Question about Radio Shack Pro-94 Scanner
On a Pro 94, how do I go to, and listen to a specific frequency (one that is not stored in a memory bank)? Neither the Radio Shack manual, or the easier 94 manual describes this, and it appears to be a basic function. I can be notified at tedv88@cs.com. Thanks.
    President:
  • 2,761 Answers
Sorry, but your PRO-94 scanner, like most models, does not have a direct tune mode. To listen to a frequency it must be either found during a search or programmed into a channel. I suggest that you designate a bank, or a portion of one, for the storage of temporary frequencies. That way you can recall and review those frequencies, and delete them as you want to.
Bill B
Listening in since the 60's
Posted on Oct 05, 2010
Owners manuel for Radio Shack Pro-2039
Nope... seems that since Radio Shack folded up it's tents almost all of the old links have dried up! And GEE, I had one of these scanners but have no idea where it is now?
A FEW of the exceptions follow...
PROGRAMMING
This Link is for the Pro-2021 BUT your PRO-2039 programming will be much the same!
Radio Shack Realistic Pro 2021 Scanner Programming and Overview
This link may help you too but it's a much more advanced scanner!
RadioShack Pro 2050 Scanner Programming Tutorial Police Scanner
PRO-2039 SPECIFICATIONS RigPix Database RadioShack Realistic Pro 2039 20 7462
GENERAL Type:VHF/UHF receiver/scanner Frequency range:66-88 / 108-174 / 380-512 / 806-960 MHz (Europe) Tuning steps: Mode:AM/FM Channels/memory management:200 regular in 10 banks @ 25 ch/sec
10 monitor Power supply:Mains Current drain/power consumption:Max 13 W @ 230 VAC Antenna impedance/connector:50-75 ohms / ? or built-in telescopic whip Dimensions (W*H*D):190*80*180 mm (7.5*3.12*7.12") Weight:1 Kg (2.2 lbs) Other features: RECEIVER SECTION Receiver system:Double conversion superheterodyne
1st IF: 10.7 MHz
2nd IF: 455 KHz Sensitivity: Selectivity: Image rejection: AF output power/speaker:1 W at ?% distortion / 8 ohms External speaker connector: MISCELLANEOUS Manufactured:China, 199x-199x (Discontinued)
For "PURE AUDIO" there is a MODIFICATION/Link:
http://schreiber.pl/mods.dk/mods.php3-radio=radio_shack&model=pro-2039&selectid=1855.htm
ANTHONY
Dec 21, 2017 | Radio Shack Radio Communications
How do i work a pro-94 radioshack police scanner?
https://www.manualslib.com/manual/137757/Radio-Shack-Pro-94.html
Specs are not needed. I suspect you need the local frequencies and how to program them. The scanner CAN be set to scan for the local frequencies. Have a pad and paper ready and write down the ones you want to keep.
You must obtain the local frequencies, try Google. They are public knowledge, but hard to find. Local Hams or a Radio Shack will likely have the frequencies. Be nice, be polite, no one has to give you this information.
Jan 29, 2018 | Radio Communications
Radio shack pro 135 want to scan only one band
  • Now if your wanting to scan one bank or your radio and the stored frequencies are still separated in different bands (banks) then just push the number on the keypad that you want to not scan. The number on your screen will show the banks that are active. Do this until only the bank you want to listen to is visible. To scan them again just press the corresponding number again.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Oct 01, 2011 | Radio Shack Radio Communications
Hi - I don't know any frequencies to enter on my PRO-94. Is there a way that I can just scan all local channels?
You can run service searches as described in your manual to locate active frequencies, but those won't help with trunked systems. You can find a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, by visiting:
www.RadioReference.com
Bill B.
Mar 06, 2011 | Radio Shack Pro-94 Scanner
Pro 84 scanner how to search for frequencys between 144.00 and 148.000
You can download a copy of the user's manual here if you need it. It doesn't look like you can set your own scan range, but you can have the scanner search by pre-defined service. Here's what the manual says about searching:
service search
You can search for weather, ham, marine, aircraft, or
police (fire/emergency) transmissions without
knowing the specific frequencies used in your area.
The scanner is preprogrammed with all the
frequencies allocated to these services. To use this
feature, press FUNC + SVC. SRCH appears and the
scanner searches starting with the weather service
bank. To select a different service bank, repeatedly
press FUNC + SVC. Service mode appears on the
display.
When the scanner stops on a transmission, quickly
press HOLD to stop searching and listen to the
transmission. HOLD appears. In this mode, you can
press FUNC + ^ or FUNC + v to step through
the frequencies.
To release the hold and continue searching, press
HOLD. Or, if you did not press HOLD, simply press
FUNC + ^ or FUNC + v to continue searching.
It goes on to explain how to store frequencies as you find them while searching.
Feb 24, 2011 | Radio Shack Pro-84 Handheld Scanner
Need help with installing frequencies into scanner. Some how all of mine got erased.
Detailed programming instructions can be found in the factory operating manual for your scanner. You can download and print it, at no cost, here:
http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/2000516_PM_EN.pdf
For a comprehensive database of active frequencies in your area, visit:
Please get back to me if you have any specific questions - I would be happy to work with you to get the scanner back up and running.
Bill B.
Nov 01, 2010 | Radio Shack Pro-94 Scanner
Program scanner radio shack pro 94 for listening to cell phones
Heads up that in some countries / States this can carry severe penalty.
I cannot give any direct information and it up to you to make sure you apply to the laws of your state etc
A good source of information are the two sites below
Frequencies
Scanner software
With any luck you will also find either the manual or a link to it there as well as quite a lot of other useful information that would give you guidance as to the legality
Oct 10, 2009 | Radio Shack Pro-94 Scanner
Scanning
The problem could be your location, altitude, antenna, or wrong frequencies for your area. Here's a link to Radio Reference where you can check their database for active frequencies in your area.
http://www.radioreference.com/apps/db/
Jun 18, 2008 | Radio Shack Pro-94 Scanner
Scanning Freq
According to the manual the Pro 94 should cover that frequency.
Please note, certain frequencies are blocked in some countries. I see no reason why 217.031 should fall into this category although the closest may be 217.030 which should be close enough
Take a look at the manual >HERE< which should help you to program your scanner.
Best wishes...:-)
Mar 17, 2008 | Radio Shack Pro-94 Scanner
Programming channels
Hello ... IF YOU HAVE A COMPUTER YOU CAN MAKE PROGREMING, DETETINMG AND TRUNKING A BREEZE. IF NOT I FOUND THAT ALL FIRE AND POLICE TRUNKING ACTIVITIES ARE BETWEEN 840.0000 through 900.0000. WHEN YOU WANT TO SAVE A CHANEL TURN OFF RADIO AND TURN BACK ON SELECT THE DESIRED CHANNEL YOU WANT. THEN PRESS "PGM" AND ENTER YOUR FREQERNCY... PRESS ENTER AND IF YOU WANT TO ADD ANOTHER CAHANNEL ... HIT "PGM" AGAIN AND FREQ. AND ENTER. YOU CAN KEEP DOING THIS TILL YOUR DONE GROGRAMING .. THEN JUST HIT SCAN AND IT WILL SCAN ALL THE FREQ.S YOU HAVE ENTERED. HERE IS A SOFTWARE PROGRAM THAT CAN LOOK UP ALL FRQ ANYWHERE IN THE US AND WITHE A PLUGIN DOWN LOAD ALL THE CHANNELS. BuTel software home page ARC-433 software for Radioshack PRO-433 / PRO-528 / PRO-2051 'ARC433 is now available!' -------------------------------------------------------------------------------- ARC433 (US$ 29.95) is dedicated software for the RadioShack PRO433, PRO528 and PRO-2051 and is the most versatile software available for the Radio-shack PRO-433 / PRO-528 / PRo-2051. Screenshot from our memory editor: the most versatile memory editor available on the market: -------------------------------------------------------------------------------- Overview of options in ARC433: Order ARC433 now online using PayPal/credit card or call Santa at 1-800-SCANNER ARC433 supports the Radioshack PRO433, PRO528 and PRO2051 models in one single software package. ARC433 includes THE most versatile memory editor available on the market. Radioreference.com import option for conventional and trunk systems! Programming your scanner was never this easy! Enhanced CSV file import and 'mapper' Paste Frequencies DIRECTLY from any website using 'Paste Special' Setup channels in an easy, spreadsheet type interface. User Manual (45 pages, PDF file) Store Unlimited number of configurations on your harddisk. Copy/Move/Swap memory banks / memory channels Compatible with Windows 2000 / XP. All updates are free for registered users Easy cut/copy/paste data between channels and banks. Move channels up and down with quick move buttons Export CSV data Fill down/series option Full clipboard support for import/export data to/from other applications Easy data toggle with mouse double click or space bar or keyboard shortcuts Sort frequencies per bank Remove duplicate frequencies Easy Fill for setting up new banks in a few seconds (enter a start frequency and a step, and easyfill will calculate and fill the selected bank) Extra Dummy bank for storing temporary data while you are re-organizing your scanner channels. Print option System Requirements: Windows XP/2000/Vista PC interface cable 20-047 for USB or PC interface cable 20-289 for serial port Use other cables at your own risk! Use the ARC433 demo version to verify communication works before purchasing the software! All software sales are final. Order ARC433 for PRO 433 / 528 now online using PayPal or a credit card or call 1-800-SCANNER. -------------------------------------------------------------------------------- Screenshots:
Apr 16, 2007 | Radio Shack Pro-95 Handheld Scanner
Radio Shack Pro-94 Scanner Logo
136 people viewed this question
Top Radio Shack Radio Communications Experts
Jason
john milligan
Steve
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
