Question about Husqvarna Garden
Proper battery charger settings for Husqvarna tractor battery, 12V
  • 27 Answers
You will want to charge this at 6 - 10 amps 12v for a few hours, then check the battery for charge.
Posted on Oct 05, 2010
How do i recharge a tractor battery?
I use my auto battery charger
May 30, 2015 | Husqvarna Garden
I have a dual marine battery charger on my boat that is wired thru a 1-2 or both switch both batteries are 12 v batteries and i was wanting to know if i could add another two 12v batteries to the sy
It sounds to me like you have an Ad-A-Battery system or something similar. Your dual battery charger has two sets of output leads. Those leads should be connected DIRECTLY as one set of leads to battery #1 and one set of leads to battery #2. Your 1-2-both switch should be OFF when you are charging. You will, I suspect, be supplying current to your motor and other boat circuits by having the switch on and running your charger through that switch. Adding two more batteries could be accomplished by buying a four battery charger (four sets of output leads) or buying a second dual battery charger. When you only want one AC plug-in you connect both charger AC inputs to a small junction box that is fed current by the AC plug-in. That will be nice and simple and safe. Of course, you need to check wire size to make sure you have proper size for the length of your wire runs.
Mar 10, 2013 | Marinco Guest 2620 Waterproof Charger
How to fix bl1830 battery when flashing red to green in charger
Take the liberty to disturb:
Our company is a Shenzhen battery factory, engaged in battery industry for 14 years, in 2010 began to set foot in the tool battery pack accessories industry, the MAKITA 18VBL1830 14.4V BL1430 opening 10.8V BL1013 series battery pack, Bosch 12V lithium battery pack and charger.Milwaukee 12V M12 1.5A 3.0A M12 M18 charger etc..Manufacturers supply quantity of large amount of pricewelcome to 86+15014034610 QQ 47018380 Mr. Miao
Feb 15, 2013 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Cannot start the engine....Battery meters out fine @12V. Had previous problems but would jumper the solinoid and start engine, then problems would disappear and mower would start normally. Now I hear the...
I would suggest starting with the battery. Put it on a battery charger over night and take it to your local parts store the following day. I have had meters read 13.8 volts on a battery only to find out that it was done.
Jun 19, 2011 | Husqvarna 155HP DualHydrostatic 42" Cut...
My husqvarna tractor won't start. It has a new battery but no clicking or anything when I turn the key. If I hook up a portable battery charger and try to start it, I hear a grinding noise but the engine...
have you checked the fuse? there is a 20amp yellow fuse under the hood just below the solenoid same side as the blade engagement switch.also be sure all your lock out switches are working or by passed.
Feb 06, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I bought the 23 HP 48" Husqvarna tractor after I cut my lawn the first time it would not start by itself. It is always dead and I have to jump it. It is only a month old. I take the key out of the ignition...
Try removing the battery after the next cut and have it tested. If it test good leave it out. If it keeps it's charge you have a draw on the battery. The simple fix is to install a switch on the negative side of the battery. If it drains out of the unit you have a bad battery.
Thanks for choosing Fix ya
May 25, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
CANT LOCATE CORRECT CHARGER
Howdy,
Most office supply stores and home supply stores, Office Max, Office Depot, Staples, Home Depot, Lowes, carry a Universal AC Adaptor that has multiple voltage settings with multiple plugs that fit a variety of low voltage charger connections.
Dec 11, 2008 | Peg Perego 12 Volt Rechargeable Battery
Ooops I charged my 12v lawn tractor battery with 6v...is there anyway to revive
This should not have caused a problem. Recharging on a trickle charger won't hurt, however, I suspect you could have a dead cell, in which case, it will not hold a charge no matter what. I would be looking into buying a new battery.
Hope this helps!
c
Oct 06, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
360 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
