Question about HP Computers & Internet
Tv set up
How to set up a cable box to my hp pavilion?
    Scholar:
  • 110 Answers
The port you're looking for looks like this:
It's called an SVHS or stereo VHS output port, and with an SVHS cable should be able to be plugged into a cable box.
Note that this is a ONE WAY PORT - it takes a signal FROM the notebook, not TO the notebook. If you want to view television pictures on your notebook you will need further hardware. This port is only for viewing your computer output through a television or other device.
Posted on May 28, 2008
How do i connect my hp pavilion dv6653cl entertainment notebook pc to my flatscreen tv?
set tv to pc insert vga cable and audio cable from tv to cpu the audio jack is normally up front next to the volume control
Jul 09, 2013 | HEWLETT-PACKARD PAVILION DV6653CL LAPTOP...
My hp pavilion ze2000 will not turn on output svideo
Thank you for using FixYa
Turn the TV off and the Computer off and plug in the SVIDEO cable
Turn on Computer
Go to Control Panel in your computer
Appearance and Themes
Display
Settings
Advanced - then select your Graphics card
Device Settings
TV
Change the display settings to 800 x 600
Turn on TV
You should see both screens however you may change it to one if you like.
Mar 13, 2011 | HP Pavilion ze2000 Notebook
I have a philips tv model 47pfl5704d. what cable
IF, your PC indeed supports TV out, then the Cable usually is SVGA or RCA, connectors. The PC must be configured to activate BOTH screens, ie: enable desktop, to be spanned or mirrored, , the Resolution on TV should only generally be set to 800x600. The correct Drivers must be installed. Must connect to TV before ya start PC too.
Jan 26, 2010 | HP Pavilion 505n (DC470A#ABA) PC Desktop
No picture dv5 HDMI
Connecting  an HDMI cable is not the only solution to share ur laptop screen over ur tv set
u've to change few settings from the laptop so that u can see or operate it from TV.
SImply go to ur Control Panel, Open Dipslay Properties, Go to Properties & select Displays. Then Identify & change ur default display from ur laptop display to ur HDMI Display. Its done
If this works, please rate me up, i really need some good ratings.,...
If this does not work, feel free to ask again
thanks !!!
Dec 13, 2009 | HP Pavilion dv5020us Notebook
I just hooked up my HP Pavilion 9000 Laptop to my Vizio TV and put the TV on correct setting. It is not working on the TV, any ideas? I went on Display setup and kept trying to connect but it says the...
If your laptop has a VGA port, your Vizio needs to have a VGA port too so you can use a standard VGA monitor cable.
If your laptop has a DVI port, you hook it up to the Vizio using a DVI-to-HDMI cable.
And if your laptop has an HDMI port, you hook it up using a standard HDMI cable.
Hope this helps.
Oct 16, 2009 | HP Pavilion dv9000z Notebook
How can I view my pc on tv using an hdmi cable and a comcast digital cable box? My tv does not have an hdmi input.
The hdmi port on the Comcast box is an output only and cannot be used as an input from the general public. If your tv has a DVI output, there are DVI to HDMI adapters that can make the hook up....other than that, there is the super video cable but you will still have to run audio through a seperate line.
Oct 11, 2009 | HP Pavilion dv9000z Notebook
How to hook up a hp pavilion laptop to a hdtv
if it worked fine at some point then it should work fine now... i use hdmi to hdmi from my laptop to tv all the time dvi would only cause quality loss.
the first thing i would try would be to change your resolution on your laptop to a couple different settings. a lot of times, if its not set to one thats compatible with your tv, you won't see anything.
if that doesn't work, go to personalization and open the tab that says "connect an external display" and toy around with it. but yeah it doesn't sound like you have any hardware problems there.
hope this helps
Jan 16, 2009 | HP Pavilion dv6000z Notebook
Problem hdmi connection
Hello, I'm from the Netherlands and I had the exact same problem with my philips lcd...
So what I did, was upgrading the software of my videocard (nvidia.com),this resolved my problem of giving a error on my laptop and restarting.
Then I got the message on my tv: "video not supported' , this I don't know exactly how i resolved this, but i tried fn+f4 a couple times. If that doesn't work you have to do something with the nvidia control panel (right click on desktop).
So now i had picture, but no sound.
To enable sound from your laptop to your tv you have to go to control panel>sound> set the SPDIF to your standard sounddevice and tick the box with wma audio something, tick out the other boxes.
I hope this will resolve some of your problems and others who have the same problem.
greetings,
Sam
Dec 14, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
32 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
