Question about Saeco Starbucks Sirena Espresso Machine
Hi, I posted a question a few weeks ago regarding my steamer. I have changed to distilled water, and that does not make a difference. My milk is being boiled, not frothed. I have used 2 thermometers to see if the temp is off, but they both were the same. How can I fix the steamer so it froths the milk again, instead of boiling it? Thanks
    President:
  • 1,618 Answers
Pure water will leach the minerals from the boiler and other hoses it is an acid.
Posted on Oct 06, 2010
  • 1 more comment
  • renslowa Oct 06, 2010
    So what can I do to fix it???
  • Ernest R
    Ernest R Oct 07, 2010
    Use filtered water, not RO or distilled.
  • renslowa Oct 07, 2010
    I really don't think it's the water that is causing the water to boil and not froth. Anything else?????
Forgot what kind of water to use - distilled or other wise can not find manual, can I get one - Model GS7RW Thanks, Susan
hi.
i am assuming it is the GS7RW garment steamer and not actually a vacuum cleaner.
any electrical item with a heating element should be used with distilled or de-ionised water.
if you live in a "hard water" area where the water contains dissolved calcuim salts, these will cause scaling and furring up of the heater element. easiest way to tell is to look inside your kettle. if there are white deposits on the base or heating element, your steamer will get the same deposits and work less effectively.
another option is to use the scented ironing waters available from many supermarkets for use in steam irons. these will not harm your steamer, and will also make your clothes smell nice as they come in a range of scents.
this link does have some instructions that may help.
http://www.conair.com/instruction_booklets/06PC2349%20gs7rw%20IB.pdf
Jun 14, 2011 | Vacuums
When trying to steam milk, very hot water comes out of the steamer arm and curdles the milks. Additionally no hot water comes out of the opening for the coffee, so no espresso is made. This started...
It seems that your problem is the one mention second that no water come out for coffee. So every time you try to make coffee the boiler is overflow and you have more water from steam tap.
So you have to clean the coffee shower on coffee group head since this might be blocked by dry coffee. Also the coffee solenoid valve could be also blocked from dry coffee and it can be removed and cleaned with a wire brush. It can be also be damage and most posible the solenoid coil burn out so you might need a new solenoid. So I beleive if you solve the coffee group blocked problem then you might have solve also the steam problem,
Good Luck
Remeber to vote for this answer.
Feb 23, 2010 | Krups Cappuccino/Espresso Maker -...
Hi - our Via Venezia has been a GREAT machine, and we love it, but over the past three weeks or so it seems the steamer arm is letting water through and the milk is getting watery. Can we replace that...
Hi
Your water is not getting hot enough to turn the water into great steam so you get more water in your milk. Have you ever descaled your machine?
Nov 22, 2009 | Saeco VIA Venezia
Is there a product to run through a rowenta pro garment steamer to eliminate build-up?
To start with, use distilled water for steaming. This will prevent calcium build-up. I buy bottles of distilled water for ironing/steaming only. I have never had calcium build-up from using distilled water for ironing/steaming. Do not use tap water!!!
You can buy some CLR (stands for Cacium, Lime & Rust) (can be found at Walgreens, CVS, Target, Walmart, etc.). You can run this product through your steamer to eliminate build-up.
May 14, 2009 | Rowenta Commercial Garment Steamer - White
What kind of water does this steamer use-spring, distilled or tap?
it is best for your device to use distilled or at least once boiled water. if you do so you will avoid filling with calcium and the life of your machine will be longer.
Mar 29, 2009 | Conair Compact Garment Steamer Iron
Milk froths at 1st then doesn't after 1 week
Ensure first that you are using the steam pipe in the correct way to froth the milk.
If it still does not work, that means that the steamer is not generating enough pressure steam.
This happens either because there is not enough heat, or if you release the steam when pressure is not enough.
If you think you are doing everything in the right way, then contact the company and insist for having the machine fixed or replaced.
Nov 07, 2008 | Krups XP 1500 Espresso Machine & Coffee...
STEAMER NOT WORKING - Hi my francis coffee machine is having problems with steaming.  Everything else works apart from getting steam/froth.  I have descaled it lots but still not working.  What can I do?
Hi again, I looked at some other posts on this site and tried soaking the steam wand in a cup of boiling water with a cap of vinegar in it.   I left it about 20 minutes and it worked very well.   My problem was just that the wand was blocked with dried milk on the inside.  I'll make sure to run water through after steaming milk in future .....
Aug 06, 2008 | FrancisFrancis! X1 - Stainless Steel...
New Rancilio Silva - steamed milk not perfect
please relay on your experience realizing that you now have new steam pipe(with different holes in the end of it and different pressure)
you will need to get use to them and get maximum quality of that steam pipe.
my advice:
  1. every time hold your hand in the bottom of milk container, so that you will prevent overheating which often gives the result you mentioned.
  2. every time you use cold milk.
Jul 22, 2008 | Rancilio Silvia Espresso Machine
Krups FND1 water escape
What position do you have the knob in? According to your manul it should be in position 9 not in position 8 for steaming.Good Luck.
Apr 11, 2008 | Coffee Makers & Espresso Machines
Saeco Starbucks Sirena Espresso Machine Logo
101 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
