Our 37" VIZIO vx37L is not diplaying a screen. It's receiving power, and it's not a burnt fuse, so we are assuming it's an issue with a back light. Can this be fixed? How much does a problem like this cost to fix?
  • 11,361 Answers
It can be the backlight inverter boards, 24vdc power supply problem.
Please read here:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Typical shop rate will be $150 and up plus parts.
Posted on Oct 05, 2010
Vx37l blue screen
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Sep 29, 2016 | Vizio 37" vx37l hdtv widescreen lcd/tv...
Vizio vx37l hdtv10a
If recently bought, take it back as a default.good luck..
Dec 07, 2013 | Televison & Video
VX37L Screen Suddenly Went Blank, Now No Image, Sound Only on Cable Input, VIZIO Logo Lights Up
turn on the set, grab a bright flash light and dim the lights in the room. Shine the flash light on the screen, if you see a faint picture on the screen, you are dealing with a backlight problem. There are several things that can cause this. One, a bad backlight inverter, two, faulty 24vdc power supply, three, bad main board, or a bad faulty backlamp.
May 10, 2013 | Vizio VX37L Television
Vizio 37" no longer turn on
It depnds, if the board is labled with voltages at the DC output connectors or not, if not, you will have to trace out the connection to find out which one is 5vdc standby, switched 5vdc, 12vdc, and 24vdc (I have to do that all the time when I work on circuits without diagram).
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Parts: www.shopjimmy.com
Please post back what you find.
Send me pictures if you want, budmrtn@aol.com
Jul 23, 2010 | Vizio VX37L Television
I heard a pop, then the tv died. No lights, no sound, nothing, dead.
Check the power supply module first for blown up burnt parts, then the rest of the boards.
http://www.google.com/products?rlz=1T4GGIH_enUS282US283&q=Vizio+VX37L+power+supply&um=1&ie=UTF-8&ei=0mZKTPHlNobUtQOUtu2wBw&sa=X&oi=product_result_group&ct=title&resnum=3&ved=0CDYQrQQwAg
Vizio,model vx37L, won't turn on
Look at the power supply first; look for burnt parts, bad capacitors, etc. Look to see if it has any voltage at the output connectors.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Vizio+VX37L+
Dec 16, 2009 | Vizio VX37L Television
I have a Vizio VX37l and was watching it and then I heard a pop and the tv went black. The power light still is on on the Vizio on the front. I checked the fuse inside and it was fine.
It sounds like the 5vdc standby circuit is still working, that is why the main fuse is still good but you may have bad 24vdc power supply, look real close again for blown transistors or IC on the power supply board, but it can also be the backlight inverter circuit boards that blew up also. Look here to see what good parts look like: http://www.shopjimmy.com/catalogsearch/result/?q=Vizio+VX37L+
Dec 08, 2009 | Vizio VX37L Television
No digital channels after running auto search
Same thing with my vizio vx37l tv. Did you fix the problem bpakja? If so please let me know how.
Sep 30, 2009 | Vizio VX37L Television
Vizio has no power want to check fuse
remove back, only exposed board there is PS, look where blue/brown AC wire plugs into it, fuse (F1) is there (5amp-250v)
if fuse is good and you get no power or front light replace that board, or start component level troubleshooting (usually regulator trans or SM fuses (000)
Jun 24, 2009 | Vizio VX37L Television
No Picture -- just a black screen on my vizio vx37L
Did you hear any pops before the screen went black?
You've tried completely discharging it? Disconnect everything off the TV, all cables and power.
Press and hold the power button on the TV for at least 20 seconds.
Let it sit, and in about an hour, plug just the power in (directly to the wall) and see if it comes on. There should be an indicator light, is it white or orange now? Was it a different color before?
Odds are it's a board, be it the main or a video, don't know for sure. If you can take the back of the TV off and see if there are any evident signs of damage, blown or swollen capacitors, burnt traces or resistors/diodes, etc.
Oct 25, 2017 | Vizio VX37L Television
Televison & Video Logo
76 people viewed this question
Top Televison & Video Experts
