Question about Citizen CT-S2000 Printer
CT S2000 The error light is on. The driver is installed and the printer works. But still I have the red light.
2 Suggested Answers
  • 158 Answers
SOURCE: After installing printer & drivers
After installing the printer and the software you must reboot the computer to register the hardware changes. After booting up open your "printers" from the Control Panel or Start "settings - printers".
Make sure that the printer is listed. If it is listed, right click on it and select "properties". Now the printer control panel will come up. Select - "Print test page". If the software and cables are installed correctly the printer will be listed and it will print the test page.
In the same way, with a right click on the printer you can select to make it your "Default" printer.
New operating systems will see the new hardware and offer to install it for you. If you say yes and OK the computer will do an internet search and it should find the correct drivers for your operating system. If it does not find the correct drivers for your operating system you may have to the companies web page and select support - downloads and find your correct driver.
Posted on Apr 13, 2011
How to install ink cartridge
That is a thermal printer. It does not use ink. It heats the special paper up in the areas that need to be darker. If you are getting blank prints you are probably using regular paper rolls. you must use thermal paper
Aug 07, 2014 | Citizen CT-S2000 Printer
Alignment is off
Check your document to insure that all text is within the margins settings. You will most likely find that these settings are correct in which case you should check that you have correctly aligned the paper in the paper tray of your printer. One or the other of these should fix your problem.
Nov 19, 2013 | Citizen CT-S2000 Printer
I have an imac. Everything turns on but it won't print.
Here is a simple solution that can help to resolve the issue.
First is to check the lights on the printer, check the online/error LED if it is green or red, if it is green then it is working, if it is red then there is an error. You can also try to check the cables between the computer and the printer it might be loose. If everything is working in the printer and the cable is properly attached you can try to reinstall the printer driver or try the printer to other computer. If your using 2 or more printer make sure that your printer is on default.
To test the printer:
Press and hold down the cancel button for about 10-15 secs and it will print out.
If you need to install the printer driver you can also download the driver from this link.
I hope this resolved your issue.
Thank you for choosing fixya
Mar 03, 2011 | Samsung ML 1710 Laser Printer
MANHATTAN CT-115
1st You download Webcam Driver.
MANHATTAN CT-115
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Sep 30, 2009 | IC Intracom Manhattan FUN! CAM Webcam
Right out of the box, my ML-2510 has a solid red error light
You should install the software prior to connecting the printer, to make sure the provided drivers are ibstalled and not the generic ones that come with Windows.
Jul 22, 2009 | Samsung ML-2510 Laser Printer
My printer is flashing two red lights and the
Communication error is saying that the computer & printer is not communicating. Try uninstalling the driver/software and then download updated drivers/software for the o/s you are using from the support link on epson.com. Install the updated drivers/software and see if it works. Hope this helps.
Jul 02, 2009 | Epson Stylus C86 InkJet Printer
Cannot Install it Successfully
Restart you computer. Turn your printer off, wait 20 seconds and turn it back on again. Load up software you use to talk to the printer.
What interface are you using to connect to the printer?
Jul 17, 2008 | Star Micronics TSP400 Label Printer
Static Warning light
Hi Angela,
The Red LED has the following function;
On all the time (not flashing) - Lid is open.
On and flashing - An error has occured. ('out of dye film', 'card jam', etc).
The error would normally be reported on the PC screen via the status monitor. If the status monitor is not running you will not get any error messages. To get the status monitor running again, it's easiest just to re-install the driver. The drivers can be downloaded from Magicard's web site The latest driver for the Rio 2 / Tango 2 (V6.01) is also compatible with the Rio 1 / Tango 1 printers. Download the driver from here;
http://www.ultramagicard.com/support/technical-support/?R=&L=&id=&lang=1&printerID=7&supportOption=1
IMPORTANT: When you run the driver installation setup program, the printer should be switched off. Also, you will be given the following choice;
'Add a printer' or 'update driver files'. Select 'update driver files'. The PC will then ask you to restart. The installation will continue after the reboot. Select your communication type (either USB - recommended, or LPT). You will be prompted to switch on and connect the printer. If USB the port name will be 'NUSB01'. Follow the rest of the instructions to the end of the installation. You will be asked to choose the model at the end.
You should now have a working status monitor. Let me know what the error says on the PC screen if you get one when the printer initialises.
I hope this helps.
Jan 16, 2008 | Magicard Rio Card Printer
Citizen CT-S2000 Printer Logo
56 people viewed this question
Top Citizen Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tejodhar Atreya...
Tejodhar Atreya...
Roy May
Are you a Citizen Office Equipment and Supply Expert? Answer questions, earn points and help others
