Question about Sony VPL CX11 Multimedia Projector
How do I check how much power the lamp has left?
I'm trying to work out how to do the above. Any help would be appreciated!
Thanks!
  • 563 Answers
Hi tulsiamin
Unfortunately the Sony range of Projectors does not have this feature like the Infocus and ASK's has.
You will have to check what the time on your lamp timer is and then compare it to the rating the factory gave - which you will find in your specs. e.g. 2000 hours lamp life.
Posted on May 28, 2008
Mitsu hc3000 problem "red-green status light blinking and no input"
Heres what the manual says about REd / green lights
Unplug the power cord from the wall outlet and contact your dealer
And also this:
Check that the lens cap is removed.
It may take about one minute for the lamp to light up.
The lamp fails to light up on rare occasions. In such a case, wait for a few minutes
and then try again.
If the projector was turned off before the lamp was cooled down suf? ciently last time,
the fan may start rotating and the POWER button may not work after the power cord
is plugged. After the fan stops rotating, press the POWER button to turn back on the
POWER indicator.
Check that the intake vent is clean.
Set SCART INPUT in the FEATURE menu to OFF. (See page 25.)
Check that the lamp cover is closed. (See page 33.)
Check that the cables connected to the external devices are not broken.
When an extension cable is being used, replace it with the supplied cable for check. When
images are displayed correctly, add an RGB signal ampli? er to the extension cable.
Check the operation manual of the video device for its connection.
Mar 14, 2008 | Mitsubishi HC3000U Multimedia Projector
Service manual
It is not working for Toshiba TDP-XP2, when I hold three button above and plug the power on, the light at power button is blinking forever.
Any help will appreciated.
Apr 04, 2012 | Toshiba TDP XP2 DLP Projector
I replaced the lamp on my Proxima DS2 after I got the message to replace the bulb and it said about 7 hours left. The new lamp worked fine for several sessions and now I get the following message “Change...
first, if you are the changing the Lamp by your self did you respect the instruction below: - Never touch the lamp by your hand, the lamp is sensitive device that can be damadged if touched by your fingers. - Install the Lamp properly, and do not push it by force, slide it softly, because you can make the lamp body inbalanced with the protective case. have a look at this link it can helps you: http://www.fixya.com/support/t7149356-changed_bulb_self_after_year_half
Dec 07, 2010 | ASK Proxima Proxima DS2 and DX2...
The red and blue light on the front keep flashing when we try and turn the TV on...it was working earlier today.
If Power and Lamp lights blinking 'alternately' it shows problem of temperature arise abnormal and reason could be blocked fan or air flow in tv is insufficient to keep it cool.
If Power and Lamp lights blinking simultaneously then it shows problem with lamp installation, need to inspect lamp cover is fixed in its position securely.
Let me know both lights are blinking at same time on your tv?
Thanks.
Aug 02, 2010 | JVC HD-52G786 52" Rear Projection HDTV
Tv won't turn on....
There could be few reasons that tv does not power On.
Power supply board got fried, deflection section got bad if its rear projection tv and if its dlp tv, lamp could be dead etc.
Model number and brand of your tv will show us what kind of tv is that to provide you some helpful info about problem.
Jun 13, 2010 | Televison & Video
2004 GMC Yukon Denali XL - left side Headlamp issue
plug may not be completely installed? wire the low and high to each other.
Jan 25, 2009 | 2004 GMC Sierra Denali
How to check for lamp life of my mitsubishi multimedia Projector xd 450u (DLP)
This should work:
How to reset the operation time meter
Plug in the power cord, switch on the projector, and
reset lamp time by pressing the (left and right arrow) and POWER buttons on the control panel simultaneously.
Important:
• If the 3 buttons was not pressed at the same time,
the lamp time may not be reset.
• Please confirm the TEMP indicator illuminates
about 2 seconds and the lamp time has been
reset.
• The projector will not turn on if you do not secure
the lamp lid.
• You must reset the operation time meter after you
replace the lamp.
• Do not reset the operation time meter unless the
lamp has been replaced.
Jul 14, 2008 | Office Equipment & Supplies
Canon np 6030
Replace the exp lamp and try again after an error clear.
Jun 25, 2008 | Office Equipment & Supplies
Sony VPL CX11 Multimedia Projector Logo
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
