Question about Western Digital Computers & Internet
My computer recently stopped recognizing my Western Digital external hard drive. I tried everything and nothing seemed to work so I figured it was the ciruit board. I removed the hard drive and opened up my computer to try and install it internally so I could save my data. I hooked it up via SATA, but I had to unhook my CD-ROM to make this possible. After adding hardware it gives me a code 31 saying the driver software can't be loaded so of course I can't use the drive. (My OS is Vista 32-bit) So I tried restarting my computer and now it won't restart, it just freezes or takes me to startup repair. I am wondering if having to unplug the CD-ROM had something to do with this? Any help would be appreciated. Thanks
  • lawmanlucas Oct 11, 2010
    Thanks Crankstart for advice, unfortunately it didn't seem to work. My drive did not show up in disk management. I don't know an awful lot about computers so I really don't know of anything else to try. I ordered a new enclosure, hopefully that will cure my problems.
  • 696 Answers
Unplugging the CDROM didn't cause this issue but installing the western digital on that cable did cause your drive numbers to change in BIOS. You need to disconnect the external hard drive from the SATA cable but leave the power connected,then boot windows. Once booted reconnect the SATA cable. Check and see if it shows up in your disk management utility.
To do this, right click on computer, then left click manage. When the management console opens, click Disk Management on the left side and scroll down through your drives. Let me know if it shows up and what it says about the partition on the right, I'll keep my eyes open for your reply.
Chris
Posted on Oct 10, 2010
  • Chris
    Chris Oct 11, 2010
    Thanks for the update. Being the drive doesn't show up in disk management it seems likely the circuit board or PCB has failed, not just the enclosure. This is generally something I would recommend sending to a pro if your files are of any significance. If the files are just personal files you wouldn't bother paying much to get back, you can try D-I-Y recovery methods, I've recently written an article for Armor-IT Data Recovery that could help you if you want to try this yourself go tohttp://www.aitsavemyfiles.com/datarecove...
Using Western Digital Hard Drive as External Hard Drive Problems
OK! First of all try to disconnect all usb's from neighbouring usb ports as they might be using up too much current resulting in your HD not having enough power to be powered up properly! Also, try to use a different usb port.
If all these fail, please use a voltmeter (if any available...) to check if your devices actually function...
Hope this helps! If not, please report back!
Mar 29, 2014 | Western Digital Computers & Internet
Device is not recognized
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked. I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Jun 22, 2010 | Western Digital Passport WDXMS2500TN 250...
External hard drive isn't recognized!
try pluging it into a different usb port try a different cable if they all do not work then the partision table has been damaged and the drive will have to be reformatted
Dec 06, 2009 | Western Digital (WD3200JS) 320 GB Hard...
Computer will not recognize one 500 external hard drive- nothing wrong with connections- other external hard drives are fine. I have tried everything
What OS are u working on? some old ones dont recognize this big hard drives, cant remmember the limit but it was around 300. Try updating ur OS if u are working on windows xp(get it to Service pack 3). I think this problem was fixed at sp2, but just to be sure.
Nov 02, 2009 | Western Digital 500GB My Book World...
External hard drive not recognized
You need to first narrow down the problem to either your PC or the external hard drive. Do you have access to any other PCs you could try connecting your hard drive to? (think friends, family, public PCs, etc)
If the hard drive works on other PCs, we know it isn't a problem with the hard drive.
If it turns out that the hard drive is fine and the PC is the problem, I would suggest going in to Device Manager and uninstalling everything USB related. Once you have done this, either reboot your PC or right-click inside device manager and "scan for new hardware". All of your USB related devices should reload their drivers automatically. You may want to try this both with and without the usb drive connected.
Another tip would be to try various USB ports.
Mar 19, 2009 | Western Digital 500GB My Book World...
Does not recognize
Did you try the disk on a different computer to make sure the disk is functioning?
And if using a laptop, make sure that power is not an issue, an external power supply or 2 USB ports are always required.
Also check:
http://www.devicedriverfinder.com/blog/device-errors/external-hard-drive-troubleshooting
Maybe one of those troubleshooting suggestions can help you.
Jules
Mar 16, 2009 | Western Digital External USB 2.0 80 GB...
Western Digital hard drive problem
Ok.  I have a WD 500 and I have ran into similar problems.  First, shut your computer down.  Unplug the hard drives USB cable and the power cable.  Wait for about 2 minutes.  Plug the USB cable into the computer, plug the power cord in...wait for 30-45 seconds and then start your computer.  That hopefully should solve your issues.
Mar 01, 2009 | Western Digital My Book Essential Edition...
120 gig Western Digital black no longer mounts on LEOPARD osx 10.5 grrrr
i have the same problem.
macbook doesn't see anymore my hdd western digital 2,5'' white 250 GB.
tried disk warrior, disk utility but nothing.
it's just seem disappeared, even if i hear it works inside (and the led light is on)
what can i do?
May 10, 2008 | Western Digital Passport WDXML800UE...
My hard drive just stopped working all of a sudden
Search around on this site for MyBook 500GB problems. I've responded to a couple, but it amazes me that lots of people, including myself, has a failed unit. Mine lasted 1.5 yrs and failure is caused by burned chip pins on the drive controller. Seems likely to be a heat issue. More info about what I did; see my other posts.
Feb 18, 2008 | Western Digital 500GB My Book Pro-External...
Computers & Internet Logo
179 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
