Question about Panasonic Televison & Video
Tv picture gets fuzzy....like someone is using a blender
    President:
  • 4,402 Answers
Fuzzy picture...started when first turned on tv,after a few minutes picture be came clear.tv now is fuzzy all the time.model #50vx915 ser.#v4k000487
TV seems dusty inside, please clean optical lens, rear mirror and front screen of TV to get better picture, need to take off back of TV to clean it inside.
Thanks.
Mar 30, 2011 | Hitachi Televison & Video
Just bought the Samsung 550 Plasma Hd Tv can you tell me if we just use a regular cable from the wall to the Tv will the picture quality be sort of off.. WE have an HM MI cable from the cable box to the TV...
unfortunately cable does not give you the best quality picture and "fuzziness ' is the reduced resolution being displayed on the tv.
the easy way to check the picture quality is to get a decent hd antenna and scan using it for free hdtv signals, if these are also fuzzy, on all channels then the tv has a problem but if it is only on a few lower resolution channels then its just the way it is until everyone is hd 720 or better.
Jan 31, 2010 | Samsung 50 in. Plasma TV
I have a Sharp 32" Standard TV ... picture will get fuzzy either due to someone walking by or sometimes if sound coming from tv is vibrating. If we shut tv off and turn it back on it is clear again. The...
Hello: Your problem seems to be in or around the tuner of the television, More then likely you have cold solder joints on the turner that needs to be resoldered. Also check the coax end protruding from the back of the set where u connect the cable and make sure it is not loose, a bad ground on this connector to the turner shield will cause this symptom. My professional diagnostic is that when the television is cold the solder connections are making contact with the board, and as heat builds up in the television while watching these connections tend to seperate and make limited contact, causing fuzzy picture and in most cases no picture just snow...
Sep 06, 2009 | Sharp 32C-240 32" TV
Can hear sound and see picture but it is all fuzzy
u need to reset the screen options back to regular spec if its not a 1080 p tv if its a regular tv you will need to use the 1080 p tv to fix it before you can use it on any tv
May 22, 2009 | Sony Playstation 3 (PS3) Console
Has fuzzy spots all the way across the screen and just scrolls up
Is the picture fuzzy whether you are waching tv or a dvd or a tape. If it's only fuzzy on tv or dvd or tape then it's the source. If all inputs are fuzzy suspect a bad tv.
Apr 04, 2009 | LG 42LC2D 42 in. LCD HDTV
Fuzzy Picture
Fuzzy is a funny word. I never use it to describe a picture problem. That because fuzzy can go too many different ways. There is snowy fuzzy, blurry fuzzy, grainy fuzzy, and demodulated fuzzy. If the set goes out of focus intermittently that has something to do with the focus ciruitry. If it goes grainy that is a front end problem, usually tuner related. The other types of fuzzy are generally associated with problems in video processing some where. So, which is it?
Oh, and BTW that unit has three small picture tubes in it, one red, one blue, and one green. It doesn't have a 'bulb'.
Feb 24, 2009 | Mitsubishi WS-65869 65" Rear Projection...
No picture/intermitten picture
I just got through explaining this to someone else - the HDCP encryption system that Philips uses is not future-proof - you will continue to have this problem as long as you use an HDMI connection with a Philips TV. My advice, which you can take or leave, is to use Component (Red, Green and Blue) cables. you won't get 1080p, but you will get 1080i, which is pretty close.
-Tha Mp3 Doctor
Jan 16, 2009 | Philips 52 In. LCD HDTV
My t.v screen is fuzzy and the picture is showing double on one side and it at times seem s streched
The stretching might be due to having the wrong aspect size on your tv. Look on your remote and see if you have a button that says "Aspect" or it could say "ratio" or something to that effect. You can cycle through the different screen sizes to make it not appear to be stretched. As far as your picture being fuzzy, if you are using a standard antenna that may be the cause. If you are using cable, I would contact the cable company and have someone come out and check your signal strength, and possible inquire if you need a cable booster added. If you are running cable through a cable box and are running it straight coaxle then I would recommend trying a different hookup method, e.g Red, white yellow cables, or S-video or even hdmi, whichever your cable/satellite box and tv allows.
Dec 15, 2008 | Panasonic TH-37PA20U/P 37 in. Plasma...
Sanyo DS27880
use your remote and try to auto program your tv. if no effect, theres a problem of your tv tuner.
Aug 04, 2008 | Sanyo DS27820 27" TV
Tv F27442
The TV does not have a reset button. If you have no picture and no sound, there is something wrong with the chassis. In this case the set should be serviced by someone experienced in the RCA CTC203 chassis. If you have no picture but do have sound, then it is possible that the 2 controls in the 2 little holes in the back of the set are not adjusted correctly. This is quite possible since you said you put a screwdriver in there and got a fuzzy picture. The control on the bottom is called "screen" and is the overall brightness of the picture and the control on top is called "focus" and is the sharpness of the picture.
May 20, 2007 | RCA F27442 27" TV
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
