Question about Cadence Weslo 825 Treadmill Walking Belt
Where can I download a manual for a Weslo Cadence 825 treadmill
  • 95 Answers
FitnessRepairParts may be able to sell you a manual if you can't find it anywhere, depending on which version of the 825 you have (there are quite a few.. check for other model numbers on your machine
http://www.fitnessrepairparts.com/part_search/EquipmentSearch/weslo%20cadence%20825
You can also try IconService.com and click on "Manuals" - sometimes they have manuals you can download or purchase.
Posted on Oct 05, 2010
4 Suggested Answers
  • 103 Answers
SOURCE: I was given a Weslo cadence 825 treadmill. I need
go to iconservice.com they have free manuals and also you may purchase replacement parts there as well. Be sure to get your model number before going to the site to make it easier (lower frame of the machine)
Good luck, Tim
Posted on Nov 25, 2009
maxtreadmill
  • 832 Answers
SOURCE: Where can I get a drive motor for my Weslo Cadence
Go to iconfitness.com click on customer service then diagrams input manufacturer then the brand name. This should give you the info you need to order your motor if not callthem 1-800-999-3756.
Posted on May 10, 2010
SOURCE: Weslo Cadence 450 Treadmill Manual
When turned on it acts like the walking surface is grabbing.Itgoes and stops its not as bad when speed is increased,but it still feels like it is grabbing.
Posted on Jun 20, 2010
Adjust incline on weslo cadence g 5.9 bought it used no manual
On the rear of walking deck you have the left and right feet. Down the deck is at 0 degree incline, fold them up and you have a 3 degree incline.. You have no incline motor on this model.
Mar 02, 2015 | Cadence Weslo 825 Treadmill Walking Belt
My cadence 825 had been unused for a while but now when I insert the plastic key the treadmill starts immediatly without my having control over it. where can I get some maintenance for this machine. Kevin...
RUN the software calibration for diagnose, troubleshooting , fix it.
adjust the speed sensor, clean it and tight the wires connector
LUBE the deck belt+rollers bearing too
SEE THE diagram.
God bless you
Jul 19, 2012 | Cadence Weslo 825 Treadmill Walking Belt
The belt keeps moving towards the left side of the treadmill and rubs the side. How can I adjust the belt to fix the problem? It is a Weslo Cadence SR12 model. Thanks!
There are Allen bolts on both sides of the bottom on the front (away from the console) of the treadmill. Turn one one way and the other the other way to adjust the belt. If this does not work, your belt is probably worn and stretched and needs to be replaced. See Treadmill Parts to order a new one.
Aug 29, 2011 | Cadence Weslo 825 Treadmill Walking Belt
May 10, 2010 | Cadence Exercise & Fitness
Lubricating a treadmill
The only lube required is between the walking belt and the deck. You can get the lube from iconfitness.com. Lift the walking belt and squirt some on the deck from each side, underneath the belt in the area where you usually walk. Walk on it for a few minutes to spread the lube around.
Mar 04, 2010 | Cadence Weslo 825 Treadmill Walking Belt
Weslo cadence treadmill wont work
I centered the belt on my tredmill and now it wont move at all. I tighted and loosened the belt. motor runs belt wont move
Feb 05, 2010 | Cadence Weslo 825 Treadmill Walking Belt
Good luck, Tim
Nov 24, 2009 | Cadence Exercise & Fitness
We have a Cadence 825 treadmill and the display has quit working. How do we fix it?
either the console is bad (which is no longer available) or the control pwb is bad (available for $114 on iconservice.com) Check for power to the controller. Red light should be on. (you must remove the hood cover 4 screws 2 on the sides and 2 in the rear) If light is on the controller then more than likely you have a bad cosole as I said it is apparently no longer available.
Nov 09, 2009 | Cadence Weslo 825 Treadmill Walking Belt
How do you adjust the belt for a Weslo Cadence 815 treadmill?
Hi, I don't have a manual on your particular treadmill but most all treadmills use the same type of belt tension and tracking, which is an allen screw adjustment on the rear tension bar. One on either side. You should have been provided an allen wrench with your treadmill, if not then use one of your own the proper size. Make the adjustment with the unit running at its slowest speed. Clockwise tightens the tension and will draw the belt. Good Luck, this should Fixya!
Mar 14, 2009 | Cadence Weslo 825 Treadmill Walking Belt
Cadence Weslo  825 Treadmill Walking Belt Logo
837 people viewed this question
Top Cadence Exercise & Fitness Experts
Jim London
Jim London
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Are you a Cadence Exercise and Fitnes Expert? Answer questions, earn points and help others
