Question about ASUS P7H55M PRO (90MIBBB0G0EAY0KZ) Motherboard
Worked perfectly until I put PC into storage for 5 week's holiday. Now no video. Upon switching it on, after short delay I hear a long pip followed by two shorter ones, and later, the normal startup pip. The HDD seems to be working as it seems to go into Windows startup mode, but my screen just says "No signal". I have tested the screen and cable on another machine - OK. I have repeatedly checked the plugs. I have attempted to bypass the video card by plugging into the motherboard video outlet. I have checked that the video card has not become dislodged. Any suggestions? Thanks
    Brigadier General:
  • 10,406 Answers
Disconnect the AC power.
Physically remove the "add-on" video-card,
to force the motherboard to use the "integrated' video-card.
Connect the AC power,
and boot to see if any video is displayed.
Temporarily disconnect the power-cables and data-cables
from the disk-drive, and the CD-drive.
Remove any other "add-in" cards (sound? TV tuner? network?)
If there's more than one stick of RAM, reduce it to one stick.
and boot to see if any video is displayed in this "bare-bones" configuration.
Try the add-in video-card in another computer, just to confirm that it still works.
Posted on Oct 05, 2010
The control panal on my weslo cadence treadmill is not working
Do the following :
1) Lube the deck belt follow the instruction manual, maybe the deck is worn.
2) Lube the roller bearing.
3) Align the deck belt.
4) Test the drive bel.
5) Test the input voltage motor, if there are the motor need repair.
6) Test the output voltage board, for input voltage motor, if there are not The board is faulyt.
7) Run the software calibration for diagose, troubleshooting, and fix it, follow the steps from instruction manual.
8) Adjust the Reed switch, clean, and tight the connector very well.
sincerely. God bless you.
May 06, 2012 | Exercise & Fitness
Refrigerator was bought 5yrs ago(brand new)it worked perfectly until then....put it in storage 4 six months...when i moved it into my house i plugged it up...can hear it on but yet to get cold....left it...
Hi
Is your fridge compressor motor working and can you hear it turn on and off every hour or so. Not to be confused with the sound coming from the fan inside the fridge.
If the motor is working but neither the fridge or freezer compartment are getting cold, then there may have been a rupture during transport and gas has escaped.
Ash
Sep 02, 2011 | Hotpoint Refrigerators
Hi there, So, my problem is the following: My pc worked well until i changed my cpu cooler, it didint turn on, i hear only two short bips after i pushed the turn on button (during this the leds are...
Sounds like the CPU may not be seated properly, did you remove the processor when you replaced the cooler (Heatsync I assume you mean)?
Try powering down and unplugging. removing the heat sync removing the processor. Re-seating the processor making sure it falls into place. then re add the thermal paste(if needed) and heat sync. Check the memory and video card to make sure they are firmly in and then power back on and see if it will boot.
Another thing you can do is check your motherboards manual or website and there is a description of "beep codes" that you can listen for yours and see exactly what its telling you is wrong.
Good luck
Jan 24, 2011 | Gigabyte Core 2 Quad Intel X48 FSB 1600...
3 medium beeps on pc; repeating
Hi John. If you already swaped the Memory, it's the video card. I'm giving you what the beep means according to the different types of BIOS, because basically Ascent is a clone PC. I hope it helps.
(you will have to open the computer to see the BIOS type.)
BIOS AWARD
1 long beep and 2 shorts -- Video error
2 short beeps -- non-fatal error.
1 beep corto -- OK.
BIOS AMI
1 short beep -- Memory error.
2 short beeps -- ECC error.
3 short beeps -- Memory error.
4 short beeps -- change atery
5 beeps cortos -- bad processor.
6 beeps cortos -- bad keyboard.
7 beeps cortos -- video memory bad.
8 beeps cortos -- video bad.
BIOS PHOENIX
1-1-2 beeps -- Problem with cpu/motherboard.
1-1-3 beeps -- Cmos issue.
3-4-1 beeps -- Video issue.
BIOS IBM
1 short beep -- Post normal, ok!.
2 short beeps -- POST error, will show on screen.
NO beep -- CPU issue or Expansion card issue
1 long and 1 short -- motherboard error.
1 long and 2 shorts -- Video issue.
1 long and 3 shorts --EGA video issue.
3 longs -- Keyboard error.
Apr 29, 2010 | Systemax Ascent Pro A20 (988185) PC...
Mitsubishi CS-35301 has a rolling screen. Need to access service menu.
you need replace capacitors in vert.output circ. Not a service menu.
Jan 28, 2010 | Televison & Video
No audio output - Marantz 2238
This can be as simple as a poor connection somwhere in the voltage regulator circuit or a defective driver transistor or output transistor. In any case, this is a simple repair for any shop that works on vintage receivers. If it is the outputs, that will be the most expensive repair from a parts perspective. The outputs will cost in the $5-$10 range for each one and it could be 2-4 pieces. If you wish to attempt this repair yourself, you will need a multimeter that has a diode checker. Let me know and I'll provide additional details and instructions.
Dan
Apr 06, 2009 | Marantz Audio Players & Recorders
Microphone fuzzyness
control panel, mic, adjust background settings, this should do it.........if not let me know
Nov 24, 2008 | Computers & Internet
Mitsubishi television
1. NO VIDEO, BUT HAS VIDEO WITH PIP ON. CHECK C763 (1UF 50V) ON THE BASE OF Q715, LOCATED ON THE UCOM-PCB. 2. NO MAIN VIDEO, THERE IS VIDEO IN PIP ON EXT1 AND EXT2:-CHECK FOR 1VPP OF LUMINANCE ON PIN 1 OF IC7000, IF MISSING OR LOW CHECK THE VALUE OF C7001 (4.7UF 35V), LOCATED ON THE PIP-PCB. THIS CAP MAY LEAK ELECTROLYTE ONTO THE BOARD AND OPENED A FEED THROUGH IN THE PATH BETWEEN C7001 POSITIVE LEAD AND THE EMITTER OF Q7003 OR CAUSE INTERMITTENT COLOR. PART # 181P504090. (CHECK ALL 'SMD' ELECTROLYTICS AND TRACES ON PIP) 3. NO MAIN OR PIP VIDEO, CHECK C7014, 47 UFD 16V ON THE PIP PCB. PART # 181P502060 4. CHECK FOR 7.2V DC ON THE BASE OF Q7003, IF LOW OR MISSING. CHECK THE VALUE OF R7002 (150 OHM 1/10W).LOCATED ON THE PIP-PWB. PART # 103P401050 5. SUSPECT R2045/R2048 (6.8 OHM 3W) FOR OPEN/RAISED VALUE. LOCATED ON PCB-SIGNAL AT 5V REGULATOR IC2003 PIN 5.
Nov 21, 2007 | Mitsubishi VS-60611 60" Rear Projection...
No picture, just grey dots
try contacting xbox they'll know what to do
Sep 04, 2007 | Microsoft Xbox 360 Console
ASUS P7H55M PRO (90MIBBB0G0EAY0KZ) Motherboard Logo
104 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
