My Canon MP730 MFC won't print. Ink cartridges are all full. Error message / alarm says " Check printer, press resume key" and has #336 also in message box rotating. I have tried reinstalling printer drivers. but now won't even copy. Can't receive faxes. HELP !
  • Brenness May 28, 2008
    I didn't realise i was signing up for a spam service for printer consumables. I'm sure its in the fine print of the terms and conditions ?
IS there any body intelligent enought to help me with thi problem ?
Posted on Aug 20, 2008
Save ink cartridges and toner cartridges
christinarosy
Don't waste money on Printer Ink. Save up to 65% on toner cartridges, ink cartridges and printer supplies. "http://www.concordsupplies.***comhttp://www.concordsupplies.com">http://www.concordsupplies.***com
Posted on May 28, 2008
I have a Canon MultiPass MP730 that is flashing the Alarm and reads cartridge jammed. However I can move the cartridge manually. The machine won't do anything because of the alarm. How do I fix this?...
To fix this you first need to remove the ink and the print head.
Wash the 4 ink pads in luke warm water.
Keep running the water over the bottom of the print head until the water shows no sign of ink colouration.
Make sure all of the print head is completely dry before replacing it into your printer.
After restarting your printer you will probably see the alarm light still flashing.
Now hold your finger on the resume button for up to 2 minutes or until you hear a clunking sound.
Hold your finger on this button and the printer will fix itself and the alarm light will stop.
Aug 30, 2011 | Canon MultiPASS MP730 All-In-One InkJet...
Canon iP2600 series-USB002 error message "The
You may need to reset your printer by software.
To reset your printer jast go to:Use ip reset software:
http://serviceprinter.wordpress.com/2008/03/26/ip-tool-canon-resetter/
Download canon ip 2600 printer resetter.
Run it on your pc.
And try to reset your printer with the resetter.
Thank you.
Aug 30, 2011 | Canon Office Equipment & Supplies
"wrong cartridge" message appears, new
It could be due to "waste tank full" alarm; you may need to reset the waste tank counter.
I found a reset sequence for a MP730 printer in this website that works for F30 and F50 as well. Try:
Resetting the Waste Ink Volume Counter
1) Enter SERVICE MODE.---
By pressing Menu-Copy-#
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [OK] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Skip step (6) since there is no [OK] key on F30 or F50 printers.
Feb 24, 2011 | Canon MultiPASS MP730 All-In-One InkJet...
Canon Multipass F80 printer. "Check printer press resume key"
On the f80 you need a shop to go to service mode and get the error code and tell you what the problem is. Could be purge assembly, waste ink full, feeder error, printhead error, any number of possible problems.
Aug 05, 2009 | Canon MultiPASS F80 All-In-One InkJet...
Horrible grinding noise
The problem sounds like a broken or stripped gear in the printer. If the unit is under warranty I would contact the authorized repair station for that printer in your local area.
Nov 10, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Getting an error message on my MP730 "Check Printer Hit Resume Key" Sounds like the ink head assembly is jamb. When I open the lid, it won't return to center, as it always had.
please do it in this order:
solution no. 1: detach and reinstall all cartridges,
solution no. 2: detach all cartridges, then detach and reinstall the print head
solution no. 3: put in printer another cartridges (only for checking the printer)
solution no. 4: put in printer another print head (only for checking the printer)
if any of these solutions does not work...
sorry...
you need buy another printer (mp730 was a quite wonderful multifunction printer: copy, print, scan and fax)
Sep 23, 2008 | Canon Office Equipment & Supplies
Alarm light flashing, please wait message
Can only try
To reset waste tank full error in MP730.
1. Hit the "menu": Key
2. Hit "Copy" Key
3. Hit "#" Key
4. Scroll thru the menu headings until you come to "Test Mode" - 12th heading
5. Hit the "3" button- this will bring up Eprom Clear
6. Hit "0" button
7. Hit the "Stop" button
Can only try then your printer go on longer but some time the other you need to clean out the waste ink it inside the printer go to open up all.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jun 10, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
CANON MP730 ERROR MESSAGE 343 WASTE INK FULL
1-press the "menu" key
2-press the"copy" key
3-press the"#" key
scroll thru the menu heading until you come to "counter"
press "ok"
press "menu"
and select "clear all" it will ask you to "please wait"
then press menu two times
restart your printer
it will work
Feb 22, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Alarm light on. F80
This worked for me on an F60 and someone else on an F30. Re: Check Printer error message on Canon MultiPass by watsonk (6/7/05 11:16 PM) reply + / - It could be due to "waste tank full" alarm; you may need to reset the waste tank counter. I found a reset sequence for a MP730 printer in this website that works for F30 as well. Try: Resetting the Waste Ink Volume Counter 1) Enter SERVICE MODE.--- By pressing Menu-Copy-# 2) Select TEST MODE. 3) Select [8] PRINTER TEST in TEST MODE. 4) Select 3. [EEPROM CLEAR]. 5) Select 0. [INK COUNT]. 6) Press the [OK] key. 7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key. Skip step (6) since there is no [OK] key on F30 printers.
Sep 29, 2007 | Canon MultiPASS F80 All-In-One InkJet...
267 people viewed this question
jasbo
jasbo
