Question about 2wire Computers & Internet
After working for months with our att uverse system, my Dell netbook can no longer connect and I get the message "problem with wireless adaptor or access point". Other computers work on the network and this same netbook connects fine via wireless at work and other places. I have recycled power and reset systems, etc. What should I try next?
    Novelist:
  • 108 Answers
This is basically an issue with the settings on wireless. Feature incompatibility is what i ll say. Your 2wire access point will be broadcasting a mixed wireless signal. Open the access point interface on a web browser by typing: http://192.168.1.254
Go to the WIRELESS settings section.
Change the SSID to whatever you want (It should be 1 word with no spaces).
Change the wireless mode to 802.11g only.
Change the wireless channel to 1, 6 or 11 (any of these).
Finally, it would be preferred if you set your wireless security mode or type as "64-bit WEP" and the key1 can be set as your phone no. because it has to be 10 numbers.
Now if your access point is WPS (Wi-Fi Protected Setup) enabled, you can disable that feature.
Even if these steps do not work, you must take a back-up of the settings and upgrade the firmware version or re-flash the same version of firmware and restore to factory defaults and then later if it cannot be configured back by you, you can simply restore the saved the settings.
For further clarifications, please revert! Good question. Even we technicians encounter it.
Thanks for asking.
Regards,
Arvind S Iyer
Posted on Oct 05, 2010
  • beclu727 Mar 12, 2011
    This worked for us, but had to specify channel 6. Channel 11 did not work.
  • Arvind Iyer
    Arvind Iyer Mar 18, 2011
    Channel 11 or Channel 6 depends on the local wireless traffic around your place. I gave you a generalized solution which would work 99% and great to know that you made it to 100%!! Thanks for reverting.
Dynex tv won't give me the option to connect to a wireless network. It defaults to wired
This would normally indicate either a compatibility problem, the wireless network is not broadcasting, or you do not have enough signal to see the network. First thing I would try is most devices that can connect to WiFi have the option of connecting to a network that is not listed. I would try that. If that still does not work I would then try disabling all wireless security on the router just to see if that will work(I do not recommend leaving the security disabled any longer than it takes to test this). If none of that works then the next thing would be to check the signal. If you have a laptop, tablet, or cell phone that is connected to your wireless network then bring it over to the tv. If you loose signal, or have low signal then you will need to find a way to get more signal. Even if you do not see low signal on other devices the tv can still have too low signal partly because the antennas are usually in the back where the signal would be blocked by the tv as well as any other equipment you may have around the tv. Try to make sure that there are no metal objects between the tv and the router, and if possible try to get the router as close to directly behind the tv as possible. The more walls the wireless signal has to go through the weaker the signal will be, and metal can reflect the signal, completely blocking it, as well as causing noise on anything near the metal.
Apr 13, 2014 | Gateway At&t 2701hgv-b 2wire Hi Speed...
Ethernet (wired) connection to computer works but "wireless" light does not come on and my laptop cannot locate a wireless access point or network device. It has worked in the past but after...
You will need to get a hold of att. They will need to have you unplug the 2wire and then reconnect. They will need to reset the gateway from their end. good Luck.
Sep 07, 2011 | 2wire Wireless-G 802.11g ADSL Gateway
SMCWUSB-G 802.11g adapter will not renew IP address.
you should be able to configure the setting in the utility for the adaptor to auto renew the ip address
Apr 21, 2010 | SMC EZ Connect g SMCWUSB-G (SMCWUSBG)...
I can't connect wirelessly with my printer since I got Uverse
i work for att tech. support .. but for DSL
yeah we dont configure printers....
but what you can do is go to the modem interphse
URL....only type in 192.168.1.254 ENTER
and go to FIREWALL then SETTINGS
select DMZ modem or allow all applications
give that a shoot might help.
then see under HOME NETWORK if you see the printer
Jun 21, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
How to set up uverse home network with 2wire gateway
To use AT&T Uverse for a home network, you need to get the AT&T "Homeview" Network Management software. AT&T provided this software in the past freely.
This software must be run on each PC on your home network, and then each PC can see the others. You then use go to My Computer, select each disk drive you want to share, right-click and select Sharing and Security, and select to share the drive. Then go on the drive to the folders you want to share and right-click and set them to be shared. Then the Homeview system will show these are shared folders. You can also share printers on the same network using the Homeview software.
Jun 13, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Ps3 and uverse wireless 3800
Have u tried setting ur gateway to wpa open? i install uverse and sometimes thats what we have to do.
Mar 31, 2009 | Sony PlayStation 3 40GB System
Lost connectivity to network printer when switched to ATT u-Verse
Is the printer connected via wireless? When I recently connected up a new wireless printer to my UVerse network, the printer manual said that establishing the first connection works better via an Ethernet cable directly to the Uverse router. After the printer is set up once, then I could remove the ethernet cable and connect to the printer via wireless from all my computers.
For all wireless PCs that were previously connected via wireless to dsl, you need to create a new network connection for each one, then enter the key that is listed on the side of your Uverse router when prompted. Sometimes it takes a few minutes to establish the connection.
I am amazed that ATT was so unhelpful on these issues. I was one of their first Uverse customers in Texas, and several times over the last years, techs would visit my house to solve a problem or hook something up, explaining to me as he went. That their helpful attitude is deteriorating is a real shame.
Mar 11, 2009 | Computers & Internet
I want to use 2 wire ATT UVerse -- BUT NOT WIRELESS
the 2wire att uverse router, does not broadcast wireless signal if there is no wireless computer connected to its network. regarding the unchecking of the ssid, it will only hide the network name of your router, but technically, if a computer will try to connect to your router, it will still "send" wireless signal to a computer within its range.
you do not have to worry about the wireless signal being sent, if nobody connects to the router via wireless cionnection.
Jan 11, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Computers & Internet Logo
252 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Justin
Justin
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
