Computer problem Actually I have an optical mouse. It is not working, although its light is on but the cursor is not moving.If you can help me then please fulfil the same.
  • killua Jun 17, 2008
    im having problem with my pc in microsoft ps\2 mouse it can't detect with my pc...i tried several remedies but still i can't solve the promblem.. then,i tried to fixed it in the registry and i did.. my ps\2 mouse restore.. but suddenly, i accidentally,change the setting in the registry when i tried to review how was i did to restore it..right now i can't use a mouse in my pc...hope u can help me...
  • RCKp Jul 24, 2008
    my optical mouse is not working. How do I reset it? I put new batteries in and rebooted and stuck a pen in the little hole on the bottom. A red light flashes and nothing happens?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 359 Answers
Make sure that you have fresh batteries, and you might try to change them twice. One time could result in still not getting a fresh set of batteries.
Be certain to shut down your machine, and when it comes back up, depending on the model mouse you have, if you have software installed, you should be able to check battery status from there. If you have further problems, please post back, otherwise thank you for rating FixYa!
Posted on May 28, 2008
My mouse cursor will not move on the screen when I try to use my new wireless mouse. The light comes on on the bottom of the mouse and the USB is plugged into the computer. The USB blinks red when plugged...
Hello, hope this isn't a silly suggestion, but have you pressed the 'connect' buttons on the mouse and receiver so that the 2 devices can synchronize?
Regards,
nicam49
Dec 29, 2010 | GE Wireless Optical Mouse
Sir, i want to know about the optical mouse in detail. what is the important point of it to use. thanks, tin
Optical mouse was developed by Agilent Technologies and introduced to the world in late 1999, the optical mouse actually uses a tiny camera to take 1,500 pictures every second. Able to work on almost any surface, the mouse has a small, red light-emitting diode (LED) that bounces light off that surface onto a complimentary metal-oxide semiconductor (CMOS) sensor.
The CMOS sensor sends each image to a digital signal processor (DSP) for analysis. The DSP, operating at 18 MIPS (million instructions per second), is able to detect patterns in the images and see how those patterns have moved since the previous image. Based on the change in patterns over a sequence of images, the DSP determines how far the mouse has moved and sends the corresponding coordinates to the computer. The computer moves the cursor on the screen based on the coordinates received from the mouse. This happens hundreds of times each second, making the cursor appear to move very smoothly.
Optical mice have several benefits over wheeled mice:
No moving parts means less wear and a lower chance of failure.
There's no way for dirt to get inside the mouse and interfere with the tracking sensors.
Increased tracking resolution means smoother response.
They don't require a special surface, such as a mouse pad.
Although LED-based optical mice are fairly recent, another type of optical mouse has been around for over a decade. The original optical-mouse technology bounced a focused beam of light off a highly-reflective mouse pad onto a sensor. The mouse pad had a grid of dark lines. Each time the mouse was moved, the beam of light was interrupted by the grid. Whenever the light was interrupted, the sensor sent a signal to the computer and the cursor moved a corresponding amount. This kind of optical mouse was difficult to use, requiring that you hold it at precisely the right angle to ensure that the light beam and sensor aligned. Also, damage to or loss of the mouse pad rendered the mouse useless until a replacement pad was purchased. Today's LED-based optical mice are far more user-friendly and reliable.
Thanks and regards,
Anil.B.R
Aug 18, 2010 | Computers & Internet
Logitech wireless optical mouse won't move computer cursor
Sometimes on wireless mice the contacts get warped or bent, so when you move it or set it down the batteries are not making full contact on both ends and the mouse loses power.
You can try adjusting the contacts or using a conductive material to make the contact (like a staple or paperclip), but you're probably better off spending the $10 or $20 to get a new mouse.
Jun 01, 2010 | Logitech Cordless Mouse
The cursor on my computer won't move at all. I
Do you have an optical mouse, is the light lit on the bottom? try another usb connect in the back of your computer if you have one, try another mouse.
Nov 06, 2009 | Dell Dimension 2400 PC Desktop
Mikomi 3 Button Mini Optical Mouse AM-9170U Not Working!
On an optical mouse, two thngs happen. The light shines out and a sensor reads the reflection almost like a camera image. Try some other surfaces, particularly ones which are not shiny. If that doesn't help, install the mouse on some other computer. If that works, reinstall your drivers on the first computer, removing the old ones as best you can (Control Panel...Device Manager...etc.). If it doesn't work on the other computer, check for any switches on the mouse (that would be uncommon) and for warranty coverage. Otherwise, the light sensor is probably broken and there is little you can do.
Sep 19, 2009 | Computers & Internet
Logitech v220 cordless mouse - worked fine for 6 mths - recently changed battery. worked fine. today, would not move cursor when on a white / light surface (although it has previously just fine). It...
Most opticals do not track on smooth white surfaces. It needs textures or color. Try pressing the "CONNECT" button on the bottom of the mouse and on the remote sensor.
Jun 17, 2009 | Logitech Cordless Mouse
IBM Optical Scroll Mouse doesn't work (Device Driver Problem)
connect your mouse. then restart your laptop do not remove mouse while restarting laptop. if not work after restart there is a problem in your mouse IC.
Jun 02, 2009 | IBM Optical Travel Mouse 2224P0480
USB mouse is jittery
Try the mouse on a different surface, also be sure you do not have any light directed at the mouse - this confuses the eye. Although no mouse pad is required for an optical mouse, sometimes it helps
Apr 01, 2009 | HP USB Optical Scroll Mouse
Msk1056 optical mouse lights on won't move cursor
REPLACE THE BATTERY AND UPDATE THE SOFTWARE AND PUSH IN THE RESET BUTTON ON THE BUTTOM OF THE MOUSE SO IT KNOWS WHAT FREQUENCE TO OPERATE AT
RODGANDYSR
Mar 05, 2009 | Microsoft Wireless Notebook Optical Mouse...
Computer problem
May 28, 2008 | Computers & Internet
Computers & Internet Logo
363 people viewed this question
David Payne
David Payne
