DVD Drives support
It seems that, something wrong with DVD/CD Drives because it takes time to open DVD or CD. Disk drives can not find and open DVD or CD automatically.
DVD/CD Drives does not work properly and I am looking for SW to upgrade DVD/CD Drives (MATSHITA DVD-RAM UJ-840S) for my laptop (HP 375052-001).
Thank you,
Ed.
  • 60 Answers
Your Laptop Model no does not seem to be valid. However asuming that you are using HP Laptop, check the below Link and find out your competable DVD drive
http://www.bixnet.com/hewhp.html
Posted on May 28, 2008
You need to format the disk in drive G before using it. Then when I click ok it says cannot be formatted.
the internal floppy drive is ALWAYS drive A: ...so be very careful you're not trying to format something (drive G:?) you shouldn't be. Perhaps your drive G: is a dvd or cd drive...or more likely a usb drive. Formatting the wrong drive is a bit catastrophic in terms of data loss.
Hope this helps.
Regards
nicam49
Dec 21, 2010 | NEC FD1231M 144MB 35" Internal Floppy Disk...
Disc tray will not open e-machine T5224
This is not uncommon with older CD/DVD drives.
There should be a very small hole on the front of the drive that can be used to manually eject the disk.
Straighten out a paper clip and insert it in the hole. It may take a little fiddling but you should be able to get your disk out.
Unfortunately, this indicates that you drive is failing so you should replace it soon.
I hope this helps.
Feb 21, 2010 | E-Machines emachines (emachinees) CD-ROM...
Iomega select portable external 320GB 2.5" Hard drive not being detected on the PC with windows 7
  • Hi, there are (3) three areas that you can search to find: Hard Disk Drives. 1. From the Desktop, click on the Computer Icon to open the "Hard Drives (window)," next find the Hard Disk Drive (1), this is the "Primary" (C:) Drive. 2. Next, in the Devices with Removable Storage (1)below is the "Secondary" Drive, this will be the (CD or DVD Drives (D:), for "External Drives" the drives locations will be (E: or F:). 3. "If the CD, or DVD Drive is present in this area?" Right click to open, select the Properties "icon" the window opens; in the "All disk drives" (block), select, and "highlight" the CD or DVD Drive, next click on the Propertie's button below! 4. In the Device Status (block), see: if the device is "working properly?" Next, click on the Drives button, select to "Update Drivers." Note: The computer screen may "blink' (3-5 times), this means the update has taken place, Click on the "Apply and OK buttons, to finish. "You may be ask to "Restart the computer, if not? Restart the computer." *The "Second" area is the "All Programs" in the Start Menu, scroll to find: Media Disk Player. Select to open, click on "Setup, and Install." Follow all instruction carefully! *The "Third" area is in the Control Panel from the Start Menu; find in the (right pane). Open the "Contol Panel" go to, and select Hardware and Sound, in the next window, click to open the Device Manager; scroll to find: DVD/CD-ROM drives. Click to open; do the same as above instructions, step by step. "Did this solution help? If so, Helpful Ratings Feedback is appreciated, thanks paul7of9"
  • Feb 17, 2010 | Electronics - Others
    It will come on but it says primary hard disk drive 0 found and secondary hard disk drive 1 not found
    Feb 15, 2010 | Dell OptiPlex GX110 PC Desktop
    Dell Dimension 8400 Bottom DVD Drive will not open
    Well in most PC related optical drives, there is a very small opening on the front of the drive, who gives access to the opening mecanism. You can use one end of a small paperclip to reach it. (In case you have a CD in there you want) Now about it working the usual way, there isnt much your can do, maybe somthing related to it's power, but again, if somthing is broken... unless it's still in waranty Good luck!
    Jun 03, 2009 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
    DVD ROM can play CD, but not DVD
    try with next dvd which is burnt in less than 16x speed then check what happens.
    Jun 02, 2009 | ASUS (E616P2) Internal DVD Drive
    Dvd ram can not read cd.
    I had the same problem, this is what worked for me.... I opened the cd/dvd drive on the side of my laptop and gently cleaned the small laser and hey presto it worked, can now erase,read and play my discs.Give this a try it only takes a few seconds. Good Luck
    Apr 20, 2009 | Acer Aspire 4315 Notebook
    CD and DVD drives
    cd rom drives are pretty straightforward. if they dont open, there's no way to fix it since the units are non user serviceable. replacement is the only option. :)
    Oct 14, 2008 | E-Machines eMachines Desktop PC
    Sony DVD RW DRU-820A
    HI,
    Double check the Ribbon Cable Connector is installed Correctly ( 40-80 Strand IDE ) sometimes if these are not fitted squarely Or pushed in hard enough. Can cause a Problem.
    Also try the emergency eject procedure on The Drive. Small jewellers screwdriver Or Needle, insert into the drives faceplate ( pinhole in drives faceplate drawer ) push to open dvd drawer. pull out drawer Gently. And push back in. This ocassionally works for a stcking Drawer/eject mechanism.
    Finally try the drive without a disk in ( open/eject Or Close )
    Mike @ Compurepair.
    Jul 01, 2008 | Sony DRU-820A DVD RW Dual Layer Burner
    Need help
    Computer CD-ROM drive help and technical information. DVD-RAM - ReWritable drive type that uses a phase-change technology like the CD-RW drives. ... CH000031, CD-ROM receiving power but does not work.
    Computer DVD Support The Divix player is more expensive than a standard DVD drive and current DVD drives do not ... CH000327, Will a scratch cause a CD or DVD to not work?
    CD or other disc tray does not close or opens by itself. A CD-ROM or other disc drive tray that does not close or remain in the drive ... If the above recommendations do not work, the drive tray does not push all.
    Computer CD-R help and technical information The CD-R drive does not actually create pits on the CD, instead the burner ... There were issues with reading CD-R disks in the first revision of DVD.
    Device Manager information and help Later versions of Microsoft Windows renamed this category to DVD/CD-ROM drives .... If the device does not work correctly, use Device Manager to remove the.
    Computer Cleaning Information CD / DVD cleaning Floppy drive cleaning Hard Disk Drive cleaning .... If a keyboard does not work after trying it again later it is recommended that it be .
    Good Luck, Read & follow instructions/Please dont for get to Vote/Thank You.
    Dec 22, 2007 | HP Pavilion dv4000 Notebook
    Computers & Internet Logo
    140 people viewed this question
    David Payne
    David Payne
