Question about Maytag Atlantis MAV6000 Top Load Washer
Maytag washer leaking from the bottom of the tub. mod. #MAVT446AWW Ser. #27434627JP REV #27
  • 90 Answers
SOURCE: maytag atlantis leaking in the tub
replace water valve
Posted on Jan 06, 2008
  • 96 Answers
SOURCE: washer leaking water on floor
Need to check drain pump and its hose connections. If its not from the drum seal then that's usually where the leaks occur.
Posted on Mar 31, 2008
  • 79 Answers
SOURCE: Maytag neptune washing mach.mod. mhw2000aww
See www.neptunebearing.com for a bearing and seal kit... They also rent the Tony Tool out for home owners to use and there is a video to help you.
Posted on Jul 05, 2008
jsrock516
  • 5911 Answers
SOURCE: Maytag washer loud sqeal when
The loud squealing can be caused by a couple of things. The following link explains this to you:
http://www.fixya.com/support/r387833-maytag_washer_squeaking_problem
This is a problem that can be accomplished by the "do-it-yourselfer" if you are mechanically inclined. In addition, a special is required (and recommended) to compress the large spring located under the Brake Stator. If you go to searspartdirect.com and type in your model number, look under the "Transmission" heading and refer to the drawing. There's an excellent illustration of the parts I discuss in the link and how they are assembled.
The spring that you must compress is item number 20.
The brake rotor is item 23.
The snubber is item 24.
The brake stator is item 25.
This can be a challenging repair is you've never worked on a washer before. Now, if you wish to pursue this repairclinic.com is another reputable website that offers some additional assistance that I need not see on the previous website. They offer a service manual (item #1094741) that provides step-by-step instructions on repairs. Maytag provides excellent instructions with their replacement parts, but this manual may come in handy. Additional tools that I would recommend are:
Spring Removal Tool (item #455570) - makes it easier to remove the wash tub suspension springs.
Brake/Bearing/Seal Removal Tool (item #997909) - this tool is required to compress the brake spring.
The following link shows an illustration of tools mentioned:
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx?searchText=maytag+washer+tools
I know this may seem overwhelming, so I would recommend trying to use the recommendations in the first link I provided you on how to quieten the problem first. In some cases, this is all it takes to quieten the problem. It sounds like to me that your brake rotor is glazed over and needs replacement. I hope you find some of this information helpful. Let me know if you have any questions.
Posted on Sep 11, 2008
jsrock516
  • 5911 Answers
SOURCE: year of maytag washer mod#LAT9304AAE
If you're asking what year the washer was manufactured, it was August of 1995. I hope this answers your question. If you still need assistance, please let me know.
Posted on Jun 21, 2009
Sudsy water is leaking from the machine
Hello there and thank you for choosing fixya
The tub seal is the most common thing that causes Maytag washers to leak. This is unfortunate because the tub seal is an expensive repair job and not one I would suggest doing yourself. I say this because it is complicated and requires special tools to perform this job. To check if the tub seal is bad, first remove the front panel by removing the two screws from the bottom of the front panel. If you have a newer model, prize the bottom clips with a screwdriver. Then pull the bottom of the panel until the top clips release. Then start the washer and watch for a leak around transmission where it goes through the tub. If it does leak then the tub seal is bad and needs replacing. If you have the tool or willing to buy it click here for instructions on how to replace the tub seal. If the tub seal doesn't, leak you probably found the leak while performing this test.
Mar 07, 2011 | Maytag MAH6700AWW Neptune Front-Load...
My maytag washer model #MAVT446AWW, will not spin , all the water drains out but the unit won't spin ,
Similar issue for MAVT446AWW machine. Tech ordered a brake, rotor, belt and thrust bearing. I had a service contract with Lowes and they elected not to fix as too expensive. Gave me a store credit for a new machine.
Feb 08, 2011 | Maytag SAV571EEWW Washer
We have a kenmore elite washer mod. 970-c40062-00 ser. xc11700832. the washer leaks, and is very noisy. It is 10 years old
Your Stainless Steel drum is supported inside of the washer tub by a spider assembly. The assemply, which is made of cast aluminum, has corroded (steel and aluminum and detegent don't mix) and the spider assembly has broken. The drum has likely wobbled enough to wear a hole through the tub. You need to replace the drum and spider assembly, and tub.
Mar 06, 2010 | Kenmore Elite 45986 Front Load Washer
I have a maytag MAV5920EWW and i need to know how to get the agitator off as well as the front panel
Hello there:
here isa couple of links below that will show you how to do it ok
I hope that this is very helpful for you
Best regards Michael
  1. [PDF] 16026502 Maytag Amana Top Load Washer 8628k - Adobe PDF - View as html MAV5920EWW. MAV551EEWW. NAV8805EWW. Electronic. Energy Star rated. ... "Agitator/Spinner/Outer Tub/Transmission Removal" procedure. ...www.servicematters.com/maytag_library/docs/16026502.pdf
  2. [PDF] Technical Bulletin 1950k - Adobe PDF - View as html MAV4758AWW, MAV551EEWW, MAV5758EWW, MAV5920EWW, MAVT236AWW, MAVT346AWW, MAVT446AWW, MAVT546EWW ... 4. Remove Agitator by loosening bolt threaded into ...www.servicematters.com/maytag_library/docs/TDL-0086-B.pdf
Nov 22, 2009 | Maytag MAV5920E Top Load Washer
Year of maytag washer mod#LAT9304AAE Ser#13364036MS
Jun 21, 2009 | Maytag Washing Machines
Spins really fast and loud and is leaking at bottom of tub where shaft goes in
buy a new washer .specifically a direct drive whirlpool,no belt. maytag washers are not what they use to be.
Jan 04, 2008 | Maytag Legacy Series Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
82 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
