Question about Poulan Pro Chain Saw 46cc 20"
Engine stales while ideling - Poulan Pro Chain Saw 46cc 20"
  • 4,340 Answers
WEll, you have to adjust the idle speed and/or mixture. Sometimes you need to disassemble the carb and clean it to remove gum buildup and blockages.
Posted on Oct 05, 2010
WHAT COULD BE THE PROBLEM FOR A 2001 TOYOTA COROLLA TO IDEL AND WANT TO STALE OUT
Could be the Idle control valve or the Position sensor which keeps the Engine idling when in park, neutral or at a light when the clutch is depressed.
Feb 13, 2015 | Toyota Cars & Trucks
What couse a 1992 dodge ramcharger to randomly stal
this speaks of charging probs..change the starer solenoid...after that..mabe voltage regulator
Jan 08, 2014 | Dodge Cars & Trucks
When startn car engine cold idels high to low ,up
sounds like the throttle position sensor, I think that is the one that makes it idel rough
Apr 10, 2010 | 1987 Lincoln Town Car
My 2004 astro van staled affter ideling for 15 min. and will not start
tis the seson for fuel pumps, this is where i would start checking to see if there is a problem, try to turn the key on and off letting the pump build up presure and see if this lets you idle the van for a while again
if so you may have a problem with your fuel system, pump, presure regulator, filter, ect.
Mar 01, 2010 | 1999 Chevrolet Astro
Starts but will not idle
Most Lesabre have the 3.8 engine. The engine has a device called an automatic idel speeed motor or AIS for short. It's held on with two torx 20 screws and a 4 wire electrical connector on the side of the Throttle body. BUT BEFORE YOU GO REPLACING THIS DEVICE THAT CAN COST OVER $50. Try this first. Don't drive the car around this way just test it! Remove the big vacume hose from the power brake booster and put your finger over the end of the hose going to the motor. Have an asstant start the car and hold the gas so it'll keep running, trying to go as slowly as they can. Slowly remove your finger from the end of the hose and the motor should pick up speed. you should be able to get a good idle with your helper completly of the gas. if you do the idel motor is'nt working ( right) so your not done checking. Let's say you can't even get a fast idel that stays. The timing chain needs checked and other vacume or engine control codes need checked. Has the check engine light been on? ( with the engine running) . If it has the idel motor will set a code as will a cam senser and all the other sensers on the car. Follow code charts if a code is found. Most auto parts stores will check your car for free for codes but their recomendations very with the experience for the operator of the tool, and if they were good enough to make the mechanics money why are they in a parts store? If you can acheive a good idel playing around with the vacume hose then put it back on and go to the next step. Remove the Idel motor and clean it and the hole it came out of with oven cleaner. Just like cleaning an oven don't get it on you or the wiring part of the motor. With an OHM meter the pins will show two different pins hooked together ( two Pair) If you get only one it's bad. Every pin is connected to just one other pin. If not it's bad. You can get new cheap ones that are bad. I use cheap ones and cross my fingers. If they work the first time their good for a long time. Then you have to learn the idel. Try to learn the idel with the old one cleaned first. Start theengine and hold the idel with the gas pedel. after holding the speed at 2000 Rpm for two minutes ( a good engine will do this easy) let off slowly it should idel down slowly then (catch) and speed back up on it's own. If it does your fixed and go on your merry way.
Feb 15, 2010 | 1999 Buick LeSabre
Car keeps staling already changed trottle body did
check for engine vacuum leak using GUMOUT carb cleaner,spray around the intake manifold when the engine smoothes out you found the leak
Nov 08, 2009 | 2000 Dodge Intrepid
My car keeps staling
sounds like your fuel pump volume is insufficient. change fuel pump
Sep 28, 2009 | 1989 Jeep Cherokee
Ideling 1600 rpm onlywhen engine warm
please change the idling switch control valve assembly plus the sensor!
Jun 18, 2009 | Mercedes-Benz SL-Class Cars & Trucks
Staling or shutting off when stopping
tork converter locking when its not suposed to try having the codes read might be a sensor in the tranny hope this helps
Mar 03, 2009 | 2003 Mercury Sable
94 feep cheroke 4.0 HO skip at idel
it sounds to me that your throttle position senser has moved or malfuctioned. check it first #2 map senser they both work togather.hope this helps
Jan 20, 2009 | 1994 Jeep Cherokee Country
Poulan Pro Chain Saw 46cc 20" Logo
98 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
