Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Whirlpool cabrio..tub moves all over in rinse and spin..any suggestions?
  • 213 Answers
SOURCE: whirlpool washing machine won't spin after rinse cycle
there is a coupling between the motor and transmission that has cracked. with the crack in the coupling the transmission cant spin as fast as the motor causeing the loud noise. replace coupling to solve problem
Posted on Nov 21, 2007
SOURCE: Whirlpool Heavy Duty Super Capacity Plus top loading washer
i see water around the bottom outside of my whirl pool heavy duty spuer capacity washing machine...in the spinning cycle it appears to be going out the drain hose and drainning ok???
Posted on Aug 25, 2008
ginko
  • 19396 Answers
SOURCE: Whirlpool Washer will not progress to the rince cycle.
that is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
I quote from : The cycle doesn't advance
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
  • Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
  • Posted on Nov 20, 2008
    jsrock516
    • 5911 Answers
    SOURCE: My Whirlpool ghw9100lw1 isn't rinsing...
    "F02" is a Long Drain error code. This generally means you have a clog or restriction in the drainage system somewhere. The following link explains:
    http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
    In the majority of the cases, all you have to do is clean out the drain pump reservoir. The instructions are included in the link I provided. If the problem does not go away after you have performed all these preliminary measures, the pump may be damaged and require replacement.
    This error code gets generated if the drain cycle exceeds 8 minutes. If the pump impeller/motor gets damaged, the pump may not pump at the proper volume and the error code will continue to reappear.
    A replacement (if required) can be purchased at any of the following websites:
    searspartsdirect.com
    appliancepartspros.com
    pcappliancerepair.com
    repairclinic.com
    The pump is sold as a complete unit. You cannot buy just the motor.
    If you have questions about this repair, or require addtional assistance, please let me know. I hope you find this information helpful.
    Posted on Aug 04, 2009
    • 57 Answers
    SOURCE: whirlpool cabrio loud noise during spin cycle
    The inner bearing will be faulty kindly replace the inner bearings as well as water seal before that kindly check whether the drum is freely moving with out any shaking If you find any shaking means you are suppose to change the drum only
    Posted on May 18, 2010
    Some cycles do not run
    check the timer control make sure it working ok
    Mar 12, 2018 | Whirlpool Washing Machines
    What does error code f 51mean?
    F51 error code is a motor rotor position sensor failure or a lower harness problem. You need to check the motor in manual test mode, not automatic test mode. This will check the hall sensors and do a spin test: Be sure the washer is in standby mode (plugged in with all indicators off; or with only the Clothes Clean or Done indicator on). Select any one button (except POWER, START, STOP, and PAUSE/CANCEL) and follow the steps below, using the same button: Press/hold 3 seconds. Release for 3 seconds. Press/hold 3 seconds. Release for 3 seconds. Press/hold 3 seconds.
    If this test mode has been entered successfully, all indicators on the console are illuminated for 5 seconds with 88 showing in the Estimated Time Remaining two-digit display. During the 5 second wait time with 88 showing in the display, press the same button once. You should be in manual test mode. If the button is not pressed within 5 seconds, the automatic test mode begins. The Rotor Position Sensor uses Wash, Rinse, and Spin indicators to detect the three hall sensors. Console can have up to two of these indicators on at the same time when the tub is not moving. Open the lid and rotate the basket by hand. The Wash, Rinse, and Spin indicators should toggle on and off according to the direction the tub is being turned.
    SPIN TEST: Make sure lid is down. Press and release: 2nd RINSE or EXTRA RINSE. The lid locks and the lid lock indicator turns on. Press and release; SPIN SPEED, WATER LEVEL, or LOAD SIZE. The motor/basket spins at 23 rpm. Press again, motor /basket spins at 530 rpm. Press again, motor/basket spins at 950 rpm. Press again and motor turns off.
    http://www.applianceblog.com/mainforums/threads/32879-Whirlpool-Cabrio-UL-F51-Error-Codes
    Jul 27, 2014 | Whirlpool WTW8200YW 4.6 cu. ft. Cabrio...
    WHY SPIN DOES NOT WORK?
    You have something stuck between the the outer and inter tubs
    Jul 13, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
    Whirlpool cabrio wtw5600xw0 will not spin
    There is a spin sensor that is part of the shifter if this is wet it wont sense the spinning, hence wont spin, and if it is wet you mat need to replace the tub seal http://www.appliancepartspros.com/gearcase-motor-pump-parts-for-whirlpool-wtw5600xw0.html
    May 29, 2012 | Whirlpool Cabrio Washing Machines
    Whirlpool Cabrio WTW6600SBT Top Load Washer won't aggitate
    My Whirlpool WTW6600 had the same problem. The tub no longer floated up and down on the center shaft, so it only spun, not agitated. You must remove the tub (with some effort) and lightly sand / clean the center shaft. Lube it lightly with wheel bearing grease so that after it is reassembled, you can pull the tub upward and feel about 1/2" movement. This will enable the proper gear assembly to engage. It can spin when it rests at the bottom of its travel, but once you fill the tub, it floats, moving upward, and engaging the agitation gear. Good Luck!
    Nov 23, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
    I have the Cabrio WTW6600SB, when I'm washing, I'll get to the rinse/spin cycle. the Tub starts to woble all over and bang sides of machine, then I'll get the UL code. I've been told I...
    If you push the tub to any side it should not be real easy and come back to the center with some force. If the above is good you shouldn't need springs. make sure that you load it evenly
    Sep 21, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
    Whirlpool Cabrio F50 Error
    Most likely the RPS sensor or the control board. Originally they had trouble with the RPS sensors.
    Aug 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
    35 people viewed this question
    Sal De
    Gerry Harvey
    Gerry Harvey
