Question about Element Electronics FLX3210 32 in. LCD TV
Need remote code for cox cable box for my 32" element lcd tv
SOURCE: VIZIO vx37l tv remote control code for cox tv remote
0178 will work but you have to keep the set-up button pressed down for more than a few seconds after you press TV on your cox remote. (You will see the tv button light up 2 or 3 times after pressing it and holding the set-up button down)
Posted on Feb 19, 2008
tvtek
  • 1284 Answers
SOURCE: TV not working with remote from Cox cable/Scientific Atlanta
The cable company should be able to tell you how to scan for the remote code that will work for the TV. The other possibility is to try a Funai or Symphonic codes since they are the same with Sylvania now.
Posted on Apr 18, 2007
unsivilaudio
  • 25 Answers
SOURCE: Need remote code for Bresnan Cable 5-1 remote for Sharp 32" LCD
Apparently I didn't read the directions for code search closely enough (as it does work for my tv). So I will post them here, just to be sure people don't make the same mistake I did.
With the Device on;
1) Press "TV" on the remote control
2) Press and Hold the "Setup" button until the light blinks twice
3) Enter "9" "9" "1" to enter code search mode on the remote
4) Press the the "CH+" slowly until your TV turns off (if you accidently go to far your can press "CH-" to go back a code or two)
5) Press the "Setup" key to lock in the code, the light should blink twice if done correctly
Your device is now programmed, enjoy!
Posted on Dec 31, 2008
dsacco86
  • 1077 Answers
SOURCE: Element LCD 32" TV- expand the screen
You will need the original remote to operate the different screen modes.
My TV has the same problem, without that silly special button on the remote, I'm not able to change the screen size without it.
I google "FLX3210 remote", 3 web sites are selling it for less than $45.
I hope I answered your question correctly. Please rate me
Posted on Feb 26, 2009
  • 13 Answers
SOURCE: I NEED A WALL MOUNT FOR A 32" tv
Wall mounts use standard mounting configurations, you should be able to get a wall mount for a 32" flat panel TV at any local electronics store.
Posted on Jul 30, 2009
Element 32 in tv
Element 32 in tv - Fixya
www.fixya.com > Forum > Flat Panel Televisions > Element
38 mins ago - element 32 in tv Need a code to run the volume and on off shaw direct sat. - Element Flat Panel Televisions question.
Remote Control Code for Element LCD TV -- & Direct ... - Fixya
www.fixya.com/support/t1101060-remote_control_code_element_lcd_tv
Remote Control Code for Element LCD TV -- & Direct TV Haven't been able to find the right code to program the - Olevia LT32HVM 32 in. ... It is annoying to turn the TV on and the volume with the Element remote and then have to use the ..... Need the codefor a 42 inch LCD TV model ELDTW422 to program our Direct TV ...
Element 32" 1080p TV (ELDFW322): Unboxing & Setup ...
? 6:40
https://www.youtube.com/watch?v=EKtjBnx6EG0
Mar 27, 2013 - Uploaded by PureLegit
This is a new video on this TV that I got from Element. If you go back on my channel you will see my first ...
Jan 20, 2016 | Element Televison & Video
Westinghouse 32' flat screen tv wont work with cox cable receiver
Hello
You haven't stated the type of signals that comes with your co-axial cable; analogue or digital. Anyway, you have to retune the TV after connecting it properly with Cox-Cable receiver with TV.
Feb 23, 2012 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Model l32hd31r will not work with cox cable box.
The Cox cable box,work before?Talk to Cox cable customer seviced send u another box?Tries unplug the tv and the cable box,replug the tv and the cable box back an hour later.Tv should reset itself back to factory setting.The cable box should update it software.They might work,if they reset themselves.
Oct 06, 2010 | RCA L32HD31 32 in. LCD HDTV
Cox Cable Remote wont program to my Sylvania LC320ss8 tv.
there are different codes for the devices that you are using. When you want to insert the code for the tv. > Switch tv on and then switch all the other devices off. Insert code. For digi box > switch on and all other devices off. Insert code for digibox. You must then switch between tv and digi box using the buttons on the top of the remote. Toggle between tv/ digi box.
Have a go with the codes below with the tv and the digibox both on, you never know you might get lucky as these are new codes, if not revert back to 1st solution.
Universal Codes (both should work using these, i think!!!!! try 'em)
002,
008,
155,
198,
227,
231
Here are the codes for the 1st solution.
Good Luck,
Hughie.
Tv
0062
0004
0009
0135
0189
0183
1141
0227
0456
0008
0068
0075
0141
0161
Digi Box.
0899
0227
0287
0290
0225
0456
0251
0292
0236
0458
1106
Jun 18, 2009 | Sylvania LC320SS8 32 in. LCD Television
Need remote code for a element tv
I have an Element HD LCD TV and have Comcast as a cable provider. I used the code 11523 and the comcast remote now works with our TV. Yeah!
Apr 25, 2009 | Element Electronics FLX3220F 32 in. LCD TV
Element tv remote code flx-2210
For the Direct White remote it is 10178
Jan 18, 2008 | Televison & Video
Lcd 32" proscan need code for universal remote
Wow it took me a couple hours but hey i found the code ever1 needs and its a 5 digit code for comcast remotes with the red ok button the codes r 10090 or 10030 hope ive helped u out good luck
Oct 19, 2007 | Proscan 32LA30Q Television
Remote control codes
You need remote rc64 to control the Olevia 32 inch LCD. You can call Directv and order the remote. Use code 11610.
Oct 15, 2007 | Olevia LT32HVM 32 in. LCD Television
Setup code
Try Mitsubishi code listed for on Cox remote Click here: http://www.cox.com/support/cable/pdf/remotecodes_sa2000.pdf
Jun 21, 2007 | Insignia IS-LCDTV32 32 in. Television
Element Electronics FLX3210 32 in. LCD TV Logo
548 people viewed this question
Top Element Electronics Televison & Video Experts
LP
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
