Question about Transtherm Refrigerators
Water is coming from underneath the wine cooler
bobotfel
  • 236 Answers
SOURCE: Wine cooler gets too cold (freezes)
Check your thermostat setting, if the setting is ok then something wrong with your thermostat control.
Posted on Jan 21, 2008
  • 27 Answers
SOURCE: U-Line 15WC Wine Cooler Problem
Cheak The Compressor relay is fault
Posted on Jun 21, 2008
  • 171 Answers
SOURCE: Haier Wine Cooler
Hi LinnieMcAdam,
I'm Harvey the Master Plumber.
Your question is: Where can you find a 10 Watt replacement light bulb for your Haier Wine Cooler?
I usually have success at the hardware store. Start there. Then you can try the store where you bought it or call Haier.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 14, 2008
SOURCE: Cuisinart Wine Cooler
If you call (Cuisinart’s service center (800) 726-0190), they will send you a brand new unit for $10.00.
Happy Holidays,
AC Freeborn
Posted on Dec 02, 2008
  • 85 Answers
SOURCE: Avanti wine cooler temperature problem
Fixya repair directory link
http://www.fixya.com/repair
this is the direct link for repair service enginers just select the proper unit of yours and your area  location.
Posted on Mar 02, 2009
Beeping will not stop on wine cooler - red wine side
Beeping usually indicates that something has gone wrong. Probably not cooling properly. The water coming out would indicate that the unit has defrosted. Turn the unit back on again and see if the red side is cooling properly. Some wine fridges have independent evaporators which allows different cooling temps in different parts of the cabinet.
Jun 26, 2014 | Danby DWC2727BLS Silhouette 54-Bottle...
Marvel wine cooler leaks water
All coolers produce water as a result of condensation which occurs when air is cooled. The water appears upon the radiator (technically called the evaporator) inside the cold area of the cooler. When the water drips off of the radiator, it is caught by a pan which may or may not be a removable piece. The pan should lean toward the rear of the cooler and the water should pour into a drain tube. The drain tube should lead down into the compressor area of the cooler and deposit the water into another pain which is outside of the cooler where it should evaporate back into the air. Sometimes "cardboard" fins are used to help the water evaporate. Sometimes a pan with a huge surface area is used to help the water evaporate. Other times the pan is literally on top of the compressor. Make sure the cooler itself is level. Make sure room air is able to move over the pan where the water is supposed to evaporate. Make sure the drain hose is not clogged. Make sure pans are not leaking.
Jun 11, 2011 | Marvel (6SBARBSG) Wine Cooler
Our kenmore wine cooler started leaking water all over the floor.
I don't know how it is leaking water, it isn't hooked up to a water supply. better start looking for the actual source of the water
Mar 23, 2011 | Kenmore 13485 Wine Cooler
It leaks water from underneath
It is not really leaking water (did you put water inside?) ... that is probably condensate ... a by product of the cooling process. Are you in a high humidity area? If yes ... that is the primary reason for this water.
Here in North America, we think that only white wine should be chilled and then only to 'celler' temp (or about 55 degrees F.
You may be able to reduce the water problem if
(1) up the temp in the cooler (it isn't a refrigerator - don't use it as one)
(2) don't put 'hot' wine inside
(3) put a small fan blowing on the cooler to help evaporate the condensate.
If the water is a big problem, sit your frig on a big tray, similar to the one you might put under your car in the garge to catch dripping oil.
I hope you find these suggestions helpful.
Thanks for visiting and please come again.
Feb 05, 2011 | Haier BC112G Wine Cooler
Will not cool to proper temp. found a puddle of water in the bottom of it.
This can be caused by a few problems, first light is staying on inside, defroster is not working, or timing has gone bad, and finally coils are dirty and need cleaned. The coils are usually underneath or on the back. Simple brush off with a small broom. When the coils are dirty they can not dissipate heat.
Jan 30, 2011 | Cuisinart CWC-1200 Wine Cooler
There is a pudle of water coming from beneath the fridge?
its condensation built up in the drain pan located underneath the frig
Feb 04, 2010 | EuroCave V256 Wine Cooler
WINE COOLER NOISE
when the fan comes on so does the compressor,hold the fan with a rag and see which one is making the noise-mike
Nov 11, 2008 | Danby Silhouette DWC512BL Wine Cooler
Water leaking out of the back
HAVE YOU CHECKED THAT THE PIPE TO THE PAN IS IN THE PROPER PLACE.ALSO CHECK IF THERE IS NO ICE ON ANY OF THE PIPES.LET ME NO IF YOU NEED FUTHER ASSISTANCE. GOODLUCK.MOHAMED
Sep 17, 2008 | Danby DWC283BLS Wine Cooler
Refrigerators Logo
Top Transtherm Refrigerators Experts
Andrew Taylor
Andrew Taylor
deton8 von Splosion
Scott Williams
Scott Williams
Are you a Transtherm Refrigerator Expert? Answer questions, earn points and help others
