Question about Timex 27191 Wristwatch
We have a R5 womans watch and can't get the back off to change the battery, any suggestions?
How to change a mt516 battery in a woman's eco drive watch
Take the watch to a jeweler for battery replacement.
Feb 21, 2018 | Watches
Why should every lady watch Wonder Woman?
Wonder Woman is one of the great Super Hero movies that is capable of changing people's mindset about women. It is a Women empowerment fiction film.How a Woman rises against the wrong, & defeats them, this story tells the magnificent journey of Diana. Hats off to the director Patty Jenkins, Gal Gadot has done fabulous job in the film.
Jul 17, 2017 | Watches
How do I change a battery on a judith ripka womans floating crystal watch
  • Open back
  • Find battery holder. Note mounting position for later reference
  • Identify battery type
  • Obtain replacement battery
  • Remove old battery. Install new
  • Check operation
  • Reinstall back
  • Set time, etc.
OR
Take your watch to a jeweler who, for a reasonable sum, will replace the battery.
Take your wathchT
Nov 28, 2016 | Crystal Watches
Battery for SP299131YLDW
You may have to open it up and find the type number on the battery.
May 16, 2016 | Croton Watches Croton Womans Brass Gold...
How should i have a woman's seiko watch fixed?
Take it to a reputable watchmaker/jeweller. Or contact seiko direct.
Jul 22, 2014 | Watches
2006 bought, stopped working, does it need a battery change? Is it worth changing the battery?
It looks like you paid over $100 for the watch, I suggest to give a try changing the battery. Actually if you take it to some watch repair shop.. some of them will NOT charge you if replacing the battery does not bring your watch back to life!
I hope this helps!
Marcelo
Oct 23, 2013 | Seiko Coutura Chronograph Watch
How iI open a casio 705 woman watch?
Thank you for contacting FixYa.
You will need:
  • A jeweler's screwdriver- Either flat head or Philips, depending on the model of watch.
    A cup or small box-This is to hold any screws.
  • How to change a Casio watch battery:
    1. Spread a cloth over your work area The cloth will help you avoid damaging the finish on your watch.
    2. If necessary, remove the watch band Removing the band gives you easier access to the back plate.
    3. Remove the back plate For some models this means using a screwdriver to gently pry it open, and others require removing screws. Keep small screws in a container to avoid losing them!
    4. Take note of the rubber seal Sometimes they need to be reinstalled in the same orientation. You might even want to use a marker to make a small "match mark" before removing it.
    5. Locate the battery It looks like a small metal button.
    6. Remove the battery You might need to loosen (not remove) a small screw and slide a latch out of the way. For other models, it's as simple as popping open a strap that is stretched across the cell.
    7. Install the new battery Make sure it's in the same orientation as the old one. They usually go in with the positive (+) side down.
    8. Perform a reset Do this by touching one tip of the tweezers to the AC contact, inside the watch, and the other tip to the back of the watch battery.
    9. Make sure the watch is working properly Carefully lift the watch to do this. Don't turn it over or the watch movement might fall out.
    10. Reassemble and seal the watch Perform steps one through four in reverse order to reassemble your watch.
    Best regards. Jewel
    Sep 14, 2010 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
    How do i open this thing? pry off or screw off? seiko womens 100m.
    I have no ideal. All i know is that it is a Seiko womans watch and Seiko has numerous types of backs on them!! If it has 6 notches on the back, then yes, it is a screw off and it takes a special tool to open the back. Please take to a local jeweler who sells SEIKO to have the battery replaced.
    Aug 23, 2010 | Watches
    Cannot get the back off a womans pulsar watch
    some are twist of which u need a special tool.. dont take it to walmart, they are only a dollar or 2 cheaper then a jewelry store
    Oct 06, 2009 | Pulsar PPG672 Ladies
    I have a Fossil JR8103 woman watch with leather strap and the face of watch is held on by two silver dots. I can't figure out how to get the face off so I can change the battery. Help!
    DONT try to change a watch battery yourself unless you have crystal press to close it and thats if the case back pops off...if it screws on then you need a case wrench to open and close it! Better to seek out a local watch repair business and avoid Walmart! :-P They arent trained to repair watches...Ive fixed a lot of their mistakes!
    Aug 09, 2008 | Fossil Watches
    Timex 27191 Wristwatch Logo
    157 people viewed this question
    Top Timex Watches Experts
    Ansel Alberto
    Ansel Alberto
    Brett Duxbury
    Brett Duxbury
    Vladimir Frolov
    Are you a Timex Watch Expert? Answer questions, earn points and help others
