Question about JVC HX-D7 DVD Compact Stereo Audio / Video System with 5 DVD Changer Shelf System
Protect message when pressing the on button i get status protect message then th unit goes off
  • 4,234 Answers
Protect means that a problem was dtected and the output amplifier section has been disabled to prevent further damage. The typical failure parts are the output transistors. Expect a parts cost between $15-$40. Add in the local labor rate for the total repair cost.
Dan
Posted on May 28, 2008
My Panasonic inverter split zircon with r410a blinking the red timer running indoor motor while out door unit not running?
To display memorized error (Protective operation)
status:
1. Turn power on.
2. Press the CHECK button on the remote controller
continuously for 5 seconds.
3. "- -" will be displayed on the remote controller display.
Note: Display only for "- -". (No transmitting signal, no
receiving sound and no Power LED blinking.)
4. Press the "TIMER" or button on the remote
controller. The code "H00" (no abnormality) will be
displayed and signal will be transmitted to the main
unit. The power LED lights up. If no abnormality is
stored in the memory, three beeps sound will be
heard.
5. Every press of the button (up or down) will increase
abnormality numbers and transmit abnormality code
signal to the main unit.
6. When the latest abnormality code on the main unit
and code transmitted from the remote controller are
matched, power LED will light up for 30 seconds and
a beep sound (continuously for 4 seconds) will be
heard. If no codes are matched, power LED will light
up for 0.5 seconds and no sound will be heard. 7. The breakdown diagnosis mode will be canceled unless pressing the CHECK button continuously for 5
seconds or operating the unit for 30 seconds. 8. The same diagnosis can be repeated by turning
power on again.
To clear memorized error (Protective operation) status after repair:1. Turn power on.
2. Press the AUTO button for 5 seconds (A beep
receiving sound) on the main unit to operate the unit
at Forced Cooling Operation mode.
3. Press the CHECK button on the remote controller for
about 1 second with a pointed object to transmit
signal to main unit. A beep sound is heard from main
unit and the data is cleared.
• Temporary Operation (Depending on breakdown status)
1. Press the AUTO button (A beep receiving sound) on
the main unit to operate the unit. (Remote control will
become possible.)
2. The unit can temporarily be used until repaired
Apr 24, 2017 | Panasonic Heating & Cooling
My HP Photosmart C6280 asks me to replace the light blue ink cartridge and says it is unable to print until we replace the ink cartridge. We have replaced it three times and the same message appears. The...
Follow the below steps on the front panel of the All-in-One printer:
A. - Press and Hold the "Print Photos" & "Red Eye Removal" buttons. Release both buttons.
Display should say "Enter Special Key Combo"
B. - Press and release in sequence "Red Eye Removal", "Print Photos", "Red Eye Removal"
(try both and see which one will get you to system config menu )
display says "enter special key combo"
1. Press and release in sequence "Red Eye Removal", "Print Photos", "Red Eye Removal"
2. Press and release the right arrow button until the display says "System Configuration
Menu".
3. Press and release the "OK" button.
4. Display should say "Hardware failure status". If not there already, Arrow Key over to
5. Press and release the "OK" button
6. Display should say "Hardware failure status: Clear. Press OK to clear".
7. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared.
Press Cancel to continue".
8. Press and release the "CANCEL" button as many times as necessary, so that, either the
"Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears.
PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the
printer and wall outlet.
it is now powered down and unplugged.
10. Wait 30 seconds for the power to get discharged and then plug the power cable into the
wall outlet first and then into the back of the printer
11. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
12. If the printer has already initialized, then go to the next step. If not, the printer
will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do
not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
13. To verify printer functionality print a SELF TEST PAGE.
Aug 31, 2011 | HP Photosmart C6280 Printer
I am getting the message "Ink System has failed. Unable to print. Refer to printer documentation. Error:0xc18a0001." I have tried to shut it down and back on and it's still not working -...
1. Get the unit into the "Support Menu" by following the steps below according with the product,
A. - Press and hold the "left arrow" key.
B. - Press the "Setup" key and release both keys.
C. - Press and release the "OK" button
2. Press and release the right arrow button until the display says "System Configuration Menu". (on C8100 use Touch Screen)
4. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
5. Press and release the "OK" button.
7. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
8. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
10. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
12. If the printer has already initialized, then go to the next step. If not, the printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
14. If the error is still there, or reoccurs replace the unit.
VOTE ME IF YOU LIKE THIS SOLUTION
Aug 12, 2011 | HP PhotoSmart C5150 All-In-One InkJet...
Ink system failure error message Oxc18a0106. How do I fix this?
Hello.
Try this
Hewlett Packard Ink System Failure Error Fix (tested C6180) 1- Press and hold the "*" key. 2- Press the "#" key and release both keys. Display should say "Enter Special Key Combo" 3- Press and release in sequence the "1", "2" and "3" buttons. screen says "support" R0631M 4. Press and release the right arrow button until the display says "System Configuration Menu". 5. Press and release the "OK" button. 6. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status", 7. Press and release the "OK" button. 8. Display should say "Hardware failure status: Clear. Press OK to clear". 9. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue". 10. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. 11. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. 12. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer 13. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
I hope this helps Regards GM
Jul 15, 2011 | HP Photosmart C7280 Printer
I am unable to print and have the following error message Oxc18a0401 come up. How do I solve this?
Try This.
Press and hold the “*” key.
Press the “#” key and release both keys.
Display should say “Enter Special Key Combo”
Press and release in sequence the “1”, “2” and “3” buttons.
Press and release the right arrow button until the display says “System Configuration Menu”.
Press and release the “OK” button.
Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
Display should say “Hardware failure status: Clear. Press OK to clear”.
Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. DO NOT TRY TO PRINT AT THIS STAGE.
Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
If it didn't print a diagnostic page
Is the error message still being displayed on the printer?
No? Good.
Press Setup menu on the All-in-One then scroll using the arrow key and select Print Report then select Self Test Report.
Jul 28, 2010 | Office Equipment & Supplies
HOW DO YOU RESET THE ERROR MESSAGE 0xc18a0207 on an HP 6100 series all in one ?
A. - Press and hold the “*” key.
B. - Press the “#” key and release both keys.
C. - Press and release in sequence the “1”, “2” and “3” buttons.
1. Press and release the “OK” button.
2. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
3. Press and release the “OK” button.
4. Display should say “Hardware failure status: Clear. Press OK to clear”.
5. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
6. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
7. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
8. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
9. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
10. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
11. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
Jul 26, 2010 | HP Photosmart C6180 All-In-One InkJet...
Oxc18a001
1. Get the unit into the ?Support Menu? by following the steps below. A. - Press and hold the ?*? key. B. - Press the ?#? key and release both keys. Display should say ?Enter Special Key Combo? C. - Press and release in sequence the ?1?, ?2? and ?3? buttons. 1. Press and release the right arrow button until the display says ?System Configuration Menu?. (on C8100 use Touch Screen) 2. Press and release the ?OK? button. 3. Display should say ?Hardware failure status?. If not there already, Arrow Key over to ?Hardware failure status?, 4. Press and release the ?OK? button. 5. Display should say ?Hardware failure status: Clear. Press OK to clear?. 6. Press and release the ?OK? Button. Message changes to ?Hardware failure status Cleared. Press Cancel to continue?. 7. Press and release the ?CANCEL? button as many times as necessary, so that, either the ?Welcome to Photosmart Express? screen appears, or, the ?Ink System Failure? screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. 8. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. 9. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer 10. Turn the unit on. The printer may display message ?USE POWER BUTTON TO SHUTDOWN THE PRINTER? followed by ?PRESS OK TO CONTINUE?. Press OK.
May 27, 2010 | HP Photosmart C6180 All-In-One InkJet...
0XC18A0101
May 25, 2010 | HP Photosmart C6180 All-In-One InkJet...
Will not print, has error message 0xc18a0406. ink system failure
The ink system failure message has a chance to be fixed or it may be a permanent issue. It can be pointing toward a firmware failure in the printer and if that is the case the following steps should fix it.
Press and hold the “*” key. Press the “#” key and release both keys.
Press and release in sequence the "1”, “2” and “3” buttons.
Display should say “Support” and display the FW rev (something like R0631R)
Mine reads R0631M
. Press and release the right arrow button until the display says “System Configuration Menu”.
Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer.
Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. Good Luck!
Jan 20, 2010 | HP Photosmart C6180 All-In-One InkJet...
Message on printer screen "ink system failure" Message on computer screen "print head failure"
The ink system failure message has a chance to be fixed or it may be a permanent issue. It can be pointing toward a firmware failure in the printer and if that is the case the following steps should fix it. Press and hold the ?*? key. Press the ?#? key and release both keys. Display should say ?Enter Special Key Combo? Press and release in sequence the "1?, ?2? and ?3? buttons. Display should say ?Support? and display the FW rev (something like R0631R) Mine reads R0631M . Press and release the right arrow button until the display says ?System Configuration Menu?. Press and release the ?OK? button. Display should say ?Hardware failure status?. If not there already, Arrow Key over to ?Hardware failure status?, Press and release the ?OK? button. Display should say ?Hardware failure status: Clear. Press OK to clear?. Press and release the ?OK? Button. Message changes to ?Hardware failure status Cleared. Press Cancel to continue?. Press and release the ?CANCEL? button as many times as necessary, so that, either the ?Welcome to Photosmart Express? screen appears, or, the ?Ink System Failure? screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer. Turn the unit on. The printer may display message ?USE POWER BUTTON TO SHUTDOWN THE PRINTER? followed by ?PRESS OK TO CONTINUE?. Press OK. The Printer will start the ?ONE TIME INK INITIALIZATION PROCESS?. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. Good Luck!
Aug 06, 2009 | HP Photosmart C6180 All-In-One InkJet...
355 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
