Question about Canon PIXMA MP240 All-In-One InkJet Printer
Canon mp240 error code 5200, how do I clear it?
  • 34 Answers
SOURCE: canon pixma i6000d error code 5200
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
CF
Posted on Jun 28, 2009
rajak2009
  • 527 Answers
SOURCE: service error 5200 canon mp240
Sir,
Error 5200 indicated an error with the print head. Try to cleaning all contacts on the print head as well as on the connecting pad. And also the power needs to be restated, so do it and try it again, just take out the USB, the power from the wall outlet and the USB in the printer itself.
Thanks Good Luck
Posted on Sep 17, 2009
  • 1126 Answers
SOURCE: What is error code p2 for a Canon PIXMA MP240
P02 5100 Carriage encoder signal is not detected.
Carriage encoder broken / dirty.
(Encoder:The carriage is a semi-transparent plastic strip with markings behind the head from left to right is stretched by the printer. On the basis of the encoder is detected, the current head position.
Posted on Nov 29, 2009
MUKHTAR
  • 2017 Answers
SOURCE: service error 5200 for my printer Canon S200SPxhow
1. hold RESUME then press & hold POWER
2. release RESUME, then press it twice, the light should go amber then green again.
3. you're now in service mode (you can release POWER now)
for reset waste tank reset is 4 presses of the RESUME button. To confirm, press POWER once
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Posted on Mar 26, 2010
nonontech
  • 4737 Answers
SOURCE: error 5200
This error code 5200 indicates that one of the cartridges is having problem with it's print head. You need to replace it, but first you need to find which one. For best solution, we need a set of new cartridges so that there'd be no problem testing.
Let's begin like this;
Remove all the old cartridges, Turn off the printer, disconnect the all the cables including power cord and ethernet cable (if any), leave it Off for few minutes and again turn it on after connecting the power cord. Now install all the new cartridges and check if the error message is still there or not (Hope it's gone, but you need to find out the culprit from among the old ones so that you can use those that are functioning properly).
Now remove one for example yellow and install the old yellow and check the message, if it's ok, go on replacing with the corresponding old cartridges after removing the newly installed, and so and find out the cartridge which is the creating this problem. After that, you'll be able to use the other remaining old cartridges.
This might be a problem for you if you don't have a new set of cartridges, but this is the best way, you can also use old working cartridges [those with no more inks].
This will definitely fix. I would also suggest you to clean the contact points on the cartridges and on the printer properly using soft brush/cotton dipped in alcohol/acetone/spirit.
Good luck.
Thanks for using FixYa.
Posted on Jul 09, 2010
Canon troubleshooting
Hi Nolan,
Error code 5200 indicates that print head temperature error occurs. This error usually occurs in case of ink low or third party or refill ink usage.
I hope the following link will answer your question clearly. :)
Canon Printer Error 5200
Jan 11, 2014 | Office Equipment & Supplies
Service error 5200 Keep getting this message Have
Your printer might be running out of ink, if you've seen that the ink button blinks, youy need to replace your cartrudge or refill your ink.
Jul 03, 2011 | Canon PIXMA MP240 All-In-One InkJet...
Canon MP240 printer, error code P8. Can't print, can't clear error code
Possible causes
1 Wrong wiring of Indoor/Outdoor connection
2 Reverse Phase
3 Protection Device operated
4 damaged Outdoor coil thermistor
for more help visit CBR Tech Solutions
Mar 15, 2011 | Canon PIXMA MP240 All-In-One InkJet...
I kept getting service error 5200 when I tried printing something. How do I fix this problem?
Hi there
Service error code 5200 is the print head error. Rub the print head into a plain paper with rubbing alcohol until ink flows and then after that remove all the USB cable connection and power cord and plug it again. Then run the print head cleaning maintenance like print nozzle or print alignment.
It should be fine right now. Please let me know if you need more help
Mar 07, 2011 | Canon PIXMA MP240 All-In-One InkJet...
Need to know what service error code 5200 means?
the error code 5200 means:
  1. an abnormal printhead temperature, the temperaure exceed the spicified value.
  2. the solution is change the print head or the logic board.
Dec 07, 2010 | Canon PIXMA MP240 All-In-One InkJet...
Receiving error message 5200...but i have lost my original manual thanks
According to the error code, http://pixma.ulmb.com/?p=226, the error #5200 means "Print head temperature rise error".
Some of the nozzles of your printer are clogged. The print head will overheat because it does not have ink going through the nozzles to cool it. But you continued to print repeatedly, the print head may have been destroyed due to overheating.
Sep 10, 2010 | Canon PIXMA MP240 All-In-One InkJet...
What is 'error 5200" P 8 what is the solution
Hi. Error 5200 is related with the printhead overheating. In some cases, disconnecting power cable from the wall outlet and USB from the computer, then put it back in after few minites will do the trick.
If the printer still show the error after disconnecting from power and USB, you may have to bring your printer to a service center. Good luck.
Sep 03, 2010 | Canon PIXMA MP240 All-In-One InkJet...
Service error 5200 canon mp240
Sir,
Thanks Good Luck
Sep 17, 2009 | Canon PIXMA MP240 All-In-One InkJet...
Canon PIXMA MP240 All-In-One InkJet Printer Logo
259 people viewed this question
old marine
old marine
