Question about Panasonic PT-AE700U Multimedia Projector
Yellow middle, Blue Exterior
The middle of the screen in a roughly oval shape is yellow tinged - appears to be an absents of blue while around it is blue tinged.
  • 1 more comment
  • Anonymous Dec 10, 2008
    I had the blue haze growing across the screen forever, then one day this happened (the yellow middle oval with blue haze still on the outsides). After removing the blue panel, the burn is obvious. Some on the avs forum have said that just the blue can be replace, others say the whole optical block...which is it? And where can I get the parts?
  • Rumorhazit Dec 13, 2008
    Does anyone know the approximate cost of the Blue LCD Polarizer? I have the exact same problem and am wondering if I should seek repair to unit or sink it.
    Thanks for any help.
  • Anonymous Feb 01, 2009
    I have the same problem with only 4000 hrs. I will not buy another panasonic again.I am finished with projecters...junk!!!!!
  • 563 Answers
Hi Druaga
This is a Blue LCD Polarizer that will have to be replaced if the spot shows yellow.
You will find that this will only get worse as time goes by.
Posted on May 28, 2008
I have small blue dots and a yellow shadow in the middle of my screen
The model indicated uses what is called a Optical Light Engine, it is a very expensive part and likely is your problem---not much else will cause this trouble.
Let me know if you have questions.
Dec 02, 2011 | Sony Grand WEGA KF42WE610 42" Rear...
Yellow stripe across middle of the picture
yes rteh color of the wires(ends)red,blue,green,sounds like they may ahve gone bad or are interchanged, what does it do with a dvd picture
May 23, 2009 | Hitachi 42V710 42" Rear Projection HDTV
Purple tinged camera screen
all you have to do is, (Now, I know this may sound crazy but it will help) Take apart your camera. Disconnect the black cord wrapped around the blue cord. Pull out the yellow cord out and throw it away. That yellow cord is a virus which is causing your screen to go purple. Now reconnect the black cord and unwrap it from around the blue cord. This will cause your screen to not only turn back to normal but to hold 2x the space of pictures you would usually hold. If this doesn't work, then stop being lazy and buy yourself a new camera. Yes, I'm talking to you granny!!
Good day my fellow American citizens. I really do hope this works. Thank you for your time. ;)
May 21, 2009 | Kodak EasyShare C713 Digital Camera
Sharp notevision xgnv6xu oval yellow spot
I have a similar issue with yellow pattern on the left and top right of my screen. Took it apart and found the blue lcd had damage that matched the yellow area that was projected. I thought it was the lens but it was the blue lcd .It has gone bad and no replacement. Are you interested in selling the bulb or the whole projector? I have since purchased another projector and am keeping the bad one for spare parts. Hope this helps..Ben
bgrenco@aol.com..
Jan 18, 2009 | Sharp Notevision XG-NV6XU Multimedia...
Yellow and blue on screen
I am slightly confused about the model of the television, because a 46F500 is a rear projection set that doesn't have a lamp. It has 3 picture tubes and I have a few of them in my shop right now that have the problem you reported. What we do to this set when it develops a convergence issue is to check each resistor around the convergence chips for discoloration, and replace any of them that have changed in value, along with the STK392-150 ic's. If you don't have an ohm meter and solder/desolder equiptment, you can usually get a shop to do this repair for 150.00 to 350.00. Parts will be 50.00 and labor , the rest, depending on the quality of repair shop that you use. Good luck, Russmann.
Nov 16, 2008 | Hitachi 46F500 46" Rear Projection...
Which part(s) to replace?
If the screen looks OK after extended cooling is provided, you may just have a failed cooling fan.
Turning the blade with the power off will tell you if the bearings have failed or stuck, or just look at it with a flashlight to see if it is turning.
Check this first before you start replacing boards.
May 05, 2008 | Samsung HCN4226W 42" Rear Projection...
Panasonic PT-AE700U Multimedia Projector Logo
993 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
