Question about Dryers
The dryer gets hot and comes on but the tub do not spin around
  • Dryers Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley or a faulty motor.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place.
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the screws that hold the filter housing.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please rate me
Posted on Oct 05, 2010
My dryer comes on and spins, heat comes on but clothes do not dry. I took the front panel off, it fires up but it doesnt get hot in the the drum.
Try checking the blower wheel just behind the front panel and see if it's loose or if you spin it without the tub moving, the blower wheel is probably stripped or you have no air flow. Take the vent off the back off unit see if you have air flow there. Remove all excess lint you see anywhere
Oct 28, 2013 | General Electric DHDSR46EGWW Dryer
How do you replace the drive belt in a kenmore dryer model 88042
Pull the fron off. Remove tub, should have a spring loaded idler pulley next to the motor. Make sure that it is not broke and spins freely. Also check tub support rolers on each side. They shoule spin freely. If ok, put belt around tub, install tu. Put belt around spring loaded pulley. May need a hand holding tub while you install pulley. Put front on. Make sure the fron of cover fits inside the tub seal. Good luck. email me with issues, bobby.crochet@lyondellbasell,com.
May 14, 2011 | Kenmore Dryers
Dryer tub doesn't spin - motor runs and hot air comes into the tub area but the tub itself has quit spinning. Could this be the belt since the motor is running and the dryer is heating up? This is an...
Unfortunately you will have to search for thebelt with auto stores to see if any of the models will match. Check to see if any machine spares shops can help, get intouch with industriaal spares outlets to help you.
Sep 23, 2010 | Amana DLE330RAW Electric Dryer
Dryer is hot, but it doesnt spin
the belt that goes around the tub may be broken or off trac.
Jan 12, 2010 | Washing Machines
DRYER GETS HOT BUT TUB WONT MOVE
BELT IS ON CORRECT?MOTOR IS WORKING CORRECT?CHECK THE 2 IF THERE BOTH WORKING CHECK THE START BUTTON FOR CONTINUITY THOSE R THE ONLY THINGS INVOLVED WITH TUB SPINNING
Aug 18, 2009 | Dryers
How do I open the dryer to get to the area around the tub
I hope this works for U
http://repair2000.com/dryer.html
Was this helpful?
May 13, 2009 | Maytag Dryers
Dryer gets hot spins takes several cycles to dry fully
ahhh very common, clean clean clean inside the dryer, take the lint screen put some toliet bowl cleaner on it let it sit while you are tearing the dryer apart and clean the whole dryer vent and or change it, make sure the flap outside is not stuck shut as well...
May 08, 2009 | Dryers
Can't get replacement parts back on Kenmore 60 series dryer.
The belt has groves, right? Make sure the groves go over the motor pulley from the right. The idler pulley is spring loaded. Place the belt around the idling pulley with the smooth side of the belt on the pulley. This should work.
Dec 24, 2008 | Kenmore 62602 Electric Dryer
Dryer Gets Hot..But doesnt Spin
I don't know what kind of dryer you have, top or front loading, but it top loading it most likely is the belt that goes from the motor & wraps around the drum.
joel
Dec 21, 2007 | Malber TD700 Electric Dryer
Groaning sounds when dryer spins
yes it is, its the rear tub bearing. pain in the butt to change but that will solve it
Nov 20, 2007 | Bosch Axxis WTL 5410 Electric Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
