Question about Sharp R-630D Microwave Oven
DISPLAY OUT THE DISPLAY ON THE UNIT IS OUT AND CAN NOT OPERATE THE MICROWAVE
  • DAVIDES May 28, 2008
    How do I do a hard reset to microwave?
    the display will scramble for 2 or 3 seconds and then it will go out
  • 426 Answers
Check the connections to the display on the microwave... make sure that nothing is burnt.. and that the ribbion cable is connected... are you able to pull the microwave apart your self? i would be more than happy to walk you thru it if you have a webcam...also make sure that all wires are tight does the micowave light come on"?
Posted on May 28, 2008
    Sergeant:
    Champion:
  • 347 Answers
Hello Davides,
The problem with your microwave display is a blown or damaged fuse inside the display.
  • Santiago Vallejo
    Santiago Vallejo May 28, 2008
    There is no easy solution for your problem, it needs to be oppened up andreplace the fuse.
    You should call their main support number and ask for warranty if you still have it.
    1-800-237-4277, 1-800-BE SHARP
    Good luck,
    Dahaka
    Genius:
  • 1,142 Answers
Did you try doing a hard reset to the device
  • 3 more comments
  • Maanita Chadha
    Maanita Chadha May 28, 2008
    unplug the unit from the power source, waiting at least a minute, then re-connecting the power cord
  • Maanita Chadha
    ocate your fuse. Most microwave fuses
    look like the one pictured to the left. They are usually an inch or two
    long. Each end is metallic and the center is either ceramic or glass.
    To
    get to the fuse, remove the outer cabinet of the unit, which is usually
    held in place with a few screws. Once the outer cabinet is removed,
    follow the power cord into the unit. It will take you to the fuse
    holder, where the fuse sits. The fuse holder is located two or three
    inches into the unit, and may be attached to a power board.
  • Maanita Chadha
    Decide if your fuse is blown. A blown glass fuse will produce flash
    burn marks on nearby surfaces, or it will be completely black on the
    inside. The internal fuse wire (filament) will be melted and blackened.
    Ceramic fuses give no outward signs of having blown. To determine if a
    ceramic fuse is blown, test it with an ohmmeter. If the ohmmeter reads
    zero ohms, your fuse is fine. A reading of infinite ohms means your
    fuse is blown.
  • Maanita Chadha
    Replace the blown fuse. Pop it out of its holder and snap in a new one.
    You can squeeze the fuse clips together with your fingers in order to
    tighten their grip. Replace the unit's outer cabinet, plug it back in,
    and test to see if it is running properly. DO NOT run the microwave
    with nothing in it.
  • Maanita Chadha
    NOTE: Fuses do not usually blow on their own. A fuse may blow
    because of problems with the interlock switches or with high voltage
    circuitry. It is also possible, though rare, that a power surge will
    cause a fuse to blow.
My SMH9151W Samsung Microwave displays a -SE- or a -5E- and will not operate. I unplugged over night and still will not operate
I had the same issue on a 2010 smh9151w samsung microwave after installing it and using it with no problem for 5 days. The second time we unplugged the microwave and turned the circuit breaker off and on we didn't reset the clock on the microwave so the display shows :0 and it has been working for 7 days straight now. Fingers crossed that this is a long term solution. Hope this helps. Thanks!
Mar 20, 2012 | Samsung Microwave Ovens
I have a JVM1850 that was installed 4 years ago. The unit was working fine, then a day ago I received an error display requesting a charcoal filet replacement. No filter is needed since it is vented...
I have a JVM1850 White microwave-over the oven-installed 3 years ago. Last evening the unit would not turn off. The inside light and fan continued to run, however, the microwave was not working.
All the controls and functions seem to operate, but when completed, the unit remained working, as stated above, with the door opened or closed.
Sep 18, 2011 | GE JVM1850 1000 Watts Microwave Oven
The microwave will not operate or turn on even though it has power
The main fuse in the microwave has blown, this is often caused by a defective door switch.
Feb 13, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
No display will not operate no fan no light
Ok, there is an in-line fuse that is located inside the unit on the power supply board. if this fuse is damaged, replace it. If this fuse is ok, replace the entire power supply board.
Jun 01, 2009 | Whirlpool GH4155XP Microwave Oven
Sharp Microwave Lights Up, But Won't Rotate or Cook
Hi. I would suggest checking out the door switches. There are usually 3. If one of those has failed then the microwave won't operate because of safety reasons. Best to replace all three. If the display on the unit is still fully operational I'd say go for the repair.
Mar 18, 2009 | Sharp Microwave Ovens
UNIT CONTINUES TO OPERATE AFTER OPENING THE DOOR
if nit continues to operate whilst the door is open.
then bin it straight away also damage it so that no one else can use it. microwave energy is being transmitted and can cause medical problems
Feb 21, 2009 | Kenmore 63762 Microwave Oven
GE Spacemaker Microwave display is flashing. Keypad is unresponsive. Boiled water for a long time under the unit. Person attempted to operate microwave. Loud boom and then this. There is a smell of...
Microwave is 16 years old. Replaced it. Service call was going to be half the cost of a new one with no assurance that problem could be fixed once it was diagnosed.
Jan 26, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
H98 error
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Dec 31, 2008 | Panasonic NN-H965 Microwave Oven
Neff HTHB86K Microwave oven.
The microwave unit is faulty as you can read from the display or the controller isn't working correctly, you should take your MW oven to an authorized service center. It can be repaired by yourself but it's highly dangerous because it has high voltage inside and microwave energy.
Feb 15, 2008 | Microwave Ovens
Sharp R-630D Microwave Oven Logo
208 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
