Lights on tower recognize drive. Running Xp on an e machine. Drive will not recognize, data, music or dvds. Have tried all solutions as well as uninstall. Although it worked on and off by chance over the last month it no longer functions at all and is NOT a hardware problem. Please help!
  • 27,725 Answers
Have you checked your leads
One bad/faulty lead can cause a computer with lots of problems
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Posted on Oct 05, 2010
My venus ds3 is not working on my new HP mini tower
What exactly is it not doing...is the machine not seeing the external drive, or is it recognized by not showing the data on the drive? What happens (or doesn't happen) when you connect it to the machine? What OS does the machine have installed? Have you tried the drive in another working machine since this occurred?
Oct 17, 2015 | AMS VENUS DS3 Aluminum Black 3.5" External...
DVD drive will recognize data discs but will not recognize DVDs. I.e. when you place a DVD in the drive and open windows explorer you are told that there is no DVD in the drive. However it will...
try running the fix-tool provided by Microsoft on this web page
http://support.microsoft.com/gp/cd_dvd_drive_problems
If that fails then my suspicion is that either
1) the drive has failed
or more likely
2) because you don't have any DVD burning software, windows can't understand the blank DVD-RW disk. This basic packet-burning software installed with XP CANNOT write to DVD disks.
However there is a bit more to it than that - the Microsoft CD burning software (which is a cut down Roxio product) cannot co-exist with any other packet burning software (e.g. DLA, In-CD or simuilar) so if one of those is installed you have to DISABLE the MS CD burning capability on the drive settings tab. Even worse, Internet Explorer 8 is not compatible with DLA - which is included in quite a few CD/DVD suites including many of the later Roxio versions
My advice would be
1) un-install any CD or DVD burning software on the machine
2) disable the MS CD burning
3) run that Microsoft patch
4) Install some DVD burning software but DON'T install the packet writing software part of it
Note that after installing that patch you may also have to reinstall any DVD playing software
Nov 21, 2010 | Acer Computers & Internet
I cannot open cd's on my emachine 4260. Can you help? The discs have data on them (Knitting patterns)
It could be a proiblem with the cd-rom drive or the computer. You can try and run a cd lens cleaning kit in the drive to try and clean the lens. Also try using a different SATA or ATA cable for the drive depending on which one it has(the cable could be bad). I would take out the cd-rom drive and try installing it into another computer to verify if the drive is working. If the drive acts the same in a different computer then replace the drive. If it does not then there might be a hardware problem with the e-machine motherboard.
Nov 11, 2009 | E-Machines emachines (emachinees) CD-ROM...
Device reads cd but will not recognize a dvd
you may need the codec pack from
www.freecodecs.com
to play dvds. if you are running windows xp then it does not come with the codecs for playing dvds.
download the xp codec pack, run the installer and away you go.
Sep 26, 2009 | HP TS-H353B/HPBH Internal DVD Drive
DVD Drive not being recognized as a DVD drive
That is not unusual.
Several of my CD/DVD drives are listed as CD drives.
They still play and write DVDs.
The problem is cosmetic and not worth spending time on.
Now if you are trying to play a DVD movie you are going to need a CODEC (Coder/Decoder).
Windows XP does not include a CODEC to play DVD movies.
I use Intervideo WinDVD.
I hope this helps.
Aug 17, 2009 | LG (GSA-5169D) DVD RW Dual Layer Burner
Drive does not recognize DVDs
sir
its the problem with your DVD ROMS's lens. It has became weak . Due to which it is not able read the DVD. It cannot be repaired but you can do few things to make it work again.
  1. open the DVD ROMS if possible
  2. try to clean dust from inside
  3. and then try again
or if not able to open it
  1. buy a lens cleaner form market and try to clean with it .
Mar 08, 2009 | Gateway (5500652) (  5500652)...
My cd rom drive will not recognize any cds or dvds. When I put a disc into the drive it will tell me to insert a blank disc into the drive. I have tried over ten different discs (including the one that...
what do you mean not recognized? not detecting the drive or not reading? if not recognized by windows you can check the driver for drives in the windows if not reading it is the lens problem..if the lens problem, the solution only is to replace the lens or to replace the whole drive
Mar 07, 2009 | Computers & Internet
How to retrieve data from external drive
I had similar problem. See FAQs on this site. My 300 GB One Touch II drive was not found in the XP machine either as USB or IEEE. When I remounted the drive in an external cabinet from Deltaco ( MAP-KC) is is running since. The Maxtor chassi was the trouble not the 3,5 " drive. All data is recovered. // Regards AH2FOTO
Sep 24, 2008 | Maxtor OneTouch II external hard drive...
DVD-RW drive burns music CDs and DVDs, but not data CDs
Alright. Seems like Windows, for some reason, doesn't think your drive is able to burn things when trying to deal with this kind of disc.
I'll need further information, like if you use another program to burn music CDs, and what other things might have changed the registry settings. I know of a fix that resolves issues with the Windows version of data CD burning, but it only applies to CD-R and CR-RW drives..
Apr 08, 2008 | Computers & Internet
Drive Being Recognized as Removable Disk
Same issue with my 500 GB TFD500U16. A little more description is that my PC is detecting the power when turning on the drive and the HDD itself is spinning up. Also the Blue light that normally indicates HDD activity by turning Red no longer shows activity but just stays Blue. This indicates that the data side of the HDD is not seated properly. Since mine is out of Warranty, I took it apart and found this to be the exact case.
! ! ! ! Please perform this at your own risk ! ! ! ! Especially if your warranty is still in effect! ! ! By loosening the HDD mounting screws inside that will allow the connection to seat properly and data to be seen.
Dec 16, 2007 | Fantom Titanium II (TFD500C16) 500 GB USB...
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
