Question about Performance Teknique ICBM-771 Car Audio Amplifier
Diagnostic light comes on only
Bridged powering 4 10in subs
was playing with nop roblem now its just showing a red light
all the fuses and connections are good
i think the amp has a internal problem
got any suggestions
    Problem Solver:
  • 8 Answers
Probably a short in the circuitry. I would try and check all my wiring to speakers for shorts. If you still cannot get the unit to come up you will probably need to get the AMP serviced unless your pretty good with a meter.
Posted on May 29, 2008
Nop is showing in the display after connecting the ST connections
Nop = No operations
Provide signal to enable input (ST).
Apr 01, 2014 | Inverter KEB COMBIVERT F5
My jl 500/1 it comes on but it dont push my subs it dont hit at all the power light comes on
number one did you install the subs youreself..it could be you have a double coil not installed right for full potential connect red to red and black to black on the back of youre spkr but if its a regular coil dont worrie about it ,,and also set amp to low pass and also bridge it so it would reach full potential .
Feb 22, 2010 | Jl Audio 500/1 Car Audio Amplifier
I need help installing a 4 Channel Power Acoustik Amplifier to Two Pioneer Subwoofers. I hooked up the power wire to the positive battery terminal in the engine compartment. I then cut the power wire and...
You are doing right on what you described. I really like to work with a clearly described what involved in an issue.
Now we have to use a Voltmeter to check if there is power to the amplifier. If there is power to the amplifier terminal, then the problem is at the amplifier, not the connection. Let check it out:
1- Turn on your Kenwood radio, make sure to hear sound from your regular speakers.
2- Turn remote control knob to the mid level between min and max.
3- Measure the blue wire where you spliced to ground to see if you have 12V, if it is not then the problem is right there.
4- Measure the Red wire power from the Amplifier to ground ( the bolt that you connect the negative power to see if there is 12V, if not trace back to the Fuse that you inserted between the positive terminal of the battery and the wire going through the firewall to correct it.
5- If you have 12V at step 3 and 4, then you have a defect unit, return it to the manufacturer for a replacement.
Sep 06, 2009 | Car Audio & Video
Red thermal light on
well id say you have cooked your amp and or subs they can only take beatings for so long. show it no mercy it gives it back,does amp smell do subs smell borrow amp see if subs are ok if so it will be your amp.new one .keep the gain down??
Jun 11, 2009 | Rockford Fosgate Punch P550.2 2-Channel...
Two terminals? bridging theory?
Hello again jm129852,
Having two power and ground terminals allows you to run two smaller wires instead of one big one. It's a convenience. No, you do not have to use them both. They are connected together inside. Yes, you should still use a single fused battery lead. Connect the big wire and fuse holder to the battery and to a distribution block and run the smaller wires from the output side of the distribution block.
When you connect the outputs of a two channel amp to two separate speakers, each speaker gets the power produced by it's channel only. If you are using only one speaker, and the amp is rated to operate bridged, then the speaker will receive the power from both channels, typically twice as much. You do need to be careful when using bridged mode because many amps will only operate safely at a higher impedance when bridged. For example, when operated with both channels connected to separate speakers (not bridged), it may be stable to 2 ohms. But when you connect both channels together (bridged), it is only stable to 4 ohms. Usually, the specifications will tell you the lowest impedance at which the amp should be operated. The specifications for the current RF Punch 500.2 are like this: 125 watts X 2 at 4 ohms; 250 watts X 2 at 2 ohms; 500 watts X 1 bridged at 4 ohms (4 ohm stable in bridged mode). You would NOT want to connect two 4 ohm subs in parallel to this amp in bridged mode. It would result in a final 2 ohm load and the amp would overheat and fail. One 4 ohm sub would be OK, and it would receive the full 500 watts as stated in the specifications. You could connect four 4 ohm subs, two each in parallel to each channel, and the 2 ohm loads on each channel would be OK. Or you could series two of them together for an 8 ohm load, do the same with the other two, and then parallel the two 8 ohm loads for a final impedance of 4 ohms and connect them into the bridged terminals. With DVC subs the connection possibilities get more complex. There are many good impedance calculators online that can help you determine the best wiring solution for various amp/sub combinations. I like the one above at the12v.com web site. Rockford-Fosgate also has one which allow you to select the a number of subs (up to 4), their voice coil configuration (single or dual), and the voice coil impedance. The RF calculator then shows you what configurations are available and what your final load impedance will be.
Hope this helps.
Apr 28, 2009 | Rockford Fosgate Punch 800a2 Car Audio...
Power
Have you checked the on-board fuses?
Did you confirm (with a multimeter) that you have voltage on the B+ and remote terminals of the amplifier?
Did you have the black meter lead on the ground terminal of the amp when you checked the voltage?
Jul 18, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Power protector light on sony xplode 1000 watt amp
a green light is the power indicator, a red light is when the protector is in affect
May 30, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
PB1500 no diag. lights - Power - OK
I don't know how you checked the fuses but if you didn't use an ohm meter, you need to confirm that you have B+ and remote at the amplifier.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage is sufficient at the remote and B+ terminals, the switching power supply has probably failed in the amplifier.
Dec 20, 2007 | Pyramid PB1500 Car Audio Amplifier
Not producing sound
It sounds like the power supply may have failed. I'm not familiar with that particular Boss amp but many amplifiers will light the power indicator even though the amp isn't operating.
Have you checked your speakers to see if they're blown?
Have you checked the wiring to make sure the speakers are still connected to the amp?
Dec 19, 2007 | Car Audio & Video
Amplifier problems!!!
it sounds like your running your ohms to low, check to see what the amp can power and then read up online about ohms and your subs and how they should be wired
Oct 12, 2007 | Car Audio & Video
Performance Teknique ICBM-771 Car Audio Amplifier Logo
206 people viewed this question
Top Performance Teknique Car Audio & Video Experts
hoyzee1
Jose Velazquez
Jose Velazquez
George Nalley
Level 1 Expert
Are you a Performance Teknique Car Audio and Video Expert? Answer questions, earn points and help others
