. Can this be this hard? The party I called will not take the range back. $3000! I thought I got a great deal and cannot use the range the way it is. I need help too.
Posted on Aug 30, 2010
  • 403 Answers
SOURCE: What does "F9" on keypad signify on a GE JGBP35
Problem with door circuit. You may have a pinched wire between control board and door lock switch. Unplug range. Gain access to the control panel and unplug all connectors. let it sit for a minute. plug all connectors back in. examine wires going to the door lock, ensure that they are not pinched. check operation of the door lock. If problem persist, you may have to replace door lock.
Posted on Feb 08, 2011
GE monogram double oven . Self cleaning top oven and F9 in red showing and beeping noise
F9 is a problem with the oven door lock circuit. If the door is locked, it's probably a bad switch that tells the oven it's locked. If the door isn't locked, it's probably a problem with the lock mechanism.
A common problem on many built-in GE ovens (you don't say if yours is built-in or free standing...) is air circulation in the control panel. The fan that keeps the panel cool either stops working or gets clogged with dirt/dust and can't move any air. This causes the panel to overheat and can cause all kinds of odd problems and error codes. If you have a built-in, check to make sure the fan is working and the mesh screen behind it is clean.
Jul 17, 2016 | GE Monogram ZET3058SHSS Stainless Steel...
Can ge 48" dual over
Yes it should be fine.You might want to check on the electricial code where your located. I would.
May 19, 2011 | GE Monogram® ZDP48N6DHSS Kitchen Range
I am thinking about buying a used ge monogram range. Model number ZDP48L4GH3SS. I am trying to find the stats for it, but I am having no luck. Would especially like to know how old it is, what it weighs,...
All in the links below.
GE Appliances Model and Serial Number Locator
www.geappliances.com/ge/find-model-serial-number/
Find Your Model & Serial Numbers. Select your product type. Refrigerators & Freezers. Compact and Wine & Beverage Refrigerators · Bottom-Freezer Refrigerators · Chest Freezers · Icemakers · Side-by-Side Refrigerators · Top-Freezer Refrigerators · Upright Freezers. Cooking Products. Advantium Ovens · Cooktops ... Missing: zdp48l4gh3ss
How to Determine the Age or Manufacture Date of a GE Appliance
products.geappliances.com/appliance/gea-support-search-content?contentId=16195 How to Determine the Age or Manufacture Date of a GE Appliance. The manufacturing month and year is coded into the serial number (not the model number) of the appliance. Our serial numbers begin with two ... for further assistance. For information on old RCA appliances, see RCA Appliance Age or Manufacture Date. Missing: zdp48l4gh3ss
Discontinued Models - GE Appliances
www.geappliances.ca/en/products/discontinued-models Discontinued Models · Explore our GE Collections. Our Company. About us. Our Story · Appliance Donation Center · Press Room. Websites. GE Appliances Worldwide · Business to Business · Corporate Website · Careers · Monogram Design Centre ... Missing: zdp48l4gh3ss
Parts for GE ZDP48L4GH3SS Range - AppliancePartsPros.com
www.appliancepartspros.com > GE > Range Original, high quality parts for GE ZDP48L4GH3SS Range in stock and ready to ship today. 365 days to return any part.
Parts including Gas burners
http://www.appliancepartspros.com/parts-for-ge-zdp48l4gh3ss.html
These are posts about that Range
https://cse.google.com/cse?cx=partner-pub-9933858514302629:4836214790&q=ZDP48L4GH3SS&oq=ZDP48L4GH3SS&gs_l=partner-generic.3...146736.146736.0.147883.1.1.0.0.0.0.115.115.0j1.1.0.gsnos%2Cn%3D13...0.42j1764j2..1ac.1.25.partner-generic..1.0.0.BUEnm5lSMk4#gsc.tab=0&gsc.q=ZDP48L4GH3SS&gsc.page=1
Weight and Specs will be the same at 538 lbs.
ZDP48N6DWSS GE Monogram 48 Professional Range with 6 Burners and Griddle...
Jan 24, 2018 | GE Monogram ZDP48L4GHSS Dual Fuel...
What does F9 mean
Failure to clean code
I have two Monogram ovens but they are not adjacent to each other top and bottom but are separate in different areas of the counter. I did the self clean for both ovens for the first time and one oven had the F9 error code about 1 hour and 45 min into the clean and the other did not sound a code.
Jan 24, 2011 | GE Monogram ZET3058SHSS Stainless Steel...
I have a 48" GE Monogram 4 burner with griddle gas/ duel fuel range (ZDP48N4GD1SS) that was set up for natural gas. I need to convert it to LP but the parts website doesn't show a conversion kit for this...
Aug 19, 2010 | GE Monogram ZDP48N4GHSS Stainless Steel...
F9 error message during self cleaning cycle
Hello,F9 error means there is a problem with the lock switch.Check the wiring to the door lock switch (the wire harness may be connected wrongly).Check for stuck lock switch.
Thanks
May 31, 2010 | GE Monogram ZET3058SHSS Stainless Steel...
48" dual fuel burners clicking wont stop after lit.
just remove it from the board .
and please be carefull
.FRANKIE.
May 04, 2009 | GE Monogram ZDP48L4GHSS Dual Fuel...
Tin foil stuck to bottom of new ge monogram oven
Jan 04, 2009 | GE Monogram ZDP48L4GHSS Dual Fuel...
GE Monogram ZDP48L4GHSS Dual Fuel (Electric and Gas) Kitchen Range Logo
696 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
