Question about Ovens
Does the teka HI 595 fan oven have a self-clean mode? And if so, how does it work - I moved into a house with no instructions for this.
5 Suggested Answers
SOURCE: cleaning our viking oven
I had to clean mine the old fashioned way -oven cleaner and elbow grease. Fortunately the oven comes apart in ways I never imagined so I could remove, for instance, the sides and bottom and clean them without bending over with my head in the oven!
Posted on Dec 22, 2007
  • 1314 Answers
SOURCE: door won't open after self cleaning.
it is locked the leaver has become detached from the door latch and even though the leaver moves the lock part doesn't have you tried it lately push in on the door and try to move the leaver if that doesn't work get a wire coat hanger make a Small hook and from the left hand side see if you can snag the hook and pull it over ive done that before theopen end of the hook should point up start just abve the door gasket about halfway over well i cant reamber which way the latch moves but im sure you can figure it out push slighty in on the door after you hook the latch but try to open it fist some have asensor that wont let the oven door open till its cool enough to be safe let me know
Posted on Dec 31, 2007
micromaster
  • 3614 Answers
SOURCE: how to use self cleaning oven
  • When using the self-cleaning feature on your oven, the temperature within the oven rises to an extremely high temperature, usually around1000 degrees. The oven will remain at this temperature for a set periodof time, often from 1 to 3 hours.
  • Self-cleaning ovens differ from traditional ovens in that they require a timer to control the amount oftime that the self-cleaning feature operates. They also require extrathermostatic controls to control the extremely high temperatures.
  • While the mechanisms inside aself-cleaning oven are quite complex, the concept behind aself-cleaning oven is fairly straight forward. The extremely hightemperatures incinerate dirt and debris from your oven, thus cleaningit for future use.
  • Safety is very important when using yourself-cleaning feature. You must ensure that the oven door is completelyclosed while the self-cleaning cycle is running. 1000 degreetemperatures are obviously extremely dangerous. Self-cleaning ovenswill come equipped with a secure oven door latch for this reason.
  • The crucial door locking system isinitially engaged to signal that you are ready to use the self-cleaningfeature. When the oven reaches a certain temperature, the door locksystem will ensure that the oven door cannot be opened until the cycleis complete and the temperature has returned to a manageable level.The result is a clean oven without the use of harsh oven cleaners orabrasives.
REMEMBER YOU ARE WORKING WITH 220 VOLTS - USE EXTREME CAUTION!!!
Posted on Nov 11, 2008
SOURCE: Elitech 1300W convection oven: How to set it for self cleaning
Hi
If you watch the advert for the Nuwave or Flavorwave they set the machine to defrost setting.
Put water in and a bit of washing up liquid and put on for about 10 min.
Posted on Dec 09, 2008
How do you clean a self cleaning oven? I don't have the instructions. It's a Frigidare gallery convection oven. We bought it used. I just need the Instructions. (it didn't come with any) Thanks Debbie
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Feb 19, 2011 | Ovens
Thermador oven will not self clean.The blower fan does not turn on, and the word HEAT never appears when LOCK stops blinking. In other words, after following steps 1,2 and 3 fan and heat never happens.
heatman101
Dec 23, 2010 | Thermador Ovens
Instructions for Amana Self Clean Oven
heatman101
Dec 13, 2010 | Ovens
I have a Teka oven HI-595 that shows power, fan works and grill works but oven won't heat up. What should I do?
If the fan is working o/k, then it is probably the oven element that is faulty, usually located at the rear of the oven compartment behind a removeable cov er.
Oct 21, 2010 | Ovens
I recently purchased a house with a Maytag wall oven but no manual. I'd like to be able to use the self cleaning option. Model MEW5530BCW
heatman101
Oct 14, 2010 | Ovens
Moved into this house. Has no manual on Kenmore glass top stove, on how to use self cleaning oven. Looking for manual or directions on how to use it. Only have model # 790.96011400 and serial # VF50635079
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Apr 13, 2010 | Ovens
No instructions on how to use self cleaning Frigidaire range/oven
stove stuck in self cleaning mode door was open when cleaning mode was turned on will not shut now what do i need to bdo?
Feb 14, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Teka h e 500 oven wont heat up....
If the fan is working o/k then the oven element is probably faulty, this should be at the rear of the oven behind a removeabkle cover.
Make sure you have the control set to grill , for grilling
Dec 03, 2009 | Ovens
Teka Model HC-595 - oven does not heat, fan working ok grill working ok
Sounds like the fan element has blown. I think access is from inside the oven at the back BUT the screws to undo the element are accessed by removing the rear cover. You will have to take the oven out of the cabinet to where is is fitted to do this and from memory there is an earth tag which is fixed to one of these screws
Oct 19, 2009 | Ovens
Ovens Logo
87 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
