Question about Reddy Heater-30,000 BTU Propane Forced-Air Heater
My rlp 30a from lowes will ignite but when I release the ignite button it dies no matter how long I hold it willstill die when I lelease I used only one year I need to know were to get parts
  • 232 Answers
It sounds as if the thermocouple is defective. Link to a test.
Posted on Oct 06, 2010
I have a DRZ400S, when you try to crank it it will start as long as you hold the start button down release the button and it dies.. As long as I hold the button down the start button for electric starter...
Are you using the choke?
Start with routine maintenance.
New Spark plug.
Make sure the air filter is clean. If it's dirty enough it will cause too much resistance.
Clean carburetor jets.
Then check valves. On that bike, the valve clearance will get tighter as it gets older.
If you have made any drastic alterations to carb settings, return them to factory.
Oct 07, 2014 | Motorcycles
Starts but when switch is released it dies
hi Jeff
you have a faulty ignition switch, replace it and your car will be OK
Mar 25, 2014 | 1992 Daihatsu Charade
My wife's XL1200/ 2008 model, engine light comes on and shortly thereafter the engine dies
Did you pull any error codes?
No?
Don't know how?
1- Turn motorcycle ignition switch to OFF & Run/Stop switch to RUN.
2- Push odometer reset button in & hold.
3- Turn ignition switch to Ignition and release odometer reset button. Background lighting will illuminate, speedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word "diag" should then appear.
4 - Push the odometer reset button once and you will see the selection menu "PSSPt" with the first P flashing.
5 - Each letter represents an area of the diagnostics module. The module that is flashing is the one you are going to check. To move from one letter (module) to the next, you push the odometer reset button one time. (from P to S to SP to t and back to P, etc.)
P = ECM/ICM (Electronic Control Module [EFI] / Ignition Control Module [Carburetor])
S = TSM/TSSM (Turn Signal/ Turn Signal Security Module)
SP = speedometer
T = tachometer
6 - To get the DTC in an area of diagnostics, push and hold the odometer reset button in for 5 seconds and release. If there are any DTC's the code will be displayed or the word "none" will appear if there are no DTC's. Push the odometer reset button again to view additional codes if they exist.
7 - Record the codes.
8 - If DTC's are not to be cleared, Press and release the odometer reset button. Part number of module will be displayed. NOTE: To determine if a code is current or historic, clear the displayed code by pushing in and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up. Release the odometer reset button. Turn OFF the ignition switch. Run your bike and shut it down then recheck the DTC's again by repeating steps 1 to 9. If the code is current it will reappear.
9 - Press and release the odometer reset button to continue to the next module.
10 - Turn Ignition switch to OFF.
On models not equipped with a tachometer "No Rsp" will appear when the tachometer identifier is selected.
"No Rsp" will also appear if the run/off switch is in the off position when doing this procedure.
Either look up, or repost error codes that you did get.
Jan 23, 2014 | Harley Davidson XL 1200 C Sportster Custom...
Cant get my heater to stay ignited
THERMO COUPLER, COPPER PEICE INSIDE TUBE MAKE SURE THE FLAME IS IN CONTACT WITH THIS PEICE, 99 PERCENT OF THE TIME IF A UNIT HEATER, WATER HEATER ETC WILL NOT STAY ON AND DOES WHEN YOU HOLD IT IN IT IS THE THERMO COUPLER
Jan 20, 2010 | Reddy Heater-30,000 BTU Propane Forced-Air...
1990 cadillac deville ( service engine soon) light comes and goes
with ignition ON, push the OFF and WARM buttons togethend release. on your A/C control panel. Hold for 5 sec and stored codes should show. Codes should reflect upon problem you are experienceing. Hope this helps.
Apr 07, 2009 | 1990 Cadillac Deville
My car wont stay running
Does the engine die as soon as you release the key, or does it run for a couple of seconds after you release the key and then die? If it dies as soon as you release the key, try holding the key for a few seconds and see if it will stay running as long as you are holding the key (the starter will make a grinding sound while holding the key but won't hurt anything). If it stays running while you hold the key then dies when you release it, that indicates that the ignition switch is bad.
Jul 01, 2008 | 1992 Honda Accord
Reddy Heater-30,000 BTU Propane Forced-Air Heater Logo
179 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
