Question about HP Photosmart C6180 All-In-One InkJet Printer
Will not finish warm up or allow turn off: it is stuck.
    President:
  • 4,070 Answers
Hi! Please try this. Unplug the printer from power source then press hold the power button for 10secs. while unplugged. This should reset the system and will bring back your printer to it's normal working condition. Hope this helps and thank you for using FixYa!
Posted on Oct 05, 2010
  • schomerlicht Oct 05, 2010
    did not help. still am faced with hp symbol and no progress. now it beeps to black occasionally.
Where is the idle screw on a 2000 R1
The following is for a 2001 model, may be the same on a 2000.
Follow your shift linkage from the foot shifter 'up' the linkage rod.
Where the linkage rod meets the shift shaft, right beside it you will find a gold colored Knob.
Thats the idle adjuster.
You will want to loosen the left Mid-fairing to allow you to get your hand behind it to reach the adjuster knob.
You dont have to remove it, just loosen the 1/4 turn screws holding it.
do not adjust the idle when the engines cold. Have it good and warmed up.
When your finished, retighten the 1/4 turn screws, and your finished.
Small adjustments, allowing the engine to 'catch-up' work best.
Good luck.
Apr 09, 2014 | 2000 Yamaha YZF-R1
Removed aluminium foil stuck to oven with pool acid - is it safe to use now?
kill the acid with some caustic soda - normal oven cleaner
then you can cook free of acid fumes
Jan 01, 2014 | Ovens
2001 Pontiac sunfire doesn't put out hot air when put on hot setting only warm air
Your coil that allows air to pass through for A/C or heat could be plugged or the thermostat is sticking.
Oct 25, 2013 | Cars & Trucks
Temperature gage is going into red zone
YOU MAY HAVE A THERMSTAT IS THE STUCK PARTIALLY CLOSE
NOT ALLOWING FULL FLOW OF COOLANT THROUGHOUT ENGINE, TRY TO REPLACE THE THERMSTAT. WHAT ENGINE IS IT? 4.3L,5,7L ?
Oct 07, 2012 | 2003 GMC Envoy
Rinse and Spin cycle stuck and not rinsing or spinning properly
Just read your posting.Now just a couple of questions.Are you using a warm fill for the wash or cold?if are using warm try cold only and take note of the time it takes to fill.I don't think your cold water is filling properly. My manual says that with only the 1st rinse light working it is your control module that is faulty. Please try a cold water wash and reply back so we can rectify this problem.
Jun 06, 2010 | Fisher and Paykel GWL11 Top Load Washer
Lost my manual for chef condor integra oven - need to check auto functions and how to set them
For TOuch Control oven:
1. Press Finish Time touch pad
2.press ^ touch pad until clock displays the required am or pm finish time.
3. Press Cook Period touch pad.
4. Adjust the cooking time as in step 2, using up and down arrow touch pads. (hours and minutes needed to cook food)
5. Press Automatic touch pad.
Press Fan touch pad to select fan speed. Red indicating light shows normal speed.
7. Turn oven thermostat to desired setting.
8. Press Keep Warm touch pad if keep warm function is required at end of cooking. 9. At end of cooking time a buzzer will sound for 1 minute and the KEEP WARM cycle will now operate until the meal is ready to be served.
10. To cancel the Automatic cycle, press Manual touch pad and turn oven thermostat off.
For Multifunction oven:
1. Set time of day.
2. Turn Function switch to Finish. 0.00 will be displayed.
3. Turn display switch + to give the required am or pm finish time. (an illuminated bar in the bottom left corner indicates when the clock display is pm).
4. Turn Function switch to Cook then turn Display switch to + till desired cooking period is displayed (hours and minutes needed to cook food)
5. Turn Function switch to Auto. The automatic programme is now ready to use.
Turn upper oven thermostat to desired setting.
If keep warm function is required, turn function switch to Cook (optional)
Happy cooking!
Jun 14, 2009 | Ovens
How do I free a stuck cartridge service station.
These are generally pretty easy, they are supposed to move to the center whenever you open the lid. However, there are quite a few things that can stop this from occuring,
If you have a print job in the que, or a camera card in one of the readers it needs to finish what it has qued before it can continue.
Remove any camera cards, close the lid and power down your computer. Then turn off the power to the printer. Remove the printers power cord and wait thirty seconds. Plug it back in and give it a minute to get through it's warm up. While it's warming up listen for the normal sounds of the head moving back and forth.
If you don't hear the sound it's likely a mechanical failure in the printer, if you do when you open the lid now it should move to the center to allow you to load the new ink.
If it doesn't you can post back here for additional info or go to:
https://wimpro.cce.hp.com/ChatEntry/Chat.aspx?productOID=397810&productLine=83&productSNI=hpphotosma397811&productName=HP+Photosmart+8150+Photo+Printer&productCategory=15100&SCOID=236252&h_cc=us&h_lang=en&lc=en&PSOID=397809&lang=en&cc=us
enter the chat with an online hp support tech as they have more detailed info for you to diagnose the issue.
Hope this helps FixYa,
Chris
May 05, 2009 | HP Photosmart 8150 InkJet Printer
Hp psc 2110 copy problem stuck warming up & scanner bar get stuck
The scanner carret belt might be too loose, so the printer cannot pass through the self-test. Try tightening it a little bit. Also you have to either repair the nobs or solder it.
Feb 14, 2009 | HP PSC 2110 All-In-One InkJet Printer
Steamers
most cookers have a basic lever down to cook/ up when rice is done or warming
2 cups med rice 3 cups water yeilds about 6 cups cooked, allow rice to sit 4 -5 min after cooking to allow to finish steaming
Feb 26, 2008 | Kitchen Appliances - Others
HP Photosmart C6180 All-In-One InkJet Printer Logo
41 people viewed this question
Seeker5211
Seeker5211
