Tv shuts off after 2 seconds of being turned on.
  • Gatordad Jul 23, 2008
    my hd dlp tv shuts off after a while then, tries to come back on and makes all kinds of noises and after about 10 minutes it comes back on but takes another 2 or 3 minutes for the color to straighten up.
    President:
  • 4,402 Answers
Posted on May 28, 2008
Tv shut down about 2 seconds after it turn on
Short circuit protection. The power supply regulator section to your TV is working properly, but after the power supply starts on, it detects a short circuit, by any of the main board section circuit. Your TV need a thorough checkup. Contact any service technician. This is not a user repairable fault. If you wish to get some details, check the site linked here. Pull up older posts.
Dec 06, 2013 | Sharp 19R-M100 19" TV
Code number to program my bell remote to this tv
01768,11034,11265, 10178, and 11748.
Or you can:
1. Press "TV" button
2. Hold "P" (program button) till the "TV" button flashes once then twice
3. Enter 9 9 1, and the "TV" should flash twice
4. Aim the remote at the TV and hold the Power button down for at least 3 seconds. (Remote automatically goes to first code but it probably wont work so go on to step 5)
5. Press CH+ repeatedly till the TV shuts off and stop immediately!
6. Hold "P" for 2 seconds
7. Hold "Select" for 2 seconds
8. Hold "P" for 2 seconds
9. Hold Power for 2 seconds and TV should turn back on
Found at:http://wiki.answers.com/Q/What_is_the_universal_remote_code_for_a_haier_tv
Be sure to rate macapplezoo 100% or whatever you think I deserve!
May 29, 2011 | Haier HL32D1 32 in. TV
Hi. My sony KDF-E50A10 will turn on for about 30 seconds, then the picture and sound go off, the standby/power light flashes 49 times green and the set turns back on. After 30 seconds, the same thing...
tv works for about 2 minutes, then shuts itself off. the red standby light flashes 50 times, then the tv. comes back on for approximetly 2 minutes then goes off again, only to repeat again
Sep 28, 2009 | Sony KDF-E50A10 TV
TV won't stay on for more than 2 seconds
TV turns on for 2 seconds then shuts off. Sleep/timer blinks. Won't go back on unless unplugged and plugged back in
Nov 16, 2008 | Televison & Video
My emerson tv is turning it self off
my tv shuts off after a few seconds what can i do to fix it
Sep 12, 2008 | Emerson EWL20D6 Television
Vs-50609
Good Day, checho3435;
Look for fluid on the PCB's or check these items:
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source). Good Luck, big IRISH>
Jul 30, 2008 | Mitsubishi WS-55807 TV
Brief power on then shuts off
It could be a component short or crack on the power supply board. Open the back of the TV and look for signs of defect. The power supply board is the brown one on the right with huge capacitors.
Jul 12, 2008 | Panasonic PT-61HX41 61" Rear Projection...
Mitsubishi turns on for 3 seconds then shuts off..after power surge
try holding in the menu and input buttons together on the front panel for about 8 seconds to see if the self diagnosis feature will blink a two digt code then let me know what happens
Jun 05, 2008 | Mitsubishi WS-55411 55" Rear Projection...
Turning on for 2 seconds then shutting off
thats the protection circuit. it detects that the low and or high voltage is not correct and shuts down.
you need a tech .
Sep 04, 2007 | Mitsubishi WS-55315 55" Rear Projection...
Projection TV keeps shutting down
I just took my Mitsubishi WS-65315 65" in to be repaired for the same problem and was told that it needed a new main circuit board part number 930b899005 as was told they wanted to charge me $1100.00. So I told them not to do the repair and picked up my tv and found that same part at Sears parts for only $225.00. Some of these TV repair places are theifs.
May 10, 2007 | Mitsubishi WS-48315 48" Rear Projection...
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
