Question about Canon iR5000-6000-L1 PS Ver 1.0
Canon IR5000 problem no heat on fuser, lamps check out good no error on display?
  • 208 Answers
SOURCE: Canon MF 5550 Fuser error
More than likely you have a fuser failure.
either contact canon or whoever you purchased the machine from.
The most likely solution will be to replace the fuser unit.
Posted on Dec 10, 2007
  • 168 Answers
SOURCE: IR5000 bloque
this is a code for detection of no or faulty charge to the drum open front door remove toner hopper take out primary charge unit see if any wires are broke on grid , then see if the wires underneath the grid are still there... if all seems ok gently clean the grid with cloth and windex then clean wires underneath dont break grid wires . put it back in let me know
Posted on Dec 23, 2008
SOURCE: CANON IR5000 ERROR CODE E000002-00000
NEED HELP WITH ERROR CODE E000246-0005
Posted on Dec 21, 2009
  • 62 Answers
SOURCE: Canon IR5000 and the finisher unit
Dirty sensor inside finisher, blow whole thing out with air. Sensors look like small black c-shaped with connector with three to four wires. Dust dirt block when not supposed to be blocked. Shutter open sensor does not turn on when the #2 feed motor has been rotated CCW for 1 second.
Posted on Jul 07, 2010
canontech
  • 1219 Answers
SOURCE: error code display 00007 in
as you probably now, the E007 is error for fixing film rotation. The rotation is checked over sensor above the film's "white" dot.
So are You sure that sensor works, is there any left overs of old film on sensor, reconnect all connectors related to the film sensor, is the "white" spot dirty or damadged, are you sure that fixing film is rotateing properly??????????
Hope that something of this will help you to find solution....
Posted on Sep 15, 2011
Copier shut down
It sounds like there is a problem with the fuser unit, although am not sure why there is no error code. In the fuser unit, check the thermal fuse to see if it is open circuit. Then check the heat rod (fuser lamp) for same and, least likely, the thermistor that controls the fuser's temperature. Also make sure the surface of the thermistor is clean (remove caked toner) and is making good contact with the hot roller. When repairs are made, you may find that you have to enter a service mode and reset the machine.
Dec 06, 2013 | Canon NP 6035 Copier
Error code e000001 0000
e000001 0000 is E001 error this is a fuser type fault.
First, the error needs to be cleared. Turning off/on won't do that.
You could go into service mode and clear the error (*28* > copier> function > clear > err > ok. Then turn the copier off, then on again and watch it heat up. I always monitor the temperature to make sure it's in the acceptable range (190 C or around that range).
If it happens often you need to change the thermistors . If it still happens, check the connectors in back of the fuser. They may need to be shimmed.
And you can get the service manual for ir5000 it will be help you a lot and save u $ you can get it from the below link:
http://goo.gl/k11ZyW
good luck
Aug 05, 2013 | Canon imageRUNNER 5000 Copier
My mechine display an error e002.
Error # 0002 indicates "Fuser temperature not rising at correct pace. Same possibilities as E000"
Error #000 refer to a number of possibilities "Fuser did not heat up. Lamp, thermal switch, thermistors, connections, AC driver, DC controller
Replace the Fuser Roller also known as the Pressure Roller or Upper Roller to resolve your problem.
Mar 08, 2011 | Canon NP 6035 Copier
Error e000004-0010 how to solve
I'm not a Canon Copier Tec but I know E04's on Canons generally means heat/fuser error - ie fuser, usally fuser lamp, thermister or thermal fuse. Have fuser replaced.
Have it looked at, due to it requiring electrical knowledge, ie test heater lamp(open), thermal fuse(open), thermister(check for toner built up on face) with the user removed from printer (fuser=hot bit that paper goes threw, just before where paper exits to go to sorter) or just replace assem.
There maybe a reset required, on some canon models after problem has been fixed.
So here is a link with explaination of the reset on a canon model simular to yours http://www.copytechnet.com/forums/canon/2673-error-code-e004-canon-np-6330-a.html
pls vote me to keep us alive
Nov 17, 2010 | Office Equipment & Supplies
It gives a code sc 542
The error code is related to the fuser area.
Likely to be a low fuser temp issue.
Need to verify good or bad heat lamps.
1) Check each lamp in fuser.
(lamp is good if you get continuity)
(lamp is bad if open)
2) Check the thermostat. (thermal control device)
(triggers if unit gets too hot)
3) Also check thermistor (monitors temp of fuser)
(2) total (middle and rear)
If heat lamp is good:
Your best bet is to change all three items. (Temp fix)
Fuser thermostat - thermal control device
Fuser thermistor (middle front) - thermal control device
Fuser thermistor (rear) - thermal control device
These items wear out. Change at the same time.
Fuser needs to be rebuilt or replaced.
Oct 19, 2010 | Ricoh Aficio AP610N Laser Printer
What does error code E000001-0000 on a Canon IR5000 copier mean
The error code is much more likely to be E001, this is a fuser type fault. You should be able reset it in service mode. (copier, Funtion, Clear, error, turn m/c off then back on)
As the issue is a fuser temperature related. First, the error needs to be cleared. Turning off/on won't do that.
If it happens often I'd have the thermistors changed. If it still happens, check the connectors in back of the fuser. They may need to be shimmed.
Sep 01, 2010 | Office Equipment & Supplies
Fault code sc542 appears on screen
(Check for wear and tear)
Inexpensive repair for the temp fix.
The whole Fuser cost can brake the bank.
I buy parts from precisionroller .com (you can preview the parts)
Franklin
baselinerepair .com
Apr 20, 2008 | Office Equipment & Supplies
Canon D880 Error -- E000
From a fellow FixYa expert, "Press "Additional Functions", press "#", then press the "Right Arrow" button till it says, "Printer", then press "Set" then press the "Right Arrow" button again until it says "Printer Reset" then press "Set" again, the display will ask you "Yes" or "No". Press the "Left" arrow for "Yes", then press "Set". Now, unplug the power cord and wait 5 seconds and plug back in. If this don't work, get a new fuser."
Nov 28, 2007 | Canon ImageClass D880 Copier
E000004-0010
canon NP 6330
error 800
Nov 15, 2007 | Canon imageRUNNER 5570 Copier
Computers & Internet Logo
Top Canon Computers & Internet Experts
Aashish Chaudhary
Aashish Chaudhary
Computer Links
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
