Question about Zanussi IZ161W Front Load Washer
Hi I Have a IZ 161 W goes through all cycles until spin starts in slow spin but thats it and the time does'nt move basically it is not spinning to full speed . appreciate any advice regards Sarah
    Problem Solver:
  • 7 Answers
The speed of spinning in the washer depends on the weight of the linen in the machine. if the machine is not fully loaded it will create an inbalance and the motor control unit will sense this and hence spin at a low speed. Solution is to ensure that the machine is fully loaded with enough linen.
Posted on Oct 05, 2010
Unbalanced load at nearly every spins cycle ,move clothes around until it spins
Is it a front load or top load? Do you have the make and model?
Jan 26, 2015 | Washing Machines
AWO/D 4505 not spinning
does it pump out all the water when it spins the first time? when they spin slow sometimes the pump is not pumping out all the water causing it to spin slow.
May 15, 2014 | Whirlpool Washing Machines
Hi Fixya, I have a Kenmore top load washer Model# 23812100. I have spin issues. I replaced the lid switch and the coupler and the spin cycle is now spinning slow and seems like it wants to spin but...
Make sure that the motor is spinning with correct TORQUE. If this seems good then the washer must SPIN inthe cycle. A loss of RPM can then be due to the clutch slippage as it fails to engage fully to the motor. Best is to check this assmebly and change the spare requied.
check for tips on the link below;
http://www.espares.co.uk/advice/washing-machines/a/7
Jul 19, 2011 | Kenmore Washing Machines
Hi I have a Bosch WSL1662 Maxx washing machine. The spin cycle does not work properly. What could the possible cause be. I have cleaned the outlet of the washing machine and the problem is still...
Probably a blocked empty pump filter. Spin won't kick in until all the water is evacuated. If there is a little left, the machine will do the slow turn cycle that it does just before spin starts but not start the spin cycle because of the water in the drum.
You need to locate the filter and clean it. That should fix your problem. Once this is done, remember to keep the filter clean every few months
Jun 23, 2011 | Washing Machines
On my Cabrio, the washer goes through all of the cycles fine until it gets to the final spin. No matter the size of the load, I get a "ul" code. I can move the items in the washer around but it contines...
Hi
Thanks for using FixYa. ULis displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load.
• Display clears if mini-cycle successfully rebalanced the load.
• If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute the load. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 29, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
HELP!! Washer machine wont work. Doesnt drain or spin. Clicks to drain and spin but nothing happens, the timer still counts down as if everything is fine.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
If the machine starts, fills and goes through its' agitate cycle fine, the problem is likely not in the motor or transmission.
This type of washer uses a reversible motor. When turning one way, the machine agitates the clothes.
When the timer gets to the spin cycle, the motor reverses, drives the pump (directly from the motor) for a period of time and then goes into spin cycle.
This appears then that is is either the connection to the motor itself or the timer.
The timer is driven by a separate motor on the control panel so if the contacts for the spin cycle are worn, the timer will move but the motor won't turn on.
Sep 09, 2009 | Washing Machines
End of wash cycle, no draining or spinning, but can move to rinse cycle and it agitates again, no spinning after rinse either
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
The drain and spin functions are started when the timer advances to the spin mode.
The motor is reversible. When agitating, the motor spins one way, when going to the drain / spin mode it reverses.
Since the machine agitates, the problem points to the timer.
Sep 04, 2009 | Kenmore Washing Machines
Washer does nothing during rinse then leaks during spin cycle
hi thanks for the question i would check the drain hose your problem is the washer is not draining check the drain hose thanks the appliance doc
Sep 27, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Zanussi IZ161W Front Load Washer Logo
162 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
