Question about Sunbeam 5891 Bread Maker
The machine reset hereself before the cooking phase
    Problem Solver:
  • 5 Answers
Then programme it on the bake cycle.
Posted on Oct 08, 2010
  • ursic Oct 08, 2010
    Yes, but that's a patch. I'll be glad to know what I have to do to poen the machine in order to check the powe supply
What mean error E99 at Electrolux EHD 6005 P?
E9 - Communication defect inside user interface.
Only the affected zones are subsequently displayed with an
"E" in the cooking phase display and are thereby disabed. The
other zones can still be used.
Replace User interface.
Dado
Feb 29, 2016 | Electrolux Washing Machines
Can i get a 200v invertor to run a 3-phase sewing machine at home
You will have to check with an electrical whole shop (business) but I doubt it as there are 3 different phases in three phase each one needing its own inverter
It would possibly be cheaper to get a single phase motor to replace the 3 phase unit or enquire from your power utility , the possibility of having 3 phase connected to the premises.
Jun 16, 2015 | Sewing Machines
Electric cook top only gets 120 instead of 240V
see the diagram and fix it. You have lost 1 phase open the outlet wall and measure the phase, go to the main panel breaker open the circuit, and repair the phase, if you are NOT shure call some electrician.
God bless you
Sep 24, 2012 | Jenn-Air 35 in. JEC8536A Electric Cooktop
Fisher & paykel waterpump / Burnt smell clothing
ok, have you checked for power at the power point? if you have power to the machine and the display doesn't light up after you have turned the power point on then your control module is faulty. only the phase 5 models don't power up if the pump is faulty, your machine is a phase 2 with a blue control module. by the way, what part of the machine did you pull apart? i think your pump was faulty which made the control module faulty. check the pump for a burning smell. if it is burnt then i"m sure your module is too. please reply if you need more help to fix this problem.please turn off the power b4 you work on it, don"t want any accidents . good luck.
May 17, 2010 | Fisher and Paykel Fisher & Paykel Washer
Does this machine run off 240volts or three phaze regards gary
If I undersatnd correct your question is if it can work with single phase or three phase.
You should first check the lable of the machine which is a silver plate and which it can be found outside the machine so you can check the voltage if it is 220-240 or 110V. Also you can find the total load in Watt.
You can check also to see how many wires are incuded in the power cable. If you find only three then you can only be connected with single phase. If you find five cables then you can connect both single phase and three phase. In the case you want single phase then you can connect the three phases as one. The only care is that the supply isolator on the wall to be able to supply the required total power mention on the label of the machine.
Good luck
Apr 16, 2010 | Astoria Argenta SAE-2 Espresso Machine
Can I change model 754 machine from three phase to single phase by just replaceing the three phase motors with single phase motors?
no you cannot. The cost to replace the dasher motor and compressor would be extreme. In addition, you would need to convert the controls from 3 phase controls over to single phase controls.
Those machines are designed for 3 phase power. If you could get the same components in a single phase version, you would spend more money economically than its worth.
Take the money you would spend converting and purchase a single phase countertop unit. They are made.
Feb 11, 2010 | Taylor 632-27 Ice Cream Maker
When wiring the 3 phase plug for power is the machine machine sensitive to phase rotation
If it is 3 phase it would be sensitive to phase rotation. After hooking up the machine I would check the rotation since it is 3 phase it could be running backwards.
Jan 14, 2010 | Washing Machines
Cooktop - maytag cse9000 - wiring
white goes to neutral, bare copper to ground, red and yellow to one phase ( red L1 wire) and the black and blue to the other phase ( black L2 wire)
Dec 20, 2009 | Maytag 30 in. CSE9000 Electric Cooktop
3 wire cook top to a 4 wire outlet
Older 3 wire connectors where Wht=Neutral Ground Return, Red=One Phase Hot, Blk=Second Phase Hot, of 220VAC stove connections.
Newer Electrical code standard has a forth wire that is bare copper for a separate safety ground return.
I suggest you but a 4 wire pig tail cable for your stove top, available at Depot or Lowes, and connect 3 wires of this 4 wire cable just like the 3 wires are now connected. The 4th bare copper safety is attached to any metal part of the stove. Find a screw you can loosen to wrap it around and tighten.
Mar 02, 2009 | Jenn-Air JED8230 Electric Cooktop
Sunbeam 5891 Bread Maker Logo
37 people viewed this question
Top Sunbeam Kitchen Appliances - Others Experts
Are you a Sunbeam Kitchen Appliances - Other Expert? Answer questions, earn points and help others
