Question about Brother HL-2040 Laser Printer
HL2040 drum light is lit and printer not working. There is a new cartridge in place.
Replace the drum. It is the device that the toner cartridge sits in. You can also take out the drum and see if there is a 'slide' that cleans the drum, slide it back and forth several times and make sure it is 'locked' into the park area. Also refer to Brother manual or their web site for further answers.
Posted on Oct 05, 2010
I have a hl2040 laser printer and i have black verticle lines on the paper. i have cleened the corona wire by sliding the tab back and forth on trum cartridge. the toner cartridge is new. the printer was...
Remove the drum and toner from printer, turn printer off and find the glass scanner bar on the top of the inside of printer. Clean that with a paper towel and window cleaner. Wipe dry. DO NOT SPRAY INSIDE THE PRINTER. Only spray window cleaner on towel.
May 26, 2017 | Brother HL-2040 Laser Printer
Toner light on, replaced toner cartridge, won't print, toner light still on, replaced with new cartridge, toner light still on and won't print.
unplug the printer for about 5 minutes thne remove the cartridges then after five minutes put the cartriodges back ion and power on the printer and after that check if you still have the toner light on if not try to print ....
Oct 30, 2008 | Brother Office Equipment & Supplies
How do i reset the brother dr350 drum
If you have already replaced the drum - only do steps 1, 2, 3, 7 and 8.
1. Make sure that the printer is turned on and the Drum LED is blinking. Open the front cover of the printer.
2. Press and hold the GO button for about 4 seconds until all the LEDs light up. Once all four LEDs are lit, release the GO button.
3. Pull out the drum unit and toner cartridge assembly.
4. Push down the blue lock lever and take the toner cartridge out of the drum unit.
5. Unpack new drum unit.
6. Put the toner cartrisge firmly into the new drum unit until you hear it lock into place. If you put the cartridge in properly, the blue lock lever will lift automatically.
7. Put the drum unit and toner cartridge assembly in the printer.
8. Close the front cover.
Jan 29, 2010 | Brother HL-2040 Laser Printer
HOW TO TAKE OUT THE TONER CARTRIDGE ON THE BROTHER HL2040 MODEL
You open the front door, pull the drum and toner out together, lay on a flat surface and press the blue lever to lift the toner cartridge. The new one goes in after removing the packing and you re insert them together.
Dec 14, 2009 | Brother HL-2040 Laser Printer
Brother HL2040 - Shading of toner all over my page when I print
The drum is a very sensitive part. Should not touch with bare hand, expose to light for long, etc. With what did you clean,it.
May 19, 2009 | Brother HL-2040 Laser Printer
The paper light blinks continously on my Brother HL2040 laser printer even though I have paper in the tray. I have changed the cartridge and drum and changed the drive settings as someone else had...
Did you try to reset the printer?
WIth the printer ON
Open toner-drum door
Hold GO button until all four lights are on
Release GO button
Close door
Printer will cycle through selftest and all lights will be reset
Apr 18, 2009 | Brother HL-2040 Laser Printer
Drum error
Just installed new toner and drum in printer (brother 2040 hl) it copies but real light
Sep 03, 2008 | Office Equipment & Supplies
Changing the toner on a brother HL-2040 in my office
It should be one unit??? look at the toner cartridge and look for a shiny cylinder that is the drum.
you can google brother hl2040 drum and click on images on the top right of google to see what it looks like
Aug 21, 2008 | Brother HL-2040 Laser Printer
Drum light on after installing new drum
As posted by Songdancer - this solution worked for my HL-1440 to reset the drum light
"Brother's webpage says to reset the drum counter. On some models this is done by opening up the front door, pressing the GO button until all 4 lights are lit, then releasing the GO button"
Apr 30, 2008 | Brother HL 1440 Laser Printer
Brother HL-2040 Printing With Strange Gray Marks on Back of Paper
Sounds to me like the toner - that is the toner cartridge has the wrong toner in it. The drum should be OK - clean it up first and then use a genuine toner cartridge OR you can buy our refill kit on eBay - search for Brother HL2040 - michellem6123
Oct 16, 2007 | Brother HL-2040 Laser Printer
Brother HL-2040 Laser Printer Logo
359 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
