Question about Fisher and Paykel E522BRXFD Stainless Steel Bottom Freezer Refrigerator
Fridge not working, freezer is, what to do? - Fisher and Paykel E522BRXFD Stainless Steel Bottom Freezer Refrigerator
  • Fisher and P... Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 05, 2010
My Hotpoint Fridge/Freezer only works with the freezer at the bottom and the fridge is fed from the freezer via ducting to the fridge at the top ---- can anyone tell me why the freezer works perfectly and...
There has to be something restricting the air flow to the fridge. If the fan is running blowing cold air into the freezer, then it should be cooling the fridge too. Empty out the fridge and freezer and use a blow drier to blow hot air into the duct work. There could be an ice blockage not visible in the duct work.
Aug 15, 2014 | Hotpoint Refrigerators
I have a Whirlpool wbm46mw Fridge, the freezer is working ok but fridge not getting cold, any suggestions,Thanks
Empty fridge and if possible put steam down vent behind the cover in the freezer section. or hot water. it will com out in the fridge so be carefull. this unblocks the aif feed from the freezer to the fridge section. also make sure the fan is working.
Oct 04, 2013 | Engel Freezer 22 Qt. Fridge/Freezer
Fridge works freezer does not Zannussi
the fridge will soon stop to! all cooling goe to the freezer first! look to see if there is frost in back of the freezer if not it might be low on charge
Apr 11, 2010 | Freezers
Side by side freezer, fridge. freezer works
try to look for the fan inside your fridge, see if it is working, if not, have it replace
Nov 11, 2009 | Refrigerators
Freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
freezer not working on ariston... Solve freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every... (More) freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
Sep 13, 2009 | Freezers
Freezer works, fridge part does not
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Aug 21, 2009 | Refrigerators
Creda R335NW Fridge/Freezer. The fridge section is not cooling down anymore, The freezer is working ok. Any ideas please?
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Jul 03, 2009 | Refrigerators
The fridge is cold but the freezer won't freeze
It has seperate cooling circuits as you describe the problem can be a leak of refrigerant in the freezer circuit.if there is no heating up in the freezer condensing coil.It has to be check for the leakage.
Jul 01, 2009 | Freezers
Fisher and Paykel E522BRXFD Stainless Steel Bottom Freezer Refrigerator Logo
154 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
