Question about Xerox Phaser 6300N Laser Printer
Re:help Yes, that print out looks great. Sharp and crystal clear.
    Genius:
  • 3,587 Answers
Good..so the printer is fine, right?
maybe it's a program issue with your computer?
send me a note by googling me(per instructions on my profile) and maybe we can solve this.
Posted on May 28, 2008
It says Rendering in the spool section of Job Status
I know this is from months ago but I'll post this reply so people in the future can see it:
You probably need to do an image memory clear on the machine to clear out the corrupted print job, delete it from the queue on your computer, then reboot the machine.
To do an image memory clear on a Sharp MX-4111N:
1. double tap the home button
2. touch the firmware version in the bottom right corner(it doesn't look like a button but it is)
3. a number pad will pop up, hit P * C *
4. you should now be in the simulation menu, hit 66, Mono, 10, mono, execute, yes.
Give the machine a minute to process, then it should reboot automatically. If at this point you cannot print, you need to clear the print queue on each computer and do another image memory clear.
Copier Collin Houston TX Copier and Imaging Expert
Sep 30, 2014 | Sharp Mx-4111n Multifunction Copier
Apple iphone 5s 4.4 new verision from hopewholesale.com
yes,it is sim card, working great, can get good gift from hopewholesale.com
Nov 27, 2013 | Apple 5ss Clear Crystal Bling Back Case...
DATA LIGHT FLASH BUT NO PRINT OUT IS COMING SHARP MX2300 N
Watch this video on how to perform an image memory clear on the sharp.
on your model you'd start by pressing # * C *, then 66 start, 10 start, execute, yes.
May 30, 2013 | Sharp MX-2300N Color Copier
SHARP MX-3100N CODE E7-06
MFP -Image data decoder error
Try to clear code. enter sim with program key- asterisk*-clear key- asterisk*(P-*-C-*) enter sim 14 print key execute yes clear all machine will reset. if code comes back it is not just not a fluke and you may have another issue.
Aug 28, 2011 | SHARP MX-3100N
Great pictures look flat and dull when sent as e-mail attachments
probably is the computer,get one of your photos developed from a machine and see if it comes out well,then you'll know if its the camera or the computer.
Mar 18, 2010 | Canon EOS 500D / Digital Rebel T1i Digital...
I have a sharp copier MX2700N with an error code of TK2. Will this cause the copier to stop printing and is there a way to clear it
The TK2 means its time to replace the secondary transfer belt. Depending on your copier and driver setup it may prevent you from printing. If you open your print driver properties and go to the ports tab and then click on configure port button, in the next window uncheck "SNMB printing" option - this should allow you to print. You can clear the maintenance code by going into the SIM mode. press the following keys one after the other "P" "*" "C" "*" then enter 24 and "copy start key" then enter 4 (maintenance clear) and copy start key then highlight the items you want to reset and press execute then yes. restart the copier by pressing the "CA" key. do not make adjustments to other sim code items as it can render copier useless!
hope that helps.
Apr 06, 2009 | Sharp MX-2700N Color Copier
Sharp copy/printer to staple Crystal Reports
this should be an option in your print driver make sure when you set up the print driver you added the accessories ie. a finisher
Mar 26, 2008 | Sharp AR-M550N Copier
Sharp AR-M237 Grayscale Copier Problem
Yes.There should be settings to enhance that in your print driver properties page.
Easiest way to access that is to open a document and click "file' then 'print and that will bring up your printer options.
Look around the print driver for ways to enhance your prints.
Most drivers have several options in graphics areas to make adjustments.
You can access printers from the controle panel and also right click the printer and select properties to access it.
There definatly are ways to adjust that.
Hope this helps you some.
Dec 19, 2007 | Sharp AR-M237 Copier
Picture quality is terrible...not sharp and crystal clear
Set the aspect ratio to 16:9 and the top and bottom of the picture will reurn. Promise.
Try adjusting your contrast to help the filmy looking picture.
Dec 09, 2007 | Sylvania LC370SL8 37 in. LCD Television
Cant enter simulation in sharp ar m207
Is that the right sequence for your model? The Sharp copiers I used to work on used either "CROP" (Clear, Reset, '0', Print) or "CPOP" (Clear, Print, '0', Print). I believe Reset and Interrupt is the same key.
Sep 14, 2007 | Office Equipment & Supplies
Xerox Phaser 6300N Laser Printer Logo
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
