Question about Kenwood Audio Players & Recorders
Item does not work
Hello i have a kenwood reciever KR-797 and it turns oln but no sound come out what could be wrong?
  • 4,234 Answers
This unit is most likely in protect mode. This occurs when the receiveer detects a problem with the output amplifier section and that section is disabled. The most common failure parts are the output transistors. Expect a parts cost between $15-$40, Add in the local labor rate for the total repair cost.
Dan
Posted on May 28, 2008
Kenwood KR-V7080 reciever will not play through speakers.I can still plug headphones into the reciever and get audio but not through the speakers. Tested the speakers and they still work.
If the speakers used to switch off when the headphone plug was put in the socket, suspect the socket it goes into as being the trouble. It is clearly not connecting the speakers, when the headphone plug is removed.
Aug 17, 2015 | Kenwood Audio Players & Recorders
My Kenwood KR-v8050 reciever will turn on, but will not go out of stand by mode, the visual screen also is not working, what am I looking at to fix this?
Sounds like either the main power fuse is blown,or the power transformer is bad. If the fuse is blown, probably means the amp is shorted.
Dec 31, 2012 | Audio Players & Recorders
My kenwood reciever kr-a4070 keeps blowing a fuse
have you tried a different outlet? something my be wrong internally
Jul 31, 2012 | Kenwood Audio Players & Recorders
I have a Yamaha RX-797 reciever and wish to install an outdoor speaker system through the zone2 outlet. Do you know if I can go from the zone2 outlet through the coupler jacks to the speakers so I can...
Hello sounds like you want to take the low level zone 2 output and run it to the PRE AMP in?
If that is correct the onboard amplifier will power your speakers but will no longer provide sound for your main channel as you are removing the "loop" which send the front L & R signal to the amp.
Your best bet is to find an inexpensive secondary amplifier.
Sonance makes a sonamp 260 or 260x3. These are available on ebay for under $100 and work great for multiroom applications.
A 260x3 would give you 3 speaker outputs allowing you to run not only to your patio but also to two other locations and includes a switch to turn each zone on/ off.
Hope that helps
Jan 02, 2010 | Yamaha RX-797 Receiver
I have a Kenwood KR-A4010 Am/Fm Stereo Receiver. Every five seconds the sound fades in and out. Can anyone find a solution to this problem?
Something in the unit is smoked and potentially dangerous. Get that puppy down to a repair shop. Don't leave it unattended if you turn it on. Got a fire extinguisher handy?
Apr 28, 2009 | Audio Players & Recorders
Problem with playing my Kenwood KR-X1000
Unit apparently has problems. Check/replace batteries in remocom
Nov 19, 2007 | Kenwood KR-X1000
223 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
