My files were collapsed while formatting from hard drive
  • 27,725 Answers
click start run type cmd then type chkdsk/f which will automatically fix any corrupt files on your hard drive then defragment your hard drive if you cant start your computer
press delete during boot up process enter BIOS then f1 for general help then run chkdsk/f which will automatically fix any corrupt files on your hard drive
hope this helps
Posted on Oct 05, 2010
    Scholar:
  • 179 Answers
Sorry u cannot retain those files back.. they are deleted permanently from the computer.. you must have saved those files in some external drive
My glyph harddrive dont show up on my mac why?
If the hard drive was formatted on a PC computer in NTFS file format then the MAC will not recognise this hard drive.
If you want to transfer data between the PC and MAC then you need to format the hard drive with a PC in FAT32 file format. The MAC can read and write to a FAT32 formatted hard drive
Aug 08, 2012 | Glyph GT 050Q Hard Drive
External hard drive used on mac,how do i use it on pc?
You need to format this hard drive using your PC.
If the hard drive was formatted using the MAC then the PC won't see anything on the hard drive because the MAC uses a different file system that is not compatible with the PC.
BUT if you want to exchange files between the MAC and the PC then format the hard drive using the PC in FAT32 file system. The MAC can read and write to a FAT32 formatted hard drive.
Apr 10, 2012 | Hitachi Computers & Internet
Will i loose pictures & other files if i format my pc
Yes you will lose all files when you format.
If you want to save your files but cannot open Windows on your computer then remove the hard drive from your computer and connect this hard drive into an USB hard drive adapter. Plug this adapter and hard drive into the USB port of a working computer, this computer will see this as an external storage device, you can then open the folders on this drive and copy/backup the various folders and files.
After you have copied/backup your files, you can install the hard drive back into your computer to format and reinstall Windows.
Feb 06, 2012 | Lenovo Computers & Internet
Formatting for Mac
What do you mean?Want to recover data from formatted hard drive?
Data Recovery Software can help.
Tenorshare Data Recovery is a professional data recovery program that can recover data from hard drive after deeply scanning your drive to look for lost data you accidentally deleted or formatted.
Get it from: http://www.any-data-recovery.com/product/datarecoveryprofessional.htm
Aug 30, 2011 | Iomega eGo Portable Hard drive 500 GB ...
I have toshiba cavino 750gb hard drive. it was working fine since last night i can't open it.. it takes long time to open and i see format to paly it i don't want to loose my file i need some...
Don't be panic. you can try some format recovery software. You can see
http://www.asoftech.com/adr/
It tells the steps how to perform data recovery.
If above does not work, you may have to format the hard drive (use quick format), and then use above mentioned software to scan again the hard drive and recover your files.
Aug 03, 2011 | Toshiba (1TBEXT-HDD) (1TBEXTHDD) 1000 GB...
How do I format this hard drive to a FAT32 hard drive?
Go to My Computer, right click on the drive, go to format. select fat32 on the type list. Remember that this will delete all of the files on the Hard Drive.
Mar 03, 2011 | Beyond Micro (BM120MD3U2) 120 GB USB 2.0...
Unable to access files
To access the files off the hard drive another way - remove the hard drive from the case and connect it to an USB hard drive adapter and then plug it into a working computer's USB port. If the computer see the hard drive as an external hard drive/storage device and you can open the folders and files then backup your data. This also indicated the hard drive is OK and the Western Digital case/electronics is faulty.
To use this as an external USB hard drive, put the hard drive in an USB adapter case.
Sep 09, 2010 | Western Digital 320GB MyBook External USB...
Segate portable hard drive 500 gb not able access
is the computer see ing it if not ,unplug run computer then turn off re plug in and computer should see it with its plug and play system
Jul 06, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Remove Write protection from the Pen drive permanently
Hi Abhishek,
There is a samll tab in the which will have lock mark, move it to unlock.
That will remove the write proterction, still have issue replace the drive.
Thanks
Smith
Jul 15, 2009 | Transcend 8GB SSD, 2.5- Inch, IDE, SLC...
My SmartDisk 80 gb FireLite hard drive says it is full but it is empty. What could be the reason for this and how would I format it? I use a Macbook pro. I dont want to have to buy a new external...
You will receive an error message when copying a file larger than 4GB to the hard drive if the drive is formatted FAT32. The FAT32 file system has a file size limitation of 4GB. You may also receive an error when backing up to the hard drive using backup software. To correct this problem you will need to format the drive to NTFS. If you are using Windows ME or 98SE, you will not be able to use NTFS.
There are some products that do not support the NTFS files system or changing their file system. If you own a FlashTrax/FlashTrax XT/FotoChute/PhotoBank/USB FireLite XPress, you cannot change the format of the drive to NTFS. It must be kept as FAT32 in order to operate properly. If you are using SOHO NAS via ethernet, do not format it to NTFS. If you have any questions, please contact technical support before you format the drive.
Warning: Formatting a hard drive erases all data from the drive. Please backup any data prior to formatting the hard drive.
To format to NTFS, open My Computer.
1.Right-click on the Verbatim hard drive, left-click on Format.
2.Select NTFS as the File System.
3.Place a check in Quick Format.
4.Click Start.
Once the format completes, you will be able to copy files larger than 4GB to the hard drive.
Feb 03, 2009 | SmartDisk FireLite 80GB 400Mbps FireWire...
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
