Question about Emerson EWF2704 TV
There is no picture. Model TC1365B. Where can I purchase a tube?
  • 321 Answers
Hi,why did you want buy a picture tube?;did you break the tube by
some how,it will cost you a bundle more then buy a new tv...
for me i expect some electronic problem in the power supply or in the high voltage circuit or its may be just a fuse?!
regards alan .
Posted on Oct 05, 2010
My probleb is I have purchased be fore 13 years & noe the clour is changed and becomonig red what shall i do/ Brand Sony Model -B21L1 The problem is changed its colour in to Red I didinot...
hi,
check the base board plugged into the picture tubes neck. there may be some dry soldering. also check the video output transistor for red cathode in the same board. found faulty replace it. also check the voltage at the collector of red out put transistor it should be above 70 volt. if it is zero then picture tubes cathode is short. if so u should replace the picture tube. for any further help yo can contact through fixya.
ok
Dec 21, 2010 | Sony KV-20VM42 20 in. TV/VCR Combo
I purchased a Mitsubishi HD new in 2001 All pictures are now blue and green The red silicone cooling jell tube is no longer lit up. It looks like you can take the tubes out. Please advise if this is...
THE TUBE IS REPLACEABLE, HOWEVER YOU MUST VERIFY IT IS BAD FIRST. THERE ARE 3 OTHER PROBLEMS THAT YOU NEED TO ELIMINATE FIRST BEFORE YOU SPEND $250.00 ON A NEW TUBE.
Dec 07, 2009 | Mitsubishi VS-55707 TV
I have an Mitsubishi HD1080i series rptv, the tv is about 10 years old, yesterday as I was watching the World Series, my picture went to a pink glow and I seemed to of lost some of my color especially...
This may not be a picture tube problem, but considering the age of the unit it may be cold solder joints on or near the crt boards. Each tube has a CRT Board attached to the neck of each picture tube. Check these first for bad solder connections, in not then it may be the green tube has finally failed you. Getting tubes for this old of a unit will be very hard. IF it is the Tubes then i recommend you think about purchasing a newer set..
Nov 05, 2009 | Televison & Video
Sony Trinitron Picture Tube replacement
I think that you will find the picture tube to be more expensive than a replacement TV, if it is still available (unlikely). That being said, it is also unlikely that the tube itself is the problem, The more common problem is the horizontal output transistor or the flyback transformer. Either part should still be available for a reasonable cost. Check with a local servicer for the part numbers and costs. These are common parts.
Dan
May 19, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
JVC AV-56WP74
You would need the service manual in order to change the picture tube properly as there are dangerous voltages stored inside the tube also the tube would have to be set up properly as well. You can get the service manual for your model at the following link. They will email it too you right after purchase. Heres the link.
http://servicemanuals.vstore.ca/
May 28, 2008 | JVC AV-56WP74 56" Rear Projection...
Sony Trinitron picture tube
The correct box will be supplied for your set through the cable or satellite provider-No problem there, but what do you want with a 5 year old set other than placing bets on what will go out next? A pix tube is not cheap nor good insurance against future problems...accordianman
Feb 27, 2008 | Sony KP-57WS500 57" Rear Projection...
56" RCA HDTV Projection Model # R56WH78
This is a rear projection CRT TV (picture tubes)Not service-friendly (disassembly,getting parts)more problems compared to other brands....
Sep 12, 2007 | Televison & Video
Emerson EWF2704 TV Logo
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
