Question about HP PL4245N 42 in. HD-Ready Plasma Television
Power on problem
Two leds will turn on then after a second one will turn off. i can here relays clicking when the leds turn on and off.. seems like the power board is waiting for a signal it never gets - then it goes into standby. I dont think its the power boards. Any suggestions?
  • 2 more comments
  • Robert S.
    Robert S. May 28, 2008
    The set is not under warranty unfortunately. I did notice that two 250V, 1000uF caps were bulging (maybe failed and outgassing - although I don't measure a short) and two other caps 450V 330uF looking a little bulging too. I plan to replace the two 1000uF caps - do you think this will help? I've disconnected all other boards except one; the system seems to want this one connected in order to turn on any LEDs. The power board is what I'm suspecting but it would be nice to get a schematic, any ideas on where to get a schematic?
  • Robert S.
    Robert S. Jun 12, 2008
    Replaced the capacitors with no luck. Measured the parts I replaced and they were within spec. Any other suggestions? I read somewhere that the Y-main board may cause this problem i.e. even if I replace the power supply it may not be the solution. Any way to fake out the power supply to make it turn on? FYI the board is actually made by MAXENT (LJ44-00068A).
  • Robert S.
    Robert S. Jul 19, 2008
    I found one bad relay by applying 5V dc to the coil and measuring the contact as open, and one bad 6.8 ohm 7W resistor - both on the input AC circuitry. I replaced both and now I have a fully functional plasma tv! :) Total cost for tv: $12. Thank you FixYa, especially Abrsvcs.
  • kjlegend Feb 06, 2009
    I have an HP 50 inch plasma that is doing the exact same thing. Can you post some pics or email them to me at kjsnowboarder_18@hotmail.com rrobert4??? On what you did...
    I have replaced the Ysus board with no luck...
  • 4,234 Answers
A problemm is being deteced during the startup process. To prevent further damage, the set is shutdown. What you are seeing is repeated attempts to startup the set. If the set is less than 1 year old, it should still be under warranty. Call for warranty service.
Dan
Posted on May 28, 2008
  • ABRsvcs May 28, 2008
    Replace the 330uF caps too. This may work, but there is no guarantee. These units are board replacement only at most authorized service centers. Schematics are not available. Try the caps and report back with the results.
    Dan
  • ABRsvcs Jun 12, 2008
    Depending upon how the caps are measured, you will feel that they are OK. If they have bulged at all, they will fail under load. Look around for caps on the same line. These caps are filter caps and there will be others further along. Check also for Zener diodes that are out of spec or even general rectifier diodes. It is difficult to diagnose this remotely. Look around and check also for low valued resistors that may have opened up or changed value significantly.
    Dan
Samsung PN50C590G4F plasma TV turning on and then off with clicking sound after 6 seconds
Have you tried replacing the power cord or the voltage feed may be off replacing the whole cord should correct that
Jan 02, 2015 | Samsung PN50C590 TV
Samsung led tv troubleshooting guide
i have 65 inch samsung tv LED UA65D8000XN if you plag in red light on if you tuch power ON was blinking then the blinking it will stop but the tv will not turn ON the tv no display no picture relay click about once per second but the tv will not turn on thanks for any solution
Aug 22, 2012 | Televison & Video
No picture on my philips 42PF7321D/37
Bad caps in the power supply must be replaced .
Jul 21, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Startup Problem with my 42pf7321d/37 Phillips plasma TV
I need to know how long do you have the tv?In the other word,approx. how many hours you have put into it?
Secondly,did you wall mounted the tv or setting it close the the area which there is not much room for the back of your tv to breath?
solutiondoct
Nov 06, 2008 | Televison & Video
42PF9956/37 SHUTSDOWN...
Ok. I got my tv back on.
I pulled off the back cover and found the relay that was clicking.
I have two blue relays next to each other that click when the power is pushed.
I placed a hair dryer over the relays for about a minute.
Once heated up, it only took 4 tries to get the TV to stay on.
Jan 03, 2008 | Philips 42PF9956 42 in. HD-Ready Plasma...
HP PL4245N 42 in. HD-Ready Plasma Television Logo
764 people viewed this question
Top HP Televison & Video Experts
Tony
Computer Links
Alun Cox
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
