Question about ViewSonic VX710 17" Flat Panel LCD Monitor
Screen flashes on 1 sec and off 1 sec. - ViewSonic VX710 17" Flat Panel LCD Monitor
  • 11,361 Answers
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Oct 05, 2010
Testimonial: "Good Stuff. I will let you know ho wit comes out. Thanks Mark"
  • Bud Martin
    Bud Martin Oct 05, 2010
    Let me know if you need service manuals.
HI, I have a Samsung PN60E6500 plasma TV that stopped working. If I switch it on, nothing at all on the screen. Not even a slight blink, nothing. No sound as well. So I opened the back.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jan 03, 2017 | Samsung Televison & Video
Panasonic projection TV does not turn on.
Power LED flashes orange 1 x 5 secs. = 1 of 3 fans stopped. TEMP LED flashes 1 x 5 secs, = Temperature error. Lamp LED flashes 1 x 5 secs. = lamp ballast error. (check lamp 1st.)
Hope this helps.
Apr 18, 2010 | Televison & Video
Sony kv32v26 video flashes off/on/off/on/off/on/ audio is good
you have a bad crt if you open the set on the flyback you see 2button 1screen 1focus
you see the screen trun it up just a littet
you see it will stop but because if you trun it to far it will shut down. and you have line thur it .
just trun it a littet bet. hear what you are doing is trune up the screen livies up. but your crt is going bad. sorry to say that to you .
Jun 02, 2009 | Emerson EWF2004 20" TV
Cant delete folders
You can delete a file by
1.push menu
2.select folder
3.select file
4.press erase once and "delete" will blink on screen
5.press and hold erase to confirm deleting (or press stop to cancel)
Erase All Folders
1.select folder
2.press erase once and "delete" will blink on screen
3.press and hold record for 2 secs.(Folder/All/Delete will flash at the same time)
4.press and hold erase for 2 secs. again to confirm delete
If you want to erase all the files in a particular folder will leaving other folders files intact.
1.select folder
2.press forward repeatedly until "All" appears on screen
3.press erase-"Delete" will blink on screen
4.Press and hold erase for 2 secs. and all files in that folder will be deleted
good luck
Apr 08, 2009 | RCA RP5012 Digital Voice Recorder
Indesit wm12x wont finish cycle just clix through dial,can u help me ?
i suspect that you may not be draining water,if you watch the light flash it will flash at 1 sec interviles it will then stop for approx 3 secs and then start flashing again at 1 sec int,if you wait for it to stop for aprox 3 secs.when it start flashing again count how many flashes til it stops again for the 3 sec,thats is your fault code,if it is 10 or 5,then its will be your pump blocked or inop.
Apr 05, 2009 | Indesit W 123 Front Load Washer
Monitor is black. Press power on monitor/screen shows for 1 sec
You will need a new monitor screen. I have had two screens go on me recently and what you describes normally happens
Dec 10, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Sony bravia
what model of Sony is it? On many of the Sony projectors, a 3 flash error code indicates the lamp is not properly seated/installed or the lamp door is not closed properly
May 15, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
The screen flashed and die really easily.
You need to go to Settings, [on the iPod] then go to Brightness. Mess with that and see what you like. I, personally, like my screen to be at 25%.
If that's not the problem, try going to Backlight in Settings. It gives you choices or Off, 2 secs, 5 secs, 10 secs, 20 secs, 30 secs and Always On.
Another issue that I've had is when I'm turning my iPod on from the Sleep option. The screen flashes and turns black when I do this. If you press the Menu button or any of the other options on the Scroll Wheel.
If that doesn't help you with your problems, then I probably haven't had them and suggest that you Google your issue.
Feb 16, 2008 | Apple iPod nano 3rd Generation
ViewSonic VX710 17" Flat Panel LCD Monitor Logo
248 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
