Question about Frigidaire Dishwashers
I have a frigidare professional series model pld4375rfc dishwasher. It turned on but did not wash. Er kept flashing. I replaced the control board but it didn't fix the problem. It still doesn't wash.
  • srauletta Oct 05, 2010
    I replaced the control panel on the diswasher but it still doesn't work. I keeps flashing Er. What do I try next?
  • Frigidaire Master
  • 3,051 Answers
Hello there:
this is a communication error that is coming from the main control board being faulty
Frigidaire had some issues with the electronic control board doing this.
You would need a new one,
Posted on Oct 05, 2010
    Brigadier General:
  • 3,513 Answers
It's a control panel failure. This unit does not vent from the front like most do, so there needs to be some clearance above the top of the tub to avoid blocking the vent fan, otherwise moisture gets trapped in the machine and works its way into the control panel eventually.
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
ER code, flashing touch pad selections.
It is most likely a fault with the keypad mebrane on the dishwasher control panel. Need model number of dishwasher to make a more detailed conclusion.
Jan 04, 2013 | Frigidaire Dishwashers
Frigidaire dishwasher fdb520rhs2 not washing
Hello - I will suggest verifying that there is enough water pressure coming into the unit. When was the last time the filter was cleaned? Do you noticed if the spray arm will rotate freely or if it is damaged? If so, you might have to remove and replace the spray arm assemblies. If any proves to be ineffective, it could possibly have a communication problem coming from the main control board, I would suggest contacting a professional technician to diagnose the unit accurately.
Sep 26, 2012 | Frigidaire PLD4375RFC Dishwasher
I have a Frigidaire model#PLD4555RFCO the er code and the washing and drying and clean and S lights are on and blinking on the display. have any ideas what the problem is?
Hi
"Er Clean S" is a common error with Frigidaire which means shorted keypad. The issue is with the touchpad/keypad that should be replaced. However, before replacing the keypad you can unplug it and take it apart completely and use a hair dryer to blow some warm air on the keypad assembly to blow the moisture off. Hope this helps...please post back for further assistance.
Daniel
Aug 27, 2011 | Frigidaire Professional Series 24 in....
Error message "clean S"; flashing
Hi
Daniel
Jun 18, 2011 | Frigidaire PLD4375RFC Dishwasher
Error codes flashing
Hi, This is mainly due to control panel failure. This unit does not ventfrom the front like most do, so there needs to be some clearance above the top of the tub to avoid blocking the vent fan, otherwise moisture gets trapped in the machine and works it's way into the control panel eventually..
Apr 13, 2010 | Frigidaire PLD4375RFC Dishwasher
I have a PLD4375RFC DISHWASHER WILL NOT RUN P F FLASHES AFTER ABOUT 2-3 MIN. it will start and run for 2-3 min.before the power failure unit less then one year old
Sounds like a faulty console panel. They had a problem with moisture getting into it, and causing it to get a PF (power failure) code. If it's under 1yr old, it should still be covered by manufacturers warranty. Part number for console with touchpads is 154639207, failing that, i'd say you have a bad control board, but console much more likely.
Mar 31, 2010 | Frigidaire PLD4375RFC Dishwasher
4000 Series Aquasurge diswasher, ER code came up
VO is vent sticking open, in top of tub upper right. You may be able to clean if not replace it.
Oct 03, 2009 | Frigidaire PLD4375RFC Dishwasher
Dishwasher Frigidaire Professional Series model PDL4555RFC indicator is flashing Er and other words in red
The dishwasher is junk...poorly designed. Masterboard for electronic buttons keeps shorting out because the dishwasher vents from the top. have this dishwasher and know first hand. had it for about a year and its been fixed several times
Aug 07, 2009 | Frigidaire Professional Series 24 in....
6 mo. old frigidaire d/w displays the "ER clean S" flashing error
Probably a control panel failure. This unit does not ventfrom the front like most do, so there needs to be some clearance above the top of the tub to avoid blocking the vent fan, otherwise moisture gets trapped in the machine and works it's way into the control panel eventually.
Jan 01, 2009 | Frigidaire PLD4375RFC Dishwasher
Dishwashers Logo
97 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
